Jn2's goes the easy route
#302
One of these weekends I go home, I think I'm gonna repaint my supercharger. Not gonna split it apart, cause I'm not gonna plug the silencer holes. Being a ported blower, I think it will be quite a bit louder anyways.
I will definitely refer to this thread as well as others.
Keep the vids/pics coming!!!
I have a few questions, but I'll just ask one at a time.
Other than the 2 studs and nuts, do the stock intake manifold bolts work for this err do I need all new one's?
#304
yeah about that bumper...ummm? lol you look like a turbo Honda
dammit I just bought bolts from bolts depot! so besides the m8x1.25 bolts you also need:
1 75mm m6x1.0 and 3 65mm m6x1.0?
#306
to bolt the intake manifold to the engine you need
m6x1.0 75mm x2
and the other stock ones will work with washer to help make up for them beig longer than needed
to bolt the alternator on
m8x1.25 130mm x3
i messed up and got m8x1.25 75mm for the intake manifold, turns out i needed m6x1.0 x_x
m6x1.0 75mm x2
m8x1.25 130mm x3
#307
I can tell you right now why the Ottp HE didnt fit in your bumper............ you mounted it wrong....
i have it on my car and had to make two 1/4" notches in the underside of the bumper and that was it.
#309
yeah i should of mounted it thru the inside of the impact bar x_x, but i decided to bolt it thru the outside bc of how easy it was to mount there
#314
ok well started tuning right earlier today around 3pm
-the fan is not turning on until 240*f
-car is overheating at every stop light(stop'd car, no fan=gets really hot)
-waiting for vince to send a re-tune
-a/f's are 11.8-12.0
#315
m6x1.0 75mm x2
m8x1.25 130mm x3
m6x1.0 75mm x2
m8x1.25 130mm x3
The powdercoater sent me a quick pic this afternoon and I will be posting it in my thread in a few minutes if anyone is interested. It is in the LAP section.
#320
So how's this coming jn2, are you still idleing ok, how's it running? Good i hope!!! I know i'm stuck on the idle issue, mine's pissing me off, lol.... . I'm uploading vids for my setup right now, will have more up tomorrow.
Do you think you could have air trapped in your cooling system causing the overheating issue.
#322
She lives!!!
She's fun to drive, but the reason she overheats is because the fan doesn't come on until 240. But the retune tomorrow should fix that.
Hopefully. But that problem probably isn't in the tune I was informed.
#323
JN2... couple of questions for you.
On the TB re-pinning and all. If our connector is a 6 pin and the LSJ is an 8 pin, how does that actual connector body fit in the LSJ TB?
I see that you mentioned in another thread you have 2 LSJ headers. I need one for my car so I can get rid of the SAI. Can you help me out with one?
#325
preston had the exact same issue afer he went turbo, with his fans no working. a few weeks later they started working just fine, it was weird, but in the mean time he wired the fans to a switch.
