Supercharger Swap
Originally Posted by SLOWBALT06
yea but every turbo thread is a laughing stock ive done my research at least on this site and its not taking me anywhere but the begining if i were to do a custom turbo swap how much total do you think all that would cost
Manifold $150(Ebay)-$599(Hahn)
Good Turbo $800-1200 depends on what your desires are
60lb injectors/harness $220
BOV w/flange $220
Charge piping/downpipe $100-$300 depending if you can fab/weld them yourself
Oil return/feed lines and fittings $100
Fab your own TB adaptor for the stock manifold $50
Professional Tune $500ish
$2270 low side to $3689 high side.
i just want a price range at least i want a nicely sized turbo that will push a bit more power than our m62 , i want to stay somewhat cheap im not talking like extremely cheap but no top of the line turbo and stuff just good buys what do you think would be a range of price 3,000 4,000 cheaper around there im not looking for EXACT $ #'s just a range
$3000-4000? Why don't you just do a twinscrew supercharger swap?! You have a better low end...
I'm afraid that most of you guys are not ready for going to a full turbo setup on a relatively brand new car.
Also, I don't think some of you guys fully understand how a turbo system works and what is involved to do such a project, which is understandable but I don't want you guys to jump into something that is way over your heads.
Yeah, you definitely pulled it out of your ass like you said unless you're meaning twinscrews only:
1. A larger displacement supercharger obviously offers more HP potential.Not true...it is ONLY when it can offer more cfm...M90s don't but maybe maybe 50 more cfm...MAYBE
2. It runs cooler because it spins slower. Not true...it is based off of how much boost is there...for it to run cooler and spin slower, you have to make it put out an equal cfm or larger at a lower level of boost...M90s don't.
3. Bearing speed friction and oil temperature are reduced.Refer back to #2 for the blower speed and the oil temp doesn't matter except for how often you have to change it (50k miles) since it is a self contained oil system...if it was pulling oil out of the crank case, that would be different.
4. Cooler air charge temperature. Only if you're looking at a twin screw because the M90 doesn't put out more cfm at equal boost levels where it would be worth while.
5. Lower parasitic loss (less engine HP to spin). M90 requires 20hp more at top end than M62.
6. Larger pulleys have more surface area for less belt slippage and wear.That is only viable info if you are using a large rib belt, like an 8 or 10 rib which is very costly because you would have to change all the other pulleys on the engine to hold that large of a rib belt...ours are only for 6 rib...we have a decent tensioner, along with the ability to purchase a larger idler pulley and idler pulley adjustable tensioners so with what we have available, belt slippage isn't an issue...
Originally Posted by Serpico
ohh ok, kenne bell pulls **** out of his ass too then cause thats where i got the information from http://www.kennebell.net/supercharge...gmCorvette.htm
Can Kenne Bell pull me a 1.3L twinscrew size **** out of his ass?
Originally Posted by 2K5SS/SC?
I could definately do the turbo swap if I wanted to. The setup is actually fairly easy to me, but I have done hours upon hours of extensive research on it. I sized a perfect turbo for the setup, and sourced all the parts I would need. That hardest part would be tuning it all. I love fabrication work, so that's not an issue for me. In fact all my buddies are turbo'd and I'm the only one with a supercharger. Some people on here may not have the capabilities like I do though, so it may be harder and more expensive for them. That is why Hahn Racecraft kits will be great for all those that would rather spend their money to get a decent setup ready to bolt on.
HPT $500
BOV w/flange $220
BOV w/flange $220
2 questions what is hpt -500 $ hp tuners if so why would you need the 500$ pro tune ? just bc they know what there doing or what ?? second how much hp do you think would be possible to put down with just a turbo swap bc if i could get 260 - 280 whp for 2500 i think im gonna do it thats really not TOO bad
The question you're asking as far as power gains, it's all circumstancial and it really can not be answered. It depends on so many things that no one can sit here and type up some magical number cause it would mislead you. Even if you told us exactly what you were planning on using and your whole setup, we still could not give you a number. In performance, there is never a set number for a modification, especaially something as complicated as a turbo setup.
so all in all i might as well just buy a new clutch and axels and start trying to build this m62 up i want to run mid 12's nothing too spectacular but i know when i get there im gonna want mid 11's and thats when im gonna want that turbo or big supercharger
Also, the problem with the M62 is that after you get so small of a pulley, you're generating more heat than you are making power.
Remember, the faster you are, the more maintenance you'll have as well.
Getting away from EATONs would be the best way of upgrading. Porting hasn't shown any more than 4 or 5whp gains so that is several hundred for pretty much no power so I wouldn't even advise someone to port...
you do realize that eaton owns autorotor just go to www.opcon.com and see what comes up
if i were to ever do a twin screw it would be a eaton twin screw
first im going to try the m90 though used m90 off ebay 300 bucks and i can make a temp. adapter plate to see viability that will only cost 20 bucks tops (i can weld) if it doesnt work out ill throw the charger back on ebay so at worst im only out 20 bucks and some of my time to find out if this is a worthwile upgrade or not
Opcon Autorotor OA 3133
Update, some quick research shows that the unit above will only spin to 13000 rpms. That would not work to well on our car with some math I did earlier in the day.
Why the hell did you wait until now to show this information to me. There are several blowers from Sprintex/Autorotor that are exactly what we need for this setup! I have no information or pricing on it, but this number looks to be promising! I can't access the site either, and I'm looking at something this very moment somewhere else! Grr......
yea ive been in contact with autorotor/sprintex about getting a unit over here for some comparison testing more info can be found here http://sprintex.com.au/Opcon_Autorotor.asp
For everyone's information, I was bidding on the Whipple Supercharger system for the PT Cruiser which just so happens to have a 1.2L 75AX supercharger as the main unit which is good for 831 CFM's and 20000rpms max spin. That is the first thing I've ever bid on Ebay for, and it has definately pissed me off! It went for only $480 too!
how much can we get this blower for and how hard would it be to install on our car and other than HPtuners , Injectors , Harness , Clutch , Axels is there anything else we would need also what kind of numbers are we talking about here , another thing the 1.33 you all are talking about is that the one from the people that own eaton
Also, if it only goes to 831cfm, that isn't too much off of where ours maxes out so it is probably best that way really.
