who's got a zzp tensioner
i was looking at the picture on c-a website and i cant figure out if it replaces the stock tensioner arm/pulley or not
anyone????
anyone????
thank you very much that is exactly what i needed to know,
i wonder if anyone has a close up picture of it installed that would prove to be very useful to me right now.
also, how is it adjustable?
The tensioner has 3 different holes. One is for a stock sized pulley (I believe), the middle one is for a 2.7" - 3", and the last one is for a 2.6" and less. You just choose which one you need to use depending on the size of the pulley your putting on and you put the bolt/screw into that hole and your set.
what do you mean there's no way to tension it. It has 3 holes one for several different sizes. bolt your tension arm into the right hole and then use the reverse threaded bolt to pull it down, put the belt back on and then let it back up and it tensions. mine works great for my 2.6
