supercharged build problem
Old Jan 22, 2010 | 04:24 PM
  #76
Fonzi1289's Avatar
Well go to any auto store and buytis thing called a "add a fuse" or similar. It mae it so that it has its own fuse so u wont blow one of ur main fuses from overloading it.. real simple..
http://store.42draftdesigns.com/asse...-a-circuit.jpg
http://images.google.com/images?hl=e...-8&sa=N&tab=wi
look at that link from goole.
Basically u just put the fusein that u r replacing then an extra to power the pump. Then put it in where ever u took out the fuse. the =n connect ur pump to it.
  #77
rico's Avatar
get the bracket in?
Old Jan 23, 2010 | 06:44 PM
  #78
ryansalazan's Avatar
ok guys really need help quick here! am just about done with the sc build but dont know how or exactly where to mount the heat exchanger! help please! does it go in between or in fron of the radiator or what?
Old Jan 23, 2010 | 07:39 PM
  #79
Fonzi1289's Avatar
What heat exchanger?
Old Jan 23, 2010 | 08:51 PM
  #80
the stock heat exchanger? how and where does it mount
Old Jan 23, 2010 | 08:53 PM
  #81
Fonzi1289's Avatar
U will have to make ur own brakets man. And bolt it to the crashbar
Old Jan 23, 2010 | 08:59 PM
  #82
ok cool thats what i figured. did you put the heat exchanger in the very front or in between the radiator?
Old Jan 23, 2010 | 09:06 PM
  #83
Fonzi1289's Avatar
in the front of the radiator and ac condenser
Old Jan 23, 2010 | 11:25 PM
  #84
ok and i got it and now its all done i just tried starting it but when i went to hook up the battery it keeps sparking on me like theres some kind of cross wire. has anyone ran into something like this?
Old Jan 23, 2010 | 11:28 PM
  #85
Fonzi1289's Avatar
Nope?
Which r u connecting? The ground right?
Old Jan 23, 2010 | 11:34 PM
  #86
ya, but what im thinking is this, does your intake manifold somewhat touch your solenoid at all like even burr it? because i think mine does and my ground wire down where the alternator is at is still in the same bolt hole that it was bolted in when the car was made. so what im thinking is if my manifold is barely touching that solenoid and the ground is in the same place that it was earlier and its connected to the bracket which touches the manifold... thats a spark right there when i try to plug the battery back on because the circuit is com,plete. im thinking thats it because i should have done this...http://i34.photobucket.com/albums/d1...ller89/108.jpg and moved the ground to the other side where its not touching the manifold at all? but thats the only thing i can think of
Old Jan 23, 2010 | 11:38 PM
  #87
Fonzi1289's Avatar
Yeah try it.. I left mine there but turned it so that it wasnt touching anything. And what do u mean by its touching the solenoid?
Old Jan 23, 2010 | 11:40 PM
  #88
like theres a little red rubber wire that is a positive charged wire connected to the solenoid and the manifold is sitting on it
and so yours is still in the same place? because all the ground is touching is the bracket and motor. but nothing else... any other ideas maybe?
Last edited by ryansalazan; Jan 23, 2010 at 11:40 PM. Reason: Automerged Doublepost
Old Jan 23, 2010 | 11:42 PM
  #89
Fonzi1289's Avatar
Yeah i left it cause the other bolt was stripped.. and hmm
what kind of spark is it? Huge? does it keep sparking after u connected it or just when u got to touch it?
Old Jan 23, 2010 | 11:44 PM
  #90
its a pretty big spark and violent. and it sparks when i touch the prong but i did get it on and left it there but the wire just got hotter and hotter and so i took it off fast
Old Jan 23, 2010 | 11:47 PM
  #91
Fonzi1289's Avatar
Yeah something is deff connected wrong.. Did u go over ur wiring?
I didnt get this problem and am deff stumped!
Nothig else is touching the batt or cables right?
Old Jan 23, 2010 | 11:49 PM
  #92
correct everything has been wired like it was stock all connectors and everything and no nothing touching the battery wires.
Old Jan 23, 2010 | 11:52 PM
  #93
Fonzi1289's Avatar
Yeah dude i am stumped.. I would go over the wiring and make sure everything is grounded right.
And make sure nothing is touching the bat or cables.
does it get hot with the car off?
Old Jan 23, 2010 | 11:56 PM
  #94
im going to try the grounding wire and pray for the best i hope thats it! thanks man i really apprecieate the help!
Old Jan 23, 2010 | 11:59 PM
  #95
Fonzi1289's Avatar
No problem!
Yeah had mine done for a couple of days! And tuner is out till Feb 1st!
Who is tuning urs?
Old Jan 24, 2010 | 12:22 AM
  #96
well im gonna go trifecta as far as i know but hey one last question... how do you loosen the belt on the tensioner from the lsj?
Old Jan 24, 2010 | 12:27 AM
  #97
Fonzi1289's Avatar
OOOH dude u wont be able to drive for a while then. i am a trifecta dealer and they r out till feb 1st...
And oh its easy.. better if u have a buddy.. do u have the lsj engine hoist bracket attached to it or no?
Old Jan 24, 2010 | 01:05 AM
  #98
no i dont and your a trifecta dealer? lol ill just order from you then haha do you dish out the handhelds with the tune for a certain price? id like to buy the handheld as well. and no i dont have the hoist
Old Jan 24, 2010 | 01:13 AM
  #99
Fonzi1289's Avatar
Yeah just a local dealer man.. Yeah bought there dealer package and tune all for around 400.. Was worth it..'
and well u gotta get a 15 mm wrench and put it on the groove on the top of the tensioner and push down and back towards the back of the car and then slide the belt on. and i would advise ya to put something over that lil groove to avaid the metal to metal contact and to prevent from like stipping it or something
Old Jan 24, 2010 | 02:00 AM
  #100
ok thanks man that helps a ton and i didnt know you were only a dealer oops haha. and im still trying to figure out wth is wrong with the wiring! i took off the blower and manifold and all and tried it again and it still sparked!
