tvs owners.
Old Jan 6, 2009 | 11:20 PM
  #301
Highrev1's Avatar
First post , but why don't any of you guys run the 1600AX twinscrew? I have only seen a 1000ax on these cars and they are out of their max efficency range.
Old Jan 6, 2009 | 11:25 PM
  #302
ColeJJones's Avatar
Bannned
buy it and let us know...
http://forums.vwvortex.com/zerothread?id=4031067
Old Jan 7, 2009 | 12:01 AM
  #303
Highrev1's Avatar
I only ask cause I have ran one on an RSX engine.... So I know about the upgrade witht hem fromt he m62 to the 1600....Done some heat testing also....
http://www.youtube.com/watch?v=bvkzmetTOp4
Chart that shows the difference in temps that our intake air temp sensor is reading in a 3000-8500 rpm WOT sweep VERSUS a 10 second steady state rpm and boost load. Boost levels in sweep and steady state modes were almost exactly the same. RSX brakes will never be the same again. Try a 10 second run at 7000 rpm in 3rd and hold the brakes so you don't go any faster. Wow. And one more note..... and that is that the intake air heat would level off after about 6 seconds; so the steady state heat figures are probably within a few percent of what they would be in a bench test over 20 seconds.
Falme suit is on....I know I am a noob here...
Originally Posted by ColeJJones
No need I have quite a few of these sitting around I just don't know why noone has tested it....Anyone in NJ with ***** or
Old Jan 7, 2009 | 12:16 AM
  #304
BoostedYards86's Avatar
i've brought up the whipple before but everyone says that it will take too much power to spin...
Old Jan 7, 2009 | 12:20 AM
  #305
Highrev1's Avatar
If HP and TQ are gained, over another charger wouldn't that offset the parasitic loss? Lysholm charger btw
Old Jan 7, 2009 | 12:22 AM
  #306
Erod's Avatar
Moderator Alumni
Originally Posted by Area47
less than a 200 dollar fix.
also it says OBO.
i have left you be for a couple days out of respect. i expect the same in return.
FASTECOTEC = JUICETURBO = will keep getting banned. What an idiot.
Old Jan 7, 2009 | 12:26 AM
  #307
car_guy_09's Avatar
Get em Erod!
Old Jan 7, 2009 | 12:27 AM
  #308
Area47's Avatar
Rent me! per hour
erod, thanks man
Old Jan 7, 2009 | 12:36 AM
  #309
what would your honda's put down with this s/c just out of curiousity...hp/tq?
Old Jan 7, 2009 | 12:37 AM
  #310
Erod's Avatar
Moderator Alumni
Actually Reign picked up on that and banned him. Anyone that keeps re registering has got to be a ******* loser, wow.
Old Jan 7, 2009 | 12:41 AM
  #311
Highrev1's Avatar
Depends...Cooled or uncooled....and the PSI...This was on an uncooled setup and it was probably around 300-320 hp at 12psi...Cooled at 15psi 350-375 easy..
Old Jan 7, 2009 | 12:48 AM
  #312
thats pretty impressive man.
Old Jan 7, 2009 | 12:52 AM
  #313
Highrev1's Avatar
With 12 psi the charger was at 12,100 rpm at 8800 rpm so on the RSX there is room to go. The 1600AX published material from last year said 15,000 rpm. And I've heard from the people that did R&D on the Saleen twin-screw kit that 16,000 is about the limit you want to stay under. 18-20 psi on the RSX is about the limit...Obviously it would be different for your car, but I do see potential with that unit over the TVS and the M62...
Old Jan 7, 2009 | 12:54 AM
  #314
PRND3L's Avatar
YEAH!
Old Jan 7, 2009 | 12:55 AM
  #315
berto's Avatar
Hey u leave them alone
they dont got the cash or the magic touch
Old Jan 7, 2009 | 12:57 AM
  #316
obviously... rsx head greatly outflows ours. interesting thought though.
Old Jan 7, 2009 | 12:59 AM
  #317
Highrev1's Avatar
Yeah, but it still would be an improvment even to the 1200ax or even the tvs at the higher end of pressures....Just a thought...
Old Jan 7, 2009 | 01:03 AM
  #318
Witt's Avatar
As well as the 1200ax. Dont feel like a nub. Worthwhile technical information triumphs post count any day.
To be honest, a 1600 would require quite a bit of fabrication, which is why you dont see any around here. Its a bit easier to fab a home made turbo kit for close to the desired result.
I do look forward to more input about this from you though. Stick around.
Old Jan 7, 2009 | 01:05 AM
  #319
Area47's Avatar
Rent me! per hour
the only thing i forsee a problem is clearance between the manifold and the core support with the 1600 on it. plus fuel rail clearance, coolant hose. ya know. the little things
Old Jan 7, 2009 | 01:11 AM
  #320
Highrev1's Avatar
Outlet plate and inlet plate...Slight adjustments for clearances and done...Dunno, I just think if I can slap that sucker on a rsx with a m62 manifold and NO room in the engine bay, it should be pretty easy for you guys...
Old Jan 7, 2009 | 01:18 AM
  #321
matego's Avatar
Thanks guys! There is a lot of good info in this thread. I have the wife talked into allowing me to get a Harrop. I would like to meet up with Rodimus to check out his set-up.
Anyone know where to get a good deal on hardwood flooring? Thats what she gets out of the deal.
Old Jan 7, 2009 | 01:49 AM
  #322
Razor564's Avatar
Well chicken nuggets.
Old Jan 7, 2009 | 01:50 AM
  #323
Rodimus_Prime's Avatar
im around at random times during the week, weekends i always work
Old Jan 7, 2009 | 01:54 AM
  #324
matego's Avatar
This weekend I am going to Brians house (you know Brian...right?) and we are going to check the compression and do a leak-down test. If there is any doubt, I am pulling it down before the TVS.
Old Jan 7, 2009 | 02:16 AM
  #325
ah yea tommorow is my only day off till next tues
