200whp N/A?
Old Oct 7, 2010 | 08:38 PM
  #101
Spanky's Monkey's Avatar
that vid don't work for me got a link? and i've witnessed a nitrous explosion and it happened for reason you couldn't even begin to imagine.
  #102
BigRyanJackson's Avatar
Originally Posted by Spanky's Monkey
what are you doing for fuel? your looking at what 110 octane with that compression? maybe alcohol?
14.5:1?.....you can run 93 octane no problem.....
Old Oct 7, 2010 | 08:42 PM
  #103
Originally Posted by LEXXONE74
...What ever man, You Probably don't or never had a 2.2L as Moded as mine so you wouldn't be able to tell till you met me anyways.
i love that comment, but on a side note i ran 14.9 in the quarter the slips posted somewhere around here.
Old Oct 7, 2010 | 08:51 PM
  #104
i was doing some reseach on the subject and with the uber high redline required for such a build you will not see **** for serious power on the street without good fuel that will not detonate under those pressures. 93 octane won't cut it, yes you can use it but you will be pulling back and robbing the setup of power. in which case the cost to fund such a project wouldn't be worth it. and you sure as **** wouldn''t be redlining at 8 or 9 grand on 93 with a 14.5:1. i was looking at going around 12:1 give or take and found it was gonna be a pain in the ass with this little 4banger.
Old Oct 7, 2010 | 11:07 PM
  #105
dandaman15's Avatar
If your building the block and only shooting for 215whp that is failure. You can almost get that without putting different internals in. The biggest restriction is in the head, if you get it ported you can easily see 200hp. I think with built engine you should be aiming more for 250whp at the least. Hell if you made it a 2.0 so the Bore x Stroke was even you could rev it to close to 8,500rpm. People have to understand if you build N/A all the power is going to be at the top end, that how it is with any N/A engine.
Old Oct 7, 2010 | 11:19 PM
  #106
DillySS's Avatar
After years of this type of discussion on my old SVT Forum we came to the conclusion that be as it may a person will eventually chose a poor route. We had only a couple of 2.0l SVT's get to the 200hp mark. They ran OK and people spend 8 - 10k more than they needed too. So spend way to much to do something you will eventually replace. I would say that when you go to get rid of the vehicle, Good Luck.
Or instead, go turbo, kick everyone else's ass, save more money and buy something useful like a Money Market or Mutual Fund that will pay off when your 80 and you always wanted that 1993 Mustang Cobra R. Well, maybe not your dream but I learned the hard way.
Old Oct 11, 2010 | 01:31 PM
  #107
kissrocker52's Avatar
where did you buys your cams from
Old Oct 13, 2010 | 07:36 PM
  #108
NWAE Cobalt's Avatar
this thread is full of 2 things...fail...and those giving good advice...no one on the fail side is listening :P
on the other hand...hitting 200whp isnat as hard as some think...but its neither cheep nor easy to do.
my goal: 275 whp...yes it wont be cheap...but it will be doable (and on street gas )
its going to involve custom pistons, rods, sleeves, ported/ polished head, custom intake mani, etc...but it will be awesome...if nothing more then to have something I built and can enjoy. I have thought many times how nice and cheep it would be just to boost...but that would be too easy and no fun :P
Old Oct 13, 2010 | 07:40 PM
  #109
troyss's Avatar
Well it's easiet said then done so don't say your going to get 275hp na unless you did so already...
Old Oct 14, 2010 | 08:38 PM
  #110
wow, arent you the big man on campus.
i think of all the n/a builds out right now, i am one of 2 that can list what their plans and goals are and people will stop acting like they are 2 yrs old when they read it...
so...grow up
Old Oct 14, 2010 | 08:43 PM
  #111
HunterKiller89's Avatar
Originally Posted by tru2nrtt777
Higher compression pistons, ported head, stage 3 cams, adjustable cam gears, full bolt ons, tune... that should put you damn close to your goal with a sexy lope idle.
this, and rev it out to 7500 or so. So a valve train is needed as well. I wouldnt be surprised to see 225whp with all of this done.
its not a tough goal to reach at all, just an expensive one.
(its especially easy if you're game for using E85 full time. Then you can really go crazy with CR)
Old Oct 14, 2010 | 08:58 PM
  #112
dandaman15's Avatar
Thats pretty much a whole engine rebuild. If that was my engine and I got 225whp with all that done I would not be happy. I think depending how high your compression is, how well the head is ported, and your valve train upgrade, you could be close to 250whp. Probably sound sick as hell too. I want to see one of these motors rev to 8K, but Im not sure if its possible with this long of a stroke in the engine. You would definitely need new connecting rods.
Old Oct 15, 2010 | 12:31 AM
  #113
it is poss, you would just need to remove the balance shafts
and n/a engines sound awesome
and you should see way more then that...
Old Oct 15, 2010 | 05:16 AM
  #114
you have high expectations for 2.2 liters. i say 210-250whp depending on how aggressive the port job is, the cams are, the CR is, and the tune. There are plenty of LSJs that have revved to 8kRPM. Theres some youtube videos out there too. LSJ can do it with shafts and springs (though a cam is needed to make any use of this). its not pricey.
Old Oct 15, 2010 | 07:59 AM
  #115
bargi's Avatar
Only read the fist page so sorry if someone has posted already.
Check out vx220.org.uk, there's 2 people who are pulling about 235 bhp and running 8000 rpm using ITBs (vockey and Fab VX) on the 2.2
YouTube - techieboy999's Channel
Lots of talk about this but to summarize (applies for up to about 250BHP)
Supercharge - Relatively easy to, loads of low down torque and relatively inexpensive
ITB's - Fantastic sound, power comes in at the top end, but it's a lot more effort and money
Turbocharge - Not really an option with VX with 2.2 as you need to do some cutting of the body, just better off buying a factory 2.0 turbo
You're looking a lot more money to do ITBs but if you want to be an unique and do NA style it's the way to go. SC/TC is cheaper and gets you the power with less effort.
bit of a summary of what the guys have done...
webcon itb kit
full 2.5" exhaust
ported head
+1mm valves
double valve springs
CompCam stage 2 camshafts
balancer delete
Eagle steel rods
TTV lightened flywheel
mapping
Old Oct 15, 2010 | 08:11 AM
  #116
dandaman15's Avatar
webcon itb kit
full 2.5" exhaust
ported head
+1mm valves
balancer delete
Eagle steel rods
mapping
I brought up ITB's in the thread earlier, but since this car has electric throttle body it would cost way more than its worth to get it running and working properly.
Old Oct 15, 2010 | 08:35 AM
  #117
bargi's Avatar
Ahhh, the VX has one as well but the Lotus cars (who made it) didn't so it's a relatively easy swap out with their bits.
Old Oct 15, 2010 | 09:10 AM
  #118
dandaman15's Avatar
Ah I see now. That kit looks so nice!
Alpha Turnkey kits
Old Oct 15, 2010 | 01:38 PM
  #119
one of the guys who built an NA 2.2 for their vauxhall is on this board. I think his name is alanoo or something like that? He posted a build thread
Old Oct 15, 2010 | 01:44 PM
  #120
alanoo's Avatar
Neither I nor Vocky with its ITB's got 200 whp
We both spent more than 10.000€ (that's 14.000$ on the current rate) on our engines.
8k rpm is not a problem by the way
Old Oct 15, 2010 | 02:58 PM
  #121
aww, man. thats disappointing. I remember following your build. You had quite a sturdy build going there. Maybe the cams werent aggressive enough? or not enough CR? I cant remember the specifics after all this time
Old Oct 15, 2010 | 03:06 PM
  #122
alanoo's Avatar
Honestly, all my engine internals are OK for something around 245 hp (around 215 whp I guess),
The problem is with the intake and even more with the exhaust.
If you go the N/A way, focus on making extreme exhaust ports, with a state of the art 4/2/1 with 1"7/8 primaries, the rest will follow.
Stage 3 comp cams are more than enough to get 200whp if you can get enough air in AND out of the engine.
Old Oct 15, 2010 | 03:37 PM
  #123
well, im going the N/A way, but i kinda upped my displacement a bit. haha.
Ever plan on porting your head more and working on the exhaust? or is that project done with?
Old Oct 15, 2010 | 04:17 PM
  #124
alanoo's Avatar
Yep, displacement is really the easy and sure way to make results. If I had to redo it from scratch, I'll either start with a 2.4 crank or go 88mm pistons with the 2.2 crank.
For the exhausts ports, I'll port mine like the BTCC 2.0l 280hp engines did
Old Oct 15, 2010 | 06:52 PM
  #125
WOW! thats a HUGE port job lol,
i would kill for an ITB setup....someday :P
