Drumrush's build thread
Old Nov 27, 2011 | 12:02 AM
  #351
drumrush's Avatar
fixed
Old Nov 27, 2011 | 01:37 AM
  #352
drumrush's Avatar
Whats the typical vacuum at idle for all you 2.2 sc guys?
Old Nov 27, 2011 | 02:08 AM
  #353
1LowLS's Avatar
20 in/hg is what im at idle.
Old Nov 27, 2011 | 02:31 AM
  #354
drumrush's Avatar
Mine was reading about 13. I might have a vacuum leak then
Old Nov 27, 2011 | 09:18 AM
  #355
huckernage's Avatar
Originally Posted by drumrush
fixed
what did you fixed
Old Nov 27, 2011 | 12:54 PM
  #356
drumrush's Avatar
i had my tb wired wrong. i looked at the pinout diagram backwards, so everything was fucked up. but heres the end result
does anyone know if vince can turn off traction control?
Old Nov 27, 2011 | 01:29 PM
  #357
1LowLS's Avatar
if you drop it to I and L traction control turns off
Old Nov 27, 2011 | 01:44 PM
  #358
c1_c1rca's Avatar
traction control ftl lol happy i dont have it my car torque steers like a mo fo tho
Old Nov 29, 2011 | 12:30 PM
  #359
nhanson's Avatar
"Max Torque" on the left MUST be maxed (6042 i think)
we combed the whole tune and finally changed this and that was it. i can burn through first and have it shift to 2nd without shut down.
Old Nov 29, 2011 | 12:40 PM
  #360
drumrush's Avatar
so i can tell vince that and he would know what im talking about?
Old Nov 30, 2011 | 02:09 AM
  #361
nhanson's Avatar
i would think he would see similar things on HPT
Old Nov 30, 2011 | 11:34 AM
  #362
heathkidder's Avatar
Any pics of the build
Old Nov 30, 2011 | 11:52 AM
  #363
drumrush's Avatar
No, I was in too much of a hurry
Old Nov 30, 2011 | 12:14 PM
  #364
Im gonna need help doin mine lol
Old Nov 30, 2011 | 12:23 PM
  #365
nhanson's Avatar
just leave a weekend for it...not too hard
Old Nov 30, 2011 | 12:31 PM
  #366
drumrush's Avatar
yeah it really wasnt hard at all. just time consuming. i had mine done after 12 hours of work, but i had a few days of downtime waiting on a part.
Old Nov 30, 2011 | 12:34 PM
  #367
Well my car is sitting all winter so thats why i decided to do some work to it mainly need to find more info on wiring harness and sensors
Old Nov 30, 2011 | 12:36 PM
  #368
drumrush's Avatar
i just used my stock map sensor, and the only thing that needs rewiring is the tb. and theres plenty of good diagrams on it
Old Nov 30, 2011 | 01:08 PM
  #369
Wat bout injectors just cut off the ends and splice to my stock harness
Old Nov 30, 2011 | 01:11 PM
  #370
drumrush's Avatar
yes. on each injector there are 2 wires, and one wire is the same color on all 4 injectors. mine was pink for example. make sure you solder the wires together that are the same color on all 4 on both the harness and the injectors themselves. make sense?
Old Nov 30, 2011 | 02:10 PM
  #371
1LowLS's Avatar
Or just order injectors with a EV6 plug.It'll use your factory harness with no rewiring needed,
Old Nov 30, 2011 | 03:23 PM
  #372
IonNinja's Avatar
this ^^^
ZZP sells 60# injectors with EV6 connectors that are plug and play into your stock harness. The less **** you have to modify the less potential you will have for problems when everything is back together.
Old Nov 30, 2011 | 03:50 PM
  #373
I wany 42 thou do they sell them plug n play
Old Nov 30, 2011 | 03:52 PM
  #374
nhanson's Avatar
IMO just get 60s.
Guy that just did S/C swap on his 2.2 is running 90 something % injector duty already. not sure if its 3.0 or 2.9 pulley.
Old Nov 30, 2011 | 04:08 PM
  #375
60s and a 3.0 pulley will be fine? idk the diff. between 42lbs and 60s
