Water Wetter in IC system???
Old 05-21-2012, 12:21 AM
volsfan92's Avatar
It's starting to get hot outside so thought this good be a good idea to put in the ic system for sc.. has anybody used water wetter or anything similar ?? And with good results ?
Old 05-21-2012, 12:26 AM
rivaladore's Avatar
When I was still supercharged I ran distilled water and water wetter during the warmer months.
Old 05-21-2012, 07:34 AM
Administrator
Administrator
Staged07SS's Avatar
The Time Attack Cobalt ran the same thing....
OP, adding water wetter to the intercooling system while you are still running a full coolant mix wont do much of anything at all. If you plan on running straight distilled water throw some in the mix.
I used to add water wetter, but after some tests with different coolant mixes, I noticed it didnt do much of anything for the intercooling system.
Old 05-21-2012, 10:56 AM
volsfan92's Avatar
Ok thanks for input
Old 05-21-2012, 02:38 PM
volsfan92's Avatar
It says on bottle u can add it to 50/50.. my mix right now is like 20% coolant and 80% water
Old 05-21-2012, 02:41 PM
I'm too JDM for you
BLAZIN07SS's Avatar
drain your IC system, fill with distilled water and some water wetter. one of the best things you can do for the system. just be sure to switch it back out in the winter
Old 05-21-2012, 02:50 PM
Administrator
Administrator
Staged07SS's Avatar
Right, you can mix it, but its intended for mixing with the engine coolant.... The intercooling system coolant will not see the same temps as engine coolant.
Now, if you run straight distilled water in your intercooling system, water wetter will help.
Like i mentioned before, the Time Attack Cobalt ran straight distilled water with water wetter.
Old 05-21-2012, 03:10 PM
haha i was about to search/make a thread on this, as i was just thinking about doing it!
either way my coolant needs to be changed so yea.
how much water wetter do you need to use? where do you even get it? its just methanol right to prevent rust?
Old 05-21-2012, 04:00 PM
Maven's Avatar
Hmmm, my intercooler doesn't use water, is something wrong my car?
Old 05-21-2012, 04:04 PM
SunburstSS's Avatar
Been doing that for two years, ran great and noticed about 10-15 degrees difference and faster recovery times.
you got a turbo syndrom ?
Old 05-22-2012, 07:18 AM
Administrator
Administrator
Staged07SS's Avatar
Yes....
Old 05-22-2012, 10:26 AM
Maven's Avatar
OK, I'll have to get some then.
Old 05-22-2012, 10:28 AM
Administrator
Administrator
Staged07SS's Avatar
Good idea
Old 05-22-2012, 10:29 AM
Old 05-22-2012, 11:03 AM
Administrator
Administrator
Staged07SS's Avatar
It tells you on the bottle
If you are going straight distilled, use the whole bottle.
Old 05-22-2012, 11:09 AM
OK so i gotta buy distilled water and where do i get the water wetter, walmart or something? autozone?
Old 05-22-2012, 11:13 AM
startingline05's Avatar
I used the whole bottle when I was still supercharged
Old 05-22-2012, 11:18 AM
rivaladore's Avatar
I got mine at autozone. I wouldn't use the whole bottle, just use what they reccommend. I think it's only a couple cap fulls
Old 05-22-2012, 11:25 AM
Administrator
Administrator
Staged07SS's Avatar
No, you can mix it with 50/50 dexcool. Follow the directions on the bottle for that.
If you plan on using straight distilled water, I recommend using the whole bottle.
Remember to switch back to a 50/50 dexcool mix for the winter months if you choose to use straight water in the summer.
Old 05-22-2012, 11:38 AM
cool. yea i'm planning on doing that, just going straight water for the summer. but its gotta be distilled right?
my buddy has a 88 firebird pushing 550 horse running 11.3's all day now... told me he jsut switched to all water and saw 10-15 degrees cooler temps so doing this!
Old 05-22-2012, 11:52 AM
Administrator
Administrator
Staged07SS's Avatar
Distilled water is best, but any clean drinkable water can be used.
Old 05-23-2012, 09:50 PM
xxxxsh4d0wxxxx's Avatar
Do not add the whole bottle. That is 100% wrong. Read the directions, it's 5 cap-fulls per every quart. It comes no-where near being the entire bottle.
On my SRT4 my IAT's are generally 7°F over ambient. Oh how I don't miss the heat-soak. Anyway, good luck. It made a decent difference when I had my SS.
Old 05-23-2012, 09:55 PM
advise's Avatar
depends on youur i/c system my system hold almost 2.5 gallons
Old 05-24-2012, 07:25 AM
Administrator
Administrator
Staged07SS's Avatar
If you run straight distilled water you can add the whole bottle.
I got that information from people who worked on the Time Attack Cobalt.
Time Attacks cooling system:
-GMR Dual Pass
-Griffin Heat Exchanger
-Opt. B
-Distilled water & 1-bottle of water wetter
Straight from a GM Engineer:
"Jeff, In all of our racing applications we use only water and water wetter. So you will be fine with the 80/20 mix. In the summer you can get slightly cooler temp using one bottle of water wetter and the rest water. be careful because this in not recommended for any temps below 32 degrees"
Good point.
If you have the stock cooling system, use only half the bottle if you plan on running straight distilled water.
Again, if you plan on mixing it with a 50/50 coolant mix follow the directions on the bottle.
turbochargedss2012
09-20-2023 12:17 PM
05-28-2022 03:47 AM
01-12-2016 12:01 AM
nathan112i
09-30-2015 07:12 PM
Slick_Nick
09-28-2015 09:15 PM
Quick Reply: Water Wetter in IC system???
