who's got a zzp tensioner
Old 07-08-2007, 04:40 PM
senior_brown's Avatar
i was looking at the picture on c-a website and i cant figure out if it replaces the stock tensioner arm/pulley or not
anyone????
Old 07-08-2007, 05:24 PM
DTM2188's Avatar
The ZZP adjustable tensioner replaces the stock tensioner.
Old 07-08-2007, 06:27 PM
thank you very much that is exactly what i needed to know,
i wonder if anyone has a close up picture of it installed that would prove to be very useful to me right now.
also, how is it adjustable?
Old 07-08-2007, 08:02 PM
DTM2188's Avatar
The tensioner has 3 different holes. One is for a stock sized pulley (I believe), the middle one is for a 2.7" - 3", and the last one is for a 2.6" and less. You just choose which one you need to use depending on the size of the pulley your putting on and you put the bolt/screw into that hole and your set.
Old 07-09-2007, 01:40 AM
ahh ok thanks
Old 07-09-2007, 03:13 AM
sscobaltscZ06's Avatar
So where exactly is the slipping point in needing a aftermarket tensioner? I know people with 2.9's that have no belt slip and some even with 2.8's.
Old 07-10-2007, 07:08 AM
DTM2188's Avatar
I needed it for my 2.8", but some other people didn't, its kinda hit or miss.
Old 07-10-2007, 09:16 AM
invisible's Avatar
I have one but there is no way to tension it so its just collecting dust right now.
Old 07-10-2007, 03:17 PM
cbevington6's Avatar
what do you mean there's no way to tension it. It has 3 holes one for several different sizes. bolt your tension arm into the right hole and then use the reverse threaded bolt to pull it down, put the belt back on and then let it back up and it tensions. mine works great for my 2.6
Old 07-10-2007, 03:18 PM
SilverBalt13's Avatar
If you going to get a zzp product. Get it from zzp. Its cheaper. Oh I also have the tensioner and it works great.
Old 07-10-2007, 05:50 PM
DTM2188's Avatar
^^Thats true. ZZP is my favorite supporting vendor on here, they got the best customer service and great quality in their products.
05-28-2022 03:47 AM
DarrenGC
12-24-2021 01:55 PM
10-20-2015 09:56 PM
no_ss
10-18-2015 11:58 PM
justinchinn
10-02-2015 12:18 PM
Quick Reply: who's got a zzp tensioner
