supercharged build problem
Old Dec 20, 2009 | 01:32 PM
ryansalazan's Avatar
hey guys so im still on the sc build but ive ran into a slight problem... ive got the lsj idler pulley on the way, but my problem is the fact of the belts and the pulleys... im running a 2.8 pulley on the blower and it has 5 slots for the belt to fit into, while the alternator and the crank, and the ac pump have only 4.... the lsj idler pulley, tensioner, and the blower pulley all have 5. so my question is, is there a belt that can fit four slots and is rigded on both sides? because i cant seem to find any solution to this:/ thanks for the help guys!
Old Dec 20, 2009 | 01:35 PM
*S!CC_R@c!NG_TURTL3*'s Avatar
all u have to do is cut the extra rib off the belt and ur set
Old Dec 20, 2009 | 01:38 PM
Section8cav's Avatar
you have to cut one rib of the belt, and make sure the belt sits on the ribs closes to the engine, the ones that are not used from the lsj pullies should be open the the side furthest from the engine, and the stock pulies have 5 ribs, the lsj ones have 6...so..
crank=5 ribs
ac condensor=5 ribs
idler=6ribs
tensionor=6 ribs
sc pulley=6 ribs
so cut one rib off the belt, than put the belt thru all the pullies, make sure the belt is closest to the engine, ill snap a pick of what i mean in a sec
Old Dec 20, 2009 | 01:42 PM
Jn2's Avatar
Jn2
hope this helpt explain things, i accidently postedwhile logged into section8's account :p
Old Dec 20, 2009 | 02:05 PM
haha thats fine i was thinking of this a while back but didnt want to but hey if its the only option then im all in. lol thanks guys and closest to the engine sounds good. now for the next :/ i just bought a throttle body (lsj) from the dealership so i can plant in on the blower. well i was looking into it and i found that the lsj tb socket for the plug has 8 prongs, where as my throttle body stock harness has only 6 openings? am i maybe just looking at the wrong one or do i need to get something else? thanks for all the feedback guys!
Old Dec 20, 2009 | 02:07 PM
Jn2's Avatar
Jn2
you have to make the 6 wires work for 8, so you have to splice 2 extra wire and tee off the 2 low reference ones from factory, you will need the 8 pin clip too :p i know we had to do that with interviewatruins bc he had a 07 model, not hard at all, just need a wiring diagram and im sure you can figure it out
Old Dec 20, 2009 | 02:10 PM
so by tee off you mean cut them? from the throttle body? i have a diagram from vince on how to connect them but its a 8-8 switch... mines a 6-8. i have a 2008 ls lol. if you know of any kind of diagram thatd be great! thanks man!
Old Dec 20, 2009 | 10:46 PM
Rocket's Avatar
warning you now, if you don't change the other pulleys to 6 rib you're going to have slip with the 2.8. I learned that quickly. You need the extra rib for it to catch properly.
Old Dec 20, 2009 | 11:25 PM
ya i was hoping i wouldnt hear that but thanks for the heads up tho. anywhere i can find just the pulleys and not the whole alternator and ac unit?
Old Dec 21, 2009 | 12:08 AM
scottyguy401's Avatar
Try to cut the rib off as straight as possible so your belt doesn't rip to shreds when the car is running
Old Dec 21, 2009 | 02:14 AM
what did youbise to cut it with just like regular scissors or what?
Old Dec 21, 2009 | 09:42 AM
Rocket's Avatar
We got my 6rib pulleys from MRZ
Old Dec 21, 2009 | 12:24 PM
oh ok ya didnt think of that... but its just expensive.. and you have no problems running the pullies? ive heard people having problems
Old Dec 21, 2009 | 01:26 PM
Rocket's Avatar
No, but I've cooled the **** out of my set up. I've got the dual pass, over sized heat exchanger and I'm running meth soooo... yeea.
Old Dec 21, 2009 | 01:41 PM
lol ya dont see anything wrong there. lol ive got the dual pass and oversized heat exchanger but no meth... yet... haha i was actually talking about the mrz pullies any problems with those? and your running a 2.8, hows that working for you as far as power?
Old Dec 21, 2009 | 02:41 PM
Rocket's Avatar
No problems with the MRZ. They work great. We technically didn't need to run meth in my car cuz it was running cool enough, it was more of a "just in case" back up kinda thing. If you don't have the cooling mods to support the 2.8 though they've been known to knock so if I were you I'd budget to run meth but that's just me and my OCD on keeping the car safe.
Power wise it's def got more power then the stage 2 gave it. You've also got to put the 60lbs injectors in. But with all that a good tune I think you'll be happy. I'm happy with mine. I'm not sure of power right now. I haven't had a chance to dyno it. We were debating taking it to SMG in Mass while we were down here but I just had to replace one wheel bearing and am going to do the other for good measure so we'll see what funds are like. I don't really want to say what we are expecting for power cuz half of the ***** on here will say there is no way prove it blah blah blah so until I get a dyno sheet it's staying quiet.
The only downside I have with this entire build is the transmission. The gearing is way different on the ss's which gives them a very good advantage. We're working on looking at all the options to fix this. You can either get gears and put them in the stock housing or get a custom fly wheel made and use the ss transmission. Lots of things to think about.
Old Dec 21, 2009 | 04:07 PM
Jn2's Avatar
Jn2
I've been running a 2.8" no belt slip at all...ever, u dont need to convert pullies, cavaliers run 2.8" as well with no belt slip, don't bother changing the other pulleys, u'll be fine, both me and interviewatruins ran a 2.8 with a stg2 belt fine, loads of cavys do it too, save ur money on those pullies. Meth is up to you and what ur plans are. I haven't ran it, I even ran unintercooled for a month on my 2.8, raced the car that way, still no problems...
Old Dec 21, 2009 | 06:16 PM
I'm on 2.9 and no belt slip
Old Dec 22, 2009 | 01:57 AM
ok so sounds like theres no need but then again the mrz pullies arent a waste either and i totally understand rocket about having people just start flaming about the power. but yeah im basically just doing the build for a fun project that will increase power lol. im going to get the trifecta tune as well after everything is put in, and i already bought the 60# injectors i just need to custom make the injector harness... as well as the throttle body one which i have no idea to do. except the info ive gotten from you guys thanks for everything by the way. and like i said before ive got the dual pass going as well and since we are in the winter i think ill go ahead and instead of getting meth, use the money for headers instead which would be needed despertly lol. then when spring comes around the meth cause ity gets so freaking hot over here in houston. lol. im also thinking of getting a boost controller as well though so that way i can keep the engine running safe. what psi you guys running?
thats another thing im worried about as well though... the transmission. i dont and repeat dont want that to break! i have the f23 i believe... hows that holding up for everyone?
Last edited by ryansalazan; Dec 22, 2009 at 01:57 AM. Reason: Automerged Doublepost
Old Dec 22, 2009 | 12:31 PM
stenguyen1's Avatar
yea i didn't get belt slip on a 2.8 or my 2.9.
i'm on a 2.9 right now and it still pulls hard without slipping
Old Dec 22, 2009 | 12:38 PM
Jn2's Avatar
Jn2
I'm running:
-2.8" pulley
-16psi
-stock clutch
-f23 tranny
runs good, pulls hard, my clutch does slip though, bu it DD's fine
Old Dec 22, 2009 | 12:43 PM
Rocket's Avatar
I'm not going to argue with you. Think as you will, do as you will but when your motor blows up I hope you don't post on here all pissed off wondering what happend and chances are, you are getting slip, you just don't realize it.
2.9's don't usually have a problem, it's the 2.8's and smaller. You also don't need to go to a bigger injector with the 2.9
Sounds good. I'd budget for both the meth and the pulleys, better to run a solid build then a half ass one and fix issues later down the road. JMO.
PSI I'm running 14-15 if I beat the **** out of it but that's extremely rare that I do that. For the car to easily get up and pass someone it usually does it around 7-10/12.
The tranny is holding up fine. I've had no issues what so ever with it. Sept the gearing blows. My car's been like this since July-ish and I've but 30-40,000 miles on it. Make sure you switch to synthetic oil to if you don't already run it.
Old Dec 23, 2009 | 12:14 AM
ya i already run with royal purple lol. and ya im debating the pullies better safe then sorry i guess. im getting paid a pretty fat check in a week anyways so maybe that can go. and thats very releiving to hear! about the transmission. mines a f23 and i was just hoping no one had any issues. and ya i do def plan switching out the clutch also lol. will stay on stock for a little while but it will have to change everyone says it slips. and your running 15psi on a 2.8? is that without a boost controller? cause ive heard they push out about 17psi. thanks for all of the replies by the way guys im glad to see everyones own opinions and experiences.
Old Dec 23, 2009 | 09:22 AM
Rocket's Avatar
I don't have a boost controller. The higher the PSI doesn't necessarily mean it's running at it's best. And the higher the PSI the more chance of it blowing up are. It's better to do everything you can to it with cooling, exhaust, etc and run a lower PSI. In these motors with stock internals, you really don't want to be pushing 17 psi.
My clutch lasted me about two months before I decided to change and although it did slip, it didn't NEED to be done. That being said, if you plan on going to the track every week you're probably going to have to look at changing it sooner. I went for the spec stage 2+
Old Dec 23, 2009 | 12:00 PM
Ya and see I know high boost maybe isn't the vest solution but I just don't want to blow the motor that would not be to fun. And ya I'm looking at thepolyrothelyne or something like that it's a little gasket made of a cooler metal that goes in between the manifold and the engine to help keep the iat cooler
