2.2 SC Thread
Old Apr 9, 2010 | 02:52 PM
  #151
Jn2's Avatar
Jn2
wait i have my cobalt supercharged and its a 2.2 ls, can we add me to the list?
proof?
Old Apr 9, 2010 | 03:10 PM
  #152
redcobalt07's Avatar
ugh yeah hold on
Old Apr 9, 2010 | 03:15 PM
  #153
stenguyen1's Avatar
wat you don't believe him jn2? lol
Old Apr 11, 2010 | 02:11 AM
  #154
ipwncivics's Avatar
hey now play nice
Old Apr 11, 2010 | 05:26 AM
  #155
YzRider452's Avatar
Originally Posted by Illini_06SS
Installed my transmission cooler last night... Took me about an 10 minutes to disassemble the front end (I'm getting good at that ), an hour to install, 20 minutes to look for the F*CKING HOSE CLAMP that somehow ended up inside my freezer , and then 20 minutes to reassemble the front end...
Figured that I'd post this here... Here's how you wire up your 6-pin TB harness to the 8-pin pigtail.
SICK! someone figured that out. Now i gotta convince my buddy to supercharge his.
Old Apr 13, 2010 | 02:47 AM
  #156
ryansalazan's Avatar
hey im a 2.2 sc! add me lol fonzi you know i am too! haha you helped me out especially with the wiring for the throttle body haha
Old Apr 16, 2010 | 10:17 AM
  #157
ipwncivics's Avatar
anyone going to use 2 ecms, keep one stock and one for the tune in case they want to "go back to stock" later for trade in?
Old Apr 16, 2010 | 11:45 AM
  #158
Illini_06SS's Avatar
No need for two pcms. Just reflash the one back to stock. Why have a couple hundred dollar part just lying around? That kind of thing is only useful for LNF guys who want to try to keep their warranty.
Old Apr 16, 2010 | 03:56 PM
  #159
dragonkingg5's Avatar
yeah just reflash it back. when i get trifectas software, im going to see if he can grab me a G5 stock tune unless i know someone who has a g5 and i'll just make a tune and keep it saved on laptop and in the future if i trade in, i'll just flash it. cant use the tune i have now cause its already a trifecta tune.
Old Apr 16, 2010 | 04:02 PM
  #160
USMCFieldMP's Avatar
Rattlesnake Race Shop
Sig Thief.
Old Apr 16, 2010 | 04:15 PM
  #161
my supercharger goes on my 2.2 april 30
Old Apr 16, 2010 | 06:22 PM
  #162
ipwncivics's Avatar
awesome, i need those same two parts as you, dang national backorder
Old Apr 20, 2010 | 03:47 PM
  #163
ipwncivics's Avatar
Sig Thief.
is that so, well take a look now
Old Apr 22, 2010 | 03:37 PM
  #164
ipwncivics's Avatar
Old Apr 23, 2010 | 08:27 AM
  #165
so how much boost do you think i will be putting down for a 3" pulley? i want to play with safe boost but nothing like 6 psi. i was hoping for around 12 psi. my g5 will be my daily driver, dont wanna put to much pressure on it.
Old Apr 23, 2010 | 09:24 AM
  #166
stenguyen1's Avatar
you will polly see like 12 psi or so on a 3 inch pulley. your car should be able to handle that kind of power easiely
Old Apr 25, 2010 | 01:08 PM
  #167
Gene Culley's Avatar
Talking
I believe I had 12 PSI on 3.0 pulley. I changed to 2.9 and am now at 15 to 15.5 PSI and clutch is not taking it. Installing SPEC stage 2+ this week, then will probably drop to 2.8.
Old Apr 25, 2010 | 03:23 PM
  #168
I think 12 is good. If I lived in a more open area, be more.
Vince sent out my cable and going to email me my tune. Gotta buy a upper radiator hose then got all parts for sc
Old Apr 26, 2010 | 08:59 AM
  #169
12 psi on a 3.0 is what get as well, but I'm an LE5 so dunno if that would make a difference.
Old Apr 26, 2010 | 03:31 PM
  #170
well from what zzp said, idk if it refers to their zzp SC kit itself or in general, they said 2.2s make one psi more than 2.4s but 12 psi is what i want so ima stick with the pulley. thanks for info
Old Apr 26, 2010 | 03:48 PM
  #171
stenguyen1's Avatar
hey guys for the 2.4 injectors and throttle body do i need to do some soldering and swapping wires? cuz i am gonna help a guy out put a sc on his 2.4 cobalt.
also is there anything else i need to do with wiring? can i use the 2.4 tb? and will it bolt on the sc?
i know how to install everything else. like intake manifold, ic pump bracket and pump, idler, tensioner, intake, h/e, alternator bracket, so is there anything else?
Old Apr 27, 2010 | 10:41 AM
  #172
Fonzi1289's Avatar
Yeah u can use it.. It wont bolt up so u have to make some kind of adapter. ANd U have to rewire.. i think its in Becks How to somewhere..?
Old Apr 27, 2010 | 12:44 PM
  #173
stenguyen1's Avatar
yea i saw it just need to switch some wires. i had to do it with my 2.2 so its been over a year so i was just wondering if i had to do anything else. but i think i got it now. my memories are coming back
Old May 3, 2010 | 10:16 PM
  #174
ipwncivics's Avatar
Old May 4, 2010 | 09:34 AM
  #175
Just buy a set of EV6 60 lbs injectors. They're plug and play and fairly inexpensive compared to what people are charging for stage 2 injectors and harness (only $160)...
