Stage 3 Comp Cams....Anyone done it???
https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/turbo-grind-cams-07-2-2-a-190012/
arent u also doing a turbo build?
Just a question, if you are going to go NA all that way, why not look into a company that might make some higher compression pistons for you. If you are going to open up the engine (with stage 3 that is a must), why not see if you can get one of the companies that already make some pistons, to make some with higher compression. That would give you another bump in power, but you would also need new injectors. Just an idea, good luck with your build, I am glad to see someone going a different way from everyone else.
Bump for more input
His 180whp dyno was uncorrected.
He ran a 14.9 at 94mph..Didn't he also have mild head work done? His traps are about the same as the other 2.2's at the top of the list. That's not 190whp.
It would take alot more than a cam swap . That alone won't add close to ~50-60whp.
1. His 180 was considered fudged because his afr ratio was running too rich
2. He had a milled head thats it
3. Whoever said it was going to add 50-60whp?
Thanks for your input....Oh btw don't you think with everything I have listed plus stage 3 cams and full valvetrain rebuild 200 - 20whp would be acheivable sounds very doable to me
Most of the bolt-on 2.2's put down in the 150WHP range. Do you really expect to hit 200+whp with just cams?
Enough of his dyno talk, if he is making that much power whats up with his track times?
BTW, here is a corrected dyno of a full bolt-on, STG 1 cam's 2.2
http://i348.photobucket.com/albums/q...Stage1Cams.jpg
That's only 163whp..stage 2 won't add an additional ~20 whp..and stage 3 won't add an additional ~20+ whp. This is a tiny mild compression 2.2 not an LS1
And I never said I expected to hit 200whp it would be nice and I think that its doable and not with JUST CAMS but with....CAI, 2.4 Intake Mani, Ported 2.4 TB, Pacesetter Header, Custom Downpipe w/ Hi-Flow Cat, Custom Catback exhaust, Underdrive Pulley, Lightweigtht Alternator Pulley, Lighweight Flywheel, Stage 1/2 Clutch, Solid Motor Mount, Poly Tranny Bushings, Poly CABs, Stage 3 Cams w/ a fully redone valvetrain, and an aggresive tune.
Now if you dont have anything else better to do with your time then to come in here in nit pick and tear apart what ppl have to say and not have any constructive or helful criticism other than being an lsj or lnf nut hugging fan boy and tell me sell it and get an SS or go FI then GTFO!!!! of my thread.
Thnxkbai
Seriously though if you want to make "decent" power look into a high compression build. The bad thing is spending all that money, even if you pulled crazy numbers like 250-260whp NA it would still be slow in comparison.
exactly money and time invested in a n/a build would be worthless unless your running in some type of class with a certain motor. but these motors love f/i and new internals.. i sware it loves cams!
like the sound of that ^^^^ very encouraged as im goin for my build soon
i dont think cams would have any issues mine drives perfect with them it just shakes/lopes alot at idle.
you do realize that your not suppose to run solid lifters with a hydraulic cam right?
so as far as having to run solid lifters with the stage 3's i wouldnt do it unless the cam was a solid or billet style cam
Try driving my car in rush hour and tell me "you just have to get use to it" lol. I would rather drive my rocket in rush hour stop and go than my car in all honesty's
http://www.youtube.com/watch?v=sA9Tvhz57Dw its not a smooth idle at all.
cams are fun...but as a daily in town/ traffic driver they SUCK
