ZZP Downpipe w/cat
Old Aug 1, 2007 | 02:03 PM
  #76
elecblue06's Avatar
Originally Posted by RedEcotecSS
LMFAO. Some life-less **** neg repped me.. Check this **** out;
ZZP Downpipe w/cat ...08-01-2007 10:41 AM.. Far from a pimp my friend.
lol they're just jealous because they probably paid more for their dp/header combo and got the same gains
Old Aug 2, 2007 | 12:17 AM
  #77
Doc's Avatar
Doc
Originally Posted by 2fastSS
hey doc did you go with catless or with a cat??? as you know i have the corsa cat back
I have both, currently, I am catless
Old Aug 5, 2007 | 07:33 PM
  #78
Ratchet104's Avatar
Originally Posted by Doc
Actually, the rear O2 sensor has nothing to do with the AFR. The only reason the rear O2 sensor is there is to verify the cat is working and the temp it is working. If the cat gets hot, the engine dumps fuel in order to cool things in the engine. As far as reprograming the rear O2 sensor, I don't think there is a way to change the value in HPTuners.
And changing the spark plugs won't make the code go away....turning it off makes that happen.
I didnt say the rear O2 sensor had anything to do with AFR. I was stating HOW an O2 sensor works. The rear O2 sensor reads the exhaust gas the exact same way the pre-cat O2 sensor does. only difference is the ECU wants to read a constant signal from the post-cat and a fluctuating signal from the pre-cat.
And I didn't say reprogram the O2 sensor value, I said shut it off. As for the spark plugs, that was just a theory. I figured it wouldn't hurt trying.
Yea I also got neg rep " ZZP Downpipe w/cat 07-31-2007 09:32 PM you have no idea do you..?? lol "
I guess I'm in the wrong line of work then...Hope he doesn't tell my boss I know how an O2 sensor works
Old Aug 5, 2007 | 09:08 PM
  #79
Toyotech's Avatar
if ya need a sound clip... have a sound clip for zzp w/ cat/gmpp.
also...wouldn't use bolts zzp bolts. ended up getting new studs/nuts from gm for bout 13 bucks.
Old Aug 6, 2007 | 01:48 PM
  #80
Doc's Avatar
Doc
don't blame me for your negative rep... I only give them to the red box army guys.
I'm not going to split hairs...
Did I say anything incorrect in the last post..??
Old Aug 7, 2007 | 01:22 PM
  #81
Jimmys2007CobaltSS/C's Avatar
would i have to change anything with the s/c setup...cause im planning on buying the zzp header and d/p
how much whp gain with a cai, megan catback, zzp header/dp w/high flow cat?
anybody
Old Aug 7, 2007 | 01:27 PM
  #82
chevysalesman614's Avatar
i dont know about gains on the ss n/a, but i can tell you, that whatever you buy, you wont have to change it out when you s/c your car. all the exhaust stuff will be fine. your intake (if you have one) may not fit anymore, but i'm not 100% sure.
had you decided to go turbo, none of your exhaust components would be compatible.
Old Aug 7, 2007 | 01:30 PM
  #83
i was till the 2.4 s/c finally was tested and work and its alot cheaper than turbo ...and boost is boost
Old Aug 7, 2007 | 01:48 PM
  #84
elecblue06's Avatar
does anyone have sound clips with the zzp combo yet??
Old Sep 9, 2007 | 12:42 AM
  #85
anthonyS88's Avatar
how many people have thrown a cel after the dp install
Old Sep 9, 2007 | 12:44 AM
  #86
M-Dub's Avatar
Roll on down here Wallas, I have the ZZP 3" to 2.5" d/p with cat! I'll let ya roll in it I love it and haven't even thrown a CEL from it yet!
Old Sep 9, 2007 | 12:54 AM
  #87
Asphalt Assault's Avatar
Originally Posted by chevysalesman614
thanks for the rep.
notice that mine has 2 bolt holes at the top.. for an aftermarket header.. i think the other one is for the stock manifold. they are not compatible.
just thought you should know
What appears to be is not so my friend. these are after market headers alright from ZZP but are two totally different products. take a closer look.
Originally Posted by Rangerondubz
Awesome piece, loving the quality of this piece, here is some pictures of my 3" DP I bought from them:
Your two hole collector is for a mid length ZZP header.
the other header is longer and will bolt up to factory header but also there is a shorty header made by ZZP. but this product is no longer available I have been told.
A friend of mine has the mid length and I bought from ZZP just early spring and have the shorty. I have seen both, installed mine and assisted with problems installing the other (problems not completely a Problem with ZZP). other than ZZP needs to ship stronger bolts with the product, everything else is top notch.
Old Sep 9, 2007 | 12:56 AM
  #88
M-Dub's Avatar
Yes the 3 hole version is for boltin to the stock manifold, or their shorty manifold! That is the version I have... and it' going with my custom ported manifold!
  #89
2fastSS's Avatar
I put on my downpipe 2.5 with cat yesterday car sounds mean..I love it...Its just a little bit louder and it actually has a nicer deeper tone to it....My mods are gmpp manifold, corsa catback and zzp downpipe w/cat also stage 2 and so forth... Your car will sound different and i personally love it... My cat is still breaking in you can smell it but other than that no problems with this setup at all...
I thought that my downpipe wasnt going to fit because i had my corsa welded on, and i thought the downpipe wouldnt fit it looked like it was half an inch off but tourqing it and wiggling it around it finally fit and no exhaust leaks at all
Old Sep 9, 2007 | 01:02 AM
  #90
M-Dub's Avatar
I want a new muffler I got the Magnaflow RACE series muffler, and albeit the exhaust tone is deep but it's Fawkin' LOUD!
Old Sep 9, 2007 | 03:21 AM
  #91
SSBOOST's Avatar
Dammit, need sound clip!
Old Sep 9, 2007 | 03:25 AM
  #92
M-Dub's Avatar
I'll try and get one....
Old Sep 9, 2007 | 12:06 PM
  #93
My 3" ZZP exhaust gets an addition. Full 3" exhaust tomorrow morning...LOL I just cant wait. if you think that will be loud you should try a hole in the exhaust pipe just after the resonator. a hanger ripped out and **** that is like having a cutout. it is stupid loud. my new 3" will be quiet in comparison. if that is too loud than I know what will get changed next to quieten it down but sacrifice HP.
Old Sep 9, 2007 | 12:17 PM
  #94
anybodys else engine light comes on and off with the zzp header/dp ...and notice shittty performance
Old Sep 9, 2007 | 12:47 PM
  #95
Uhmmmm not here but I notice your a 2.4. are you catless? if so you need HPTUners.
do you have PO code for that CEL?
Old Sep 9, 2007 | 02:59 PM
  #96
SSBOOST's Avatar
do NOT go catless, it will **** with your emissions if they check for the cat and it has been reported for low end torque loss. Just put it on or get a HF cat.
Old Sep 9, 2007 | 03:56 PM
  #97
RedEcotecSS's Avatar
i got a CEL, P0420, cat problems. Going to get someone to HPT it for me. Other than that, i love the set up.
Old Sep 9, 2007 | 04:09 PM
  #98
sensesfail99's Avatar
for everyone running stg2, gmpp sports exhaust, the zzp dp with cat and gm honed manifold.... is it alright for daily driving? This is my only car for now and I want to do all that, but if its going to make it at all unreliable, im going to wait til i get another ride.
Old Sep 9, 2007 | 04:13 PM
  #99
i have the ZZP header/DP with gmpp sport exhaust and GM stage 2 w/ 2.9 pulley and my car runs great
Old Sep 9, 2007 | 04:17 PM
  #100
thanks, I think im going to run this setup : stg 2, gmpp sports exhaust, gm honed manifold, zzp dp with cat and eventually switch out my stg 2 pulley for the 2.9
