Sentry's Turbo Build Thread Extravaganza!
Glad u got the rail in, so WTF is going on here? I know the other Stephen guy is having a issue with his a/f ratio, at wot he's getting 13's vince already sent him tunes but hrs still seeing 13's, this is the dude with the blower build who just finished not long ago
Sorry, haven't had any updates because car was in the shop over the weekend.
I managed to grab the problem codes off the GT Tuner.
P1682
P0230
If anyone has a haynes manual or similar that can look these codes up, that would help a lot.
P1682
P0230
p1682 is a throttle actuator control code, (throttle body issue) http://gsi.xw.gm.com/si/showDoc.do?d...&cellId=139064 I hope that link works
P1682 Acura A/T FI Signal A High Input
P1682 Chrysler Charging system voltage too low
P1682 Ford Metering oil pump failure
P1682 Honda A/T FI Signal A High Input
P1682 Mazda Metering Oil Pump Failure
P0230
Fuel Pump Primary Circuit Malfunction
more info in a sec
P0230
more info in a sec
Sorry, i'll try again, my laptop froze, po230 is a fuel pump driver or circuit malfunction. There are bullitens from gm on both of those codes also, but i have to leave in a minute for an hour or 2, i will post back when i get home if noone else comes up with it. BUT i have had the throttle contol issue in a few gm cars when i put a ecm program in the ecm that it did not like. So it may be from the tune.
DTC P1682
Circuit Description
The Throttle Actuator Control (TAC) System determines the drivers intent and then calculates the appropriate throttle response. The TAC system achieves throttle positioning by providing a pulse width modulated voltage to the TAC motor. The powertrain control module (PCM) is the control center for the TAC system. Ignition 1 voltage is supplied on 2 separate circuits to the PCM. If the PCM detects a voltage difference between the 2 circuits, DTC P1682 sets.
DTC Descriptor
This diagnostic procedure supports the following DTC:
DTC P1682 Ignition 1 Switch Circuit 2
Conditions for Running the DTC
The ignition is in Unlock, Accessory, Run, or Crank mode.
DTC P1682 runs continuously when the above condition is met.
Conditions for Setting the DTC
The ignition 1 voltage is less than 10 volts for more than 10 seconds.
Action Taken When the DTC Sets
The control module stores the DTC information into memory when the diagnostic runs and fails.
The malfunction indicator lamp (MIL) will not illuminate.
The control module records the operating conditions at the time the diagnostic fails. The control module stores this information in the Failure Records.
The driver information center, if equipped, may display a message.
Conditions for Clearing the DTC
A current DTC Last Test Failed clears when the diagnostic runs and passes.
A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other non-emission related diagnostic.
Clear the DTC with a scan tool.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
This step determines if there is voltage present to the ECM fuse.
This step determines if voltage is present at the PCM.
This step determines if the PCM ignition 1 voltage circuit is shorted to ground.
Step
Action
Values
Yes
No
Schematic Reference: Engine Controls Schematics
Connector End View Reference: Engine Controls Connector End Views or Powertrain Control Module Connector End Views
Did you perform the Diagnostic System Check - Vehicle?
Go to Step 2
Go to Diagnostic System Check - Vehicle
Observe the Freeze Frame/Failure Records for this DTC.
Turn OFF the ignition for 30 seconds.
Turn ON the ignition, with the engine OFF for 10 seconds.
Does the DTC fail this ignition?
Go to Step 3
Go to Testing for Intermittent Conditions and Poor Connections
With a test lamp connected to ground, probe both sides of the 15-amp ECM/ETC fuse.
Does the test lamp illuminate on both sides of the fuse?
Go to Step 5
Go to Step 4
Does the test lamp illuminate on one side of the fuse?
Go to Step 6
Go to Powertrain Relay Diagnosis
Turn OFF the ignition.
Disconnect the powertrain control module (PCM).
Test the ignition 1 voltage circuit that is supplied by the ECM/ETC fuse for an open or for a high resistance. Refer to Circuit Testing and Wiring Repairs .
Did you find and correct the condition?
Go to Step 9
Go to Step 7
Disconnect the PCM.
Test the ECM/ETC ignition 1 voltage circuit for a short to ground. Refer to Circuit Testing and Wiring Repairs .
Replace the fuse if necessary.
Go to Step 9
Go to Step 7
Test for an intermittent and for a poor connection at the PCM. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 9
Go to Step 8
Replace the PCM. Refer to Control Module References for replacement, setup, and programming.
Did you complete the replacement?
Go to Step 9
Clear the DTCs with a scan tool.
Start the engine.
Operate the vehicle within the Conditions for Running the DTC. You may also operate the vehicle within the conditions that you observed from the Freeze/Frame Failure Records.
Did the DTC fail this ignition?
Go to Step 2
Go to Step 10
Observe the Capture Info with a scan tool.
Are there any DTCs that have not been diagnosed?
Go to Diagnostic Trouble Code (DTC) List - Vehicle
System OK
DTC P0230
Circuit Description
The control module enables the fuel pump relay when the ignition switch is turned ON. The control module will disable the fuel pump relay within 2 seconds unless the control module detects ignition reference pulses. The control module continues to enable the fuel pump relay as long as ignition reference pulses are detected. The control module disables the fuel pump relay within 2 seconds if ignition reference pulses cease to be detected and the ignition remains ON.
The control module monitors the voltage on the fuel pump relay control circuit. If the control module detects an incorrect voltage on the fuel pump relay control circuit, a fuel pump relay control DTC sets.
DTC Descriptor
DTC P0230 Fuel Pump Relay Control Circuit
The ignition is ON.
The ignition voltage is between 11-18 volts.
DTC P0230 runs continuously once the above conditions are met.
The control module detects that the commanded state of the driver and the actual state of the control circuit do not match.
The above condition is met for more than 2 seconds.
Step
Action
Yes
No
Connector End View Reference: Powertrain Control Module Connector End Views or Engine Controls Connector End Views
Go to Step 2
Turn ON the ignition, with the engine OFF.
Command the fuel pump relay ON and OFF with a scan tool.
Listen for a click when the fuel pump relay operates. Command both the ON and OFF states. Repeat the commands as necessary.
Does the fuel pump relay turn ON and OFF with each command?
Go to Step 3
Go to Step 4
Start the engine.
Operate the vehicle within the Conditions for Running the DTC. You may also operate the vehicle within the conditions that you observed from the Freeze Frame/Failure Records.
Go to Step 4
Go to Intermittent Conditions
Remove the fuel pump relay.
Probe the control circuit of the fuel pump relay with a test lamp that is connected to a good ground. Refer to Probing Electrical Connectors .
Does the test lamp turn ON and OFF with each command?
Go to Step 5
Go to Step 6
Connect a test lamp between the control circuit of the fuel pump relay and the ground circuit of the fuel pump relay.
Go to Step 9
Go to Step 11
Does the test lamp remain illuminated with each command?
Go to Step 8
Go to Step 7
Test the control circuit of the fuel pump relay for a short to ground or for an open. Refer to Circuit Testing and Wiring Repairs .
Go to Step 14
Go to Step 10
Test the control circuit of the fuel pump relay for a short to voltage. Refer to Circuit Testing and Wiring Repairs .
Go to Step 14
Go to Step 10
Test for an intermittent and for a poor connection at the fuel pump relay. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 14
Go to Step 12
Test for an intermittent and for a poor connection at the powertrain control module (PCM). Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 14
Go to Step 13
Repair the open or high resistance in the ground circuit of the fuel pump relay. Refer to Wiring Repairs .
Did you complete the repair?
Go to Step 14
12
Replace the fuel pump relay.
Go to Step 14
13
Go to Step 14
14
Start the engine.
Go to Step 2
Go to Step 15
Have any other DTCs not been diagnosed?
System OK
DTC P1682
Circuit Description
DTC Descriptor
Test Description
Step
Action
Values
Yes
No
Go to Step 2
Go to Step 3
Go to Step 5
Go to Step 4
Go to Step 6
Go to Step 9
Go to Step 7
Disconnect the PCM.
Go to Step 9
Go to Step 7
Go to Step 9
Go to Step 8
Go to Step 9
Start the engine.
Go to Step 2
Go to Step 10
System OK
DTC P0230
Circuit Description
DTC Descriptor
The ignition is ON.
Step
Action
Yes
No
Go to Step 2
Go to Step 3
Go to Step 4
Start the engine.
Go to Step 4
Go to Step 5
Go to Step 6
Go to Step 9
Go to Step 11
Go to Step 8
Go to Step 7
Go to Step 14
Go to Step 10
Go to Step 14
Go to Step 10
Go to Step 14
Go to Step 12
Go to Step 14
Go to Step 13
Go to Step 14
12
Go to Step 14
13
Go to Step 14
14
Start the engine.
Go to Step 2
Go to Step 15
System OK
Ok, by reading those two bulletins, I know exactly what I need to do to fix it. The fuel pump relay must be toast, because by those instructions it will shut off the ignition after 2 seconds of no voltage from the relay, which is EXACTLY what's happening. After we replace that, everything should be ok.
I'll retune the pcm tomorrow after we replace the relay, but everything sounds like it's figured out.
lol
I wonder if this is big daves problem too
data loged my car and vince said its coming back i have a major vaccum leak ..but i checked every thing my next step is maybe i cracked the manifold with the last setup so. so im gonna take it off and check that . if that dosnt work i have another motor ill try replacin differnt sensors
I checked the fuel pump relay, it's good. I'm getting voltage to the fuel pump and I got fuel pressure in the rail, so that problem is resolved. The other one, for the TB I still have yet to figure out. It could be a multitude of things, hopefully my ecm isn't bricked. I got an updated tune from Trifecta and loaded it, same results. Now it's not saying I'm throwing any codes, even though I can clearly see the cel on the dash. Kinda confused at this point.
It's displaying -40 on the coolant temp, if anyone knows what that could indicate. How much is a new ecm, anyone know?
Did you try flashing back to a stock tune, then trying to start the car? I think this has to do with the tune, not saying vince doesn't know his stuff or nothing, i just think your ecm is rejecting the tune for some reason. You may have to go as far as to put your stock injectors back in and see what happens. The ecm will not display codes until it runs a test for a certain code, certain things have to happen before the ecm will even run a test, like the engine needs to run. This is just my opinion and i may be way off, but i doubt it. If you put in the stock injectors and tune and it still won't start, you may have a fried pcm.
well i did a compression check 2 day and not good .. 3 of my cylinders were all around the same and the other one was no where close to the other 3 .. also found metal chips in my intake manifold doing a leak down check in the morning to see if i can find out whats wrong and possibly putting my other motor in ,
Ok, went ahead and picked up a second E37 ECM on ebay for a reasonable price, we will see if it helps.
http://cgi.ebay.com/ebaymotors/ws/eB...m=310114393583
