IonNinja Build
Old Aug 20, 2013 | 08:32 PM
  #326
1LowLS's Avatar
no the L61 does not have those ports unfortunately.
Old Aug 20, 2013 | 09:08 PM
  #327
SlowCobaltSS's Avatar
How much cash do you have into this already?
Old Aug 21, 2013 | 02:37 PM
  #328
InfraRedline's Avatar
Damn just looked through all of this. You had a tough break but looks like it will be back and better than ever soon!
Old Aug 24, 2013 | 11:24 PM
  #329
Quad-coupe07's Avatar
I wanna do a build like urs but why u using catch can? sorry for dumb question
Old Aug 25, 2013 | 12:31 AM
  #330
1LowLS's Avatar
Catch cans catch any oil vapors,thus preventing them from being pushed into the combustion chamber.Not only will oil residue coat the IM laminova cores and not allow them to cool the air charge as efficiently,when oil vapor gets in the combustion chamber,it reduces fuel octane.So any oil you can catch before it hits the intake manifold is a good thing.
Old Aug 25, 2013 | 09:02 PM
  #331
bmxracerchamp12's Avatar
Atmosphere dump lol. I need a catch can for mine
Old Aug 25, 2013 | 10:35 PM
  #332
1LowLS's Avatar
I ran a breather filter right off the valve cover and you could smell all the fumes in the car.
Old Aug 26, 2013 | 08:29 AM
  #333
i had one but it was spitting moisture and oil out of it. looked like a blown head gasket but nothing was wrong with the car... so i just took it off and havent put anything back on
Old Aug 28, 2013 | 07:55 PM
  #334
where do u mount it and hook up 2?
Old Aug 29, 2013 | 03:59 AM
  #335
1LowLS's Avatar
valve cover nipple to catch can,catch can to intake
Old Sep 3, 2013 | 10:11 PM
  #336
IonNinja's Avatar
Originally Posted by ssyellow
Nice, best of luck on the rebuild.
thanks!
Originally Posted by Tennpenn83
Jerry... if I remember, you said you're getting a new block. If that is still the case, does it come with ports for an oil cooler? Such as the fittings that go right beside the oil filter housing? If you would need an oil cooler assembly, I have one for you.
Yeah I wish it did
I wouldn't mind having an oil cooler, maybe one day
As far as what's into the engine at the moment...about $3500. It's not that expensive to supercharge and build an L61
Thanks, yeah never really got to experience the build like I should have before it went down due to me having a stock clutch but I can't wait to get everything back together again
After that I never want to do another engine build
I don't necessarily know if I even need one at this point, just trying to cover all my bases and make sure my oil is A1 at all times...don't want to spin another bearing
Old Sep 3, 2013 | 10:26 PM
  #337
IonNinja's Avatar
Got some work done on the engine today...
Removed all the timing stuff to get ready to pull the head since I'll be re-using this one...it's a bone stock head but will have Comp blower cams and ZZP valve springs
Head off...excuse my filthy garage
My Wiseco pistons after rougly 3K miles
Removed...#3 is the one that had the spun bearing
Head and new block waiting to be broken down and filled with goods
That's as far as I got. Next plan is to put my new block on the stand and break it down completely so she can get new bearings, bolts, hone and forged rods/pistons from old block
Old Sep 3, 2013 | 10:44 PM
  #338
574's Avatar
574
Get er done
Old Sep 4, 2013 | 08:39 AM
  #339
thought you had a patriot head on it?
Old Sep 4, 2013 | 03:40 PM
  #340
IonNinja's Avatar
I still have it but it needs new valve guides so I'm switching back to my stock head
Old Sep 27, 2013 | 07:24 PM
  #341
any more progress man
Old Oct 17, 2013 | 01:12 AM
  #342
IonNinja's Avatar
I got a little progress done recently
Working on my head in the living room, gf was not happy lol
Difference between OEM and ZZP 82# valve springs
Installed Viton valve seals, ZZP 82# valve springs w/ steel retainers and my Comp blower cams. Got it all assembled and ready to be torqued down.
Still need to break down my new block so I can throw my forged pistons/rods and new bearings and stuff in there.
Oh and I finally got my replacement Eagle rod (and rod bolts) for the cylinder that spun the bearing
Old Oct 17, 2013 | 01:17 AM
  #343
IonNinja's Avatar
On a side note, installing valve springs was freakin tedious because of those stupid keepers! What a pain in the ass
Old Oct 17, 2013 | 07:35 AM
  #344
about time i see progress lol
Old Oct 18, 2013 | 01:02 PM
  #345
1LowLS's Avatar
replacing anything valve related sucks ass.Doing it to mine both times was a pain in the ass.
Old Oct 20, 2013 | 11:51 AM
  #346
IonNinja's Avatar
Slow progress is better than no progress
Yeah man the ****** valves would keep getting pushed down when I was trying to compress the spring or when I was releasing it, the spring would come up at an awkward angle and pop off the keepers that I just spent 10min. lining up
Old Oct 20, 2013 | 12:57 PM
  #347
574's Avatar
574
Look at those cut hoses, no ***** given just kidding man. Nice picture of the valve springs, I may pick some up soon
Old Oct 20, 2013 | 02:07 PM
  #348
armcclure's Avatar
Nick once I throw a rod out the side of this block you can buy my 82's lol. 76's are going in the good head.
Old Oct 20, 2013 | 02:09 PM
  #349
574's Avatar
574
Haha funny I just posted that because I'm meeting a guy around 4:30 to pick up a brand new set of 82's for $200
Old Oct 20, 2013 | 06:16 PM
  #350
armcclure's Avatar
Daaang. Nice.
