IonNinja Build
Old Mar 28, 2013 | 12:50 AM
  #301
elecblue06's Avatar
Originally Posted by IonNinja
so I pulled the pan off tonight and the rod bearings in #3 were completely gone, top and bottom
had tons of broken pieces of crap at the bottom of my oil pan
tried new bearings and its a no go, there's still slop between the crank and rod so either the crank and/or rod is out of spec
jesus man that sucks
Old Mar 28, 2013 | 02:24 PM
  #302
SSfamilywagon's Avatar
Sucks Jerry
Old Mar 29, 2013 | 08:16 AM
  #303
usafcobalt's Avatar
Still got a good crank for ya
Old Mar 29, 2013 | 02:37 PM
  #304
IonNinja's Avatar
How much?
Old Mar 29, 2013 | 09:41 PM
  #305
huckernage's Avatar
i much a stock crank worth.
Old Mar 29, 2013 | 10:56 PM
  #306
usafcobalt's Avatar
50 plus shipping work?
Old Mar 31, 2013 | 02:57 PM
  #307
IonNinja's Avatar
PM'd
Old Apr 2, 2013 | 04:51 PM
  #308
CptProzak's Avatar
Yeah blow by. I have that problem. Catch can solved that though. What were you running for pcv?
Catch can?
Old May 14, 2013 | 10:37 PM
  #309
IonNinja's Avatar
Just placed an order for the following:
ZZP 82# valve springs
ARP head studs
Viton valve seals
4 injector clips
LSJ radiator hose
Baffled catch can
Cobra OEM reservoir
OEM crank bearings
OEM timing chain tensioner
Already received my KY Stage 3 clutch
Should I get new piston rings and a new head gasket? They both have about 3200 miles on them.
I also may have sourced another block instead of trying to locate a good crank for cheap
Old May 15, 2013 | 01:08 AM
  #310
1LowLS's Avatar
Get a new block dude.don't forget about cyl 2.
Old May 15, 2013 | 09:25 AM
  #311
IonNinja's Avatar
Just bought one
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160593002085
Old May 19, 2013 | 10:29 PM
  #312
IonNinja's Avatar
Since I'm getting a new block (should be getting delivered tomorrow) I decided to play it safe and get new rings. Also bought a new headgasket and main bearing bolts.
Only thing left to get is a new rod but apparently Eagle needs some info off the rod to order a new one so I've gotta tear down the old block first.
Almost there!
Old Aug 14, 2013 | 03:42 PM
  #313
IonNinja's Avatar
FINALLY got the engine pulled!
Now I just need to start tearing **** down so I can get this thing back together. It's so hot though lol, wish I could do this all in my living room.
Parts ready to go in...
Old Aug 14, 2013 | 08:56 PM
  #314
1LowLS's Avatar
bad ass!!!!!
Old Aug 14, 2013 | 10:48 PM
  #315
bmxracerchamp12's Avatar
Bring it to Michigan lol. Like 70-75 right now and getting into the 50's at night. Glad yo see you got it started though!
Old Aug 15, 2013 | 03:21 AM
  #316
IonNinja's Avatar
That would feel amazing right about now
Atleast the fun part begins now, just gotta grab some bolts to put this block on my engine stand and I can get to work.
Old Aug 15, 2013 | 07:00 AM
  #317
i cant believe you went out the top. going to be lots of fun dropping it in and getting it all lined up
Old Aug 16, 2013 | 04:14 AM
  #318
IonNinja's Avatar
I've read out the top is the quickest and easiest way to go if you don't have a lift or some sketchy way to lift your car high off the ground
I'm expecting the install to be a PITA though regardless lol. I'll worry about that though once I get everything swapped over to my new block
Old Aug 16, 2013 | 10:13 AM
  #319
armcclure's Avatar
With 4 people its not too bad.
Old Aug 16, 2013 | 02:04 PM
  #320
Tennpenn83's Avatar
I second that. I know of at least 4 people that have done this before.
Old Aug 17, 2013 | 06:30 PM
  #321
we dropped mine out the bottom. it was sketchy as hell jacking the car up high enough to get everything out lol
Old Aug 18, 2013 | 05:17 PM
  #322
IonNinja's Avatar
yeah that was my concern
plus at the time I just wanted to get the damn thing out as quickly as possible...obviously that didn't work out like I wanted it to lol
Old Aug 20, 2013 | 02:46 PM
  #323
IonNinja's Avatar
Yesterday I lifted up the engine with my cherry picker so I could throw it on the stand
Removed the clutch and flywheel (not pictured)
Finally got it on the stand
Now it's time to start breakin this bitch down
Old Aug 20, 2013 | 03:28 PM
  #324
ssyellow's Avatar
Nice, best of luck on the rebuild.
Old Aug 20, 2013 | 05:05 PM
  #325
Tennpenn83's Avatar
Jerry... if I remember, you said you're getting a new block. If that is still the case, does it come with ports for an oil cooler? Such as the fittings that go right beside the oil filter housing? If you would need an oil cooler assembly, I have one for you.
