Drumrush's build thread
Old Dec 6, 2011 | 12:03 AM
  #426
drumrush's Avatar
it appears that way
Old Dec 9, 2011 | 07:41 AM
  #427
heathkidder's Avatar
hey did you get any bolt ons with the sc build .... header/dp/exhaust???
reason i ask is im tryin to get a zzp dp catted but there options are o2 bung for wideband or o2 bung for 2.2 wouldnt i need both or no?
Old Dec 9, 2011 | 09:42 AM
  #428
drumrush's Avatar
In the additional comments area say you need one for the 2.2 and wideband. And I have a full header back exhaust, and recommend one if your going smaller than a stock pulley lol
Old Dec 9, 2011 | 02:16 PM
  #429
drumrush's Avatar
I stopped at a red light on my way to work and the idle started dipping and then it stalled on me. it started right back up and didnt do it again. any ideas? my tensioner has a lot of play in it and I think that might be the problem, it rattles quite a bit
Old Dec 9, 2011 | 03:57 PM
  #430
So i need wideband and another o2 bung in the dp
Old Dec 9, 2011 | 08:43 PM
  #431
drumrush's Avatar
Bump for answer
Old Dec 9, 2011 | 09:55 PM
  #432
vash90909's Avatar
no idea, mine has been having a strange idle issue whenever i give it gas and then left off....did it when it was new too! Dealership couldn't figure it out either. lol
Old Dec 9, 2011 | 10:15 PM
  #433
drumrush's Avatar
it picks right back up when i give it gas, but the strange idle is just confusing me, because it only does it about 1/20 stops
Old Dec 10, 2011 | 06:40 AM
  #434
vash90909's Avatar
Watch your afrwhen it happens. Mine dips down to 10.1 for a split second when it starts to happen. Then mine will do a roller coaster up and down till it hits smooth idle. It isn't drastic but the rpms do go from 600-1200 and then the end numbers narrow as it hits idle. I think its something with the tune personally.
Old Dec 10, 2011 | 08:54 AM
  #435
drumrush's Avatar
Do you have 60's or 42's?
Old Dec 10, 2011 | 09:28 AM
  #436
05Slowline's Avatar
Originally Posted by heathkidder
Any1 no wat the diff is between alternator bracket and alternator spacer?And why the zzp kit doesnt need a tensioner it says to use stock one
rofl
whos tuning you
Old Dec 10, 2011 | 11:14 AM
  #437
huckernage's Avatar
intake leak it can be
Old Dec 10, 2011 | 12:39 PM
  #438
drumrush's Avatar
Originally Posted by 05Slowline
rofl
whos tuning you
vince. i know its not a vacuum leak because it would do it more often, and im wondering if the 60's could be causing it because ive been hearing a lot about them causing a weird idle
Old Dec 10, 2011 | 02:56 PM
  #439
07cobaltguy's Avatar
I never had weird idle with 60's or my 80's. it idled fine everytime.
Old Dec 11, 2011 | 10:17 PM
  #440
nhanson's Avatar
in your gauge cluster thread you said you pegged 140?
details?
Old Dec 11, 2011 | 10:20 PM
  #441
05Slowline's Avatar
ouch, hope you catch him on a good day lol.
i had the 42's on my s/c setup and it idled like stock....80s now and they do idle a tad worse, my tunes not done though. you just need to get on him about it.
Old Dec 11, 2011 | 10:37 PM
  #442
drumrush's Avatar
details?
Haha I was just ****** around, I've never gone above 120 because thats all my tires are rated to right now. And I'm pretty sure I can't go much faster than that due to my shitty final drive ratio on my automatic. I would like another boosted auto to chime in and give me a max speed
Old Dec 11, 2011 | 10:48 PM
  #443
nhanson's Avatar
i did 133 mph (topped) with full bolt ons...and im auto.
so im guessing we could do 150 at least
but i know what you mean about our 4th gear
Old Dec 11, 2011 | 10:53 PM
  #444
drumrush's Avatar
I know how fast I can go as far as power is concerned, but I dont know how fast our max speed is at 6.5k rpms in 4th gear
Old Dec 11, 2011 | 11:09 PM
  #445
nhanson's Avatar
Top Speed Calculator
that said 189 mph
195/60-15 is my tire size right now
Old Dec 11, 2011 | 11:21 PM
  #446
drumrush's Avatar
uhh i dont think that is correct
Old Dec 11, 2011 | 11:32 PM
  #447
drumrush's Avatar
i just entered in all my **** and it says 196
just seems too high
Old Dec 11, 2011 | 11:34 PM
  #448
drumrush's Avatar
i just used another one and it says 133.76mph, seems much more accurate
Old Dec 12, 2011 | 07:28 AM
  #449
nhanson's Avatar
i did 133 with bolts ons and was only at 4500ish RPM
Old Dec 12, 2011 | 10:11 AM
  #450
vash90909's Avatar
My problem is not a intake leak. This happened new, with a 2.4 Mani, and now supercharged. LOL it isn't all the time so I've injored it. I'm running 42s, had 60s on but the afr was to rich at idle for me and I wasn't hitting peak with 42s so I figured y go bigger if 42 are fine. If I do a washer fluid tank swap and get an intake, that may be enough to motivate me to swap all the pulleys to go 6rib and get the 2.8 I so desire. Running a 3.1 is boring, LOL should of just went Turbo...to late now
