IonNinja Build
Old Mar 17, 2013 | 09:39 PM
  #251
thedubsack85's Avatar
Sounds like an exhaust leak to me.. Cause if it was internal your knock sensors would be cutting power and you would have a serious problem!
Old Mar 17, 2013 | 09:40 PM
  #252
Honestly it sounds like a cracked header combine through my iPhone speaker
My thoughts too, but not sure how changing an axle would cause it, I guess it could be a coincidence
Old Mar 17, 2013 | 10:15 PM
  #253
IonNinja's Avatar
actually, I did throw a knock sensor code when I drove it today. i'll have to pull the code when I get home
Old Mar 17, 2013 | 11:49 PM
  #254
IonNinja's Avatar
It's P0326 Knock sensor 1 circuit performance
also throwing P0171 System too lean (bank 1)
As of now though the knock sensor CEL has turned off
Old Mar 18, 2013 | 01:21 AM
  #255
Pleass's Avatar
They said exhaust leak? Lmao, um no, heck no it doesnt
Old Mar 18, 2013 | 08:33 AM
  #256
huckernage's Avatar
why do you have false knock?
did you upgraded your motor and tranny mount?
Old Mar 18, 2013 | 08:37 AM
  #257
turbosmart4's Avatar
Upgraded trans mounts give u false knock?
Old Mar 19, 2013 | 12:25 PM
  #258
IonNinja's Avatar
So it's not an exhaust leak lol. Ran my OEM LSJ manifold with no downpipe and noise is still there.
The only thing left is something on the bottom end or I was even thinking a really fubar'd TOB. I just can't understand why either of those would cause the car to run lean. At idle my LTFT are like ~27
I'm lost =/
Old Mar 19, 2013 | 01:08 PM
  #259
huckernage's Avatar
yes it can
Old Mar 19, 2013 | 07:59 PM
  #260
1LowLS's Avatar
What's vacuum at,at idle?
Old Mar 20, 2013 | 11:58 AM
  #261
IonNinja's Avatar
19in. hg
Old Mar 20, 2013 | 12:22 PM
  #262
Spanky's Monkey's Avatar
is that coming from the blower? i recall some years back hearing a vid like yours and the guys blower was bad. in his case it was sold to him in that condition. i know i've been outta the game for a minute and i'm just trying to help.
Old Mar 20, 2013 | 01:38 PM
  #263
bmxracerchamp12's Avatar
no his is all motor noise. i would check out your bottom end and make sure nothing went bad down there
Old Mar 20, 2013 | 02:34 PM
  #264
1LowLS's Avatar
Seems a tad low. Mines at 20-21 ay idle. You may have a small leak causing the afr issue. As for the noise,id have to hear iit in person .
Old Mar 20, 2013 | 02:43 PM
  #265
klutch814's Avatar
i wanna say its sc related ..not sure though. thats very odd noise lol
Old Mar 20, 2013 | 03:45 PM
  #266
he took the belt off and started the car and it was there.. its got to be in the bottom end
Old Mar 20, 2013 | 10:32 PM
  #267
1LowLS's Avatar
Everything in the bottom end is new except crank main bearings.he's on stock clutch components with tons of miles.
Old Mar 20, 2013 | 10:37 PM
  #268
armcclure's Avatar
Tob?
Old Mar 20, 2013 | 10:51 PM
  #269
1LowLS's Avatar
Possibly
Old Mar 21, 2013 | 07:02 AM
  #270
i expect that. my stock clutch doesnt like the 2.8 at all. so i cant imagine his
Old Mar 21, 2013 | 02:29 PM
  #271
1LowLS's Avatar
Yea his clutch has been through tons of nitrous and now 2.7 pulley on e47
Old Mar 21, 2013 | 06:20 PM
  #272
IonNinja's Avatar
I haven't touched the car in 2 days but I'll check some other stuff today.
TOB was my second guess but other issues are throwing me off
Old Mar 22, 2013 | 05:11 AM
  #273
IonNinja's Avatar
So I threw the car on ramps and started it, then got underneath...its definitely coming from the engine FML
It sounds just like this to me
Old Mar 22, 2013 | 07:07 AM
  #274
well i would say crank bearings since its the only thing you havent really replaced. but double check and make sure those rod bearings didnt go
Old Mar 22, 2013 | 08:42 AM
  #275
usafcobalt's Avatar
Well ninja if it makes you feel any better I have a spare crank that's good and main bearings are only 30 bucks. The crank is 2.2 anything pre 07
