Who wants to diagnose my problem...
x2.
Did you get all the o-rings and washers back in position, all cores seated, and clean everything when you had it apart?
I'm late, nm. Glad you got it fixed.
Well guys I figured out what my problem was, it didnt have to do with the laminovas, it had to do with the fact I didnt swap over the o-rings from the stock endplate to the new one which caused the intake manifold to fill up. The best part is I cant even get the o-rings out of the stock endplate because I sold it to Raven_SS and sent it out..... grrr. Not ur fault man, all mine. So now im off to the hardware store to find some o-rings.
later
later
Last edited by ItalianJoe1; Apr 23, 2008 at 08:56 PM. Reason: Automerged Doublepost
Thanks everyone!
yeah you cant use buna oring you have to get viton or epr o-rings, they will stand up to the dexcool no problem.
The buna has a tendancy to swell, I think GM's orings on the car are a viton base, so if you can get a hold of viton you will be good. If you end up getting epr, dont get oil on them only used them on the laminova tubes
later
