Too Lean
Old Jul 19, 2009 | 05:26 PM
biniecki's Avatar
Too Lean
Wondered if there are any options to fix a too lean code other than a tune. I have replaced the stock header and DP with an SS header and XTC catless pipe and now receiving this code. My only thought was possibly running higher octane but not sure if it would help.
Old Jul 19, 2009 | 05:49 PM
huckernage's Avatar
trifecta
Old Jul 19, 2009 | 07:04 PM
randizzle's Avatar
probably fix the vacuum leak.
Old Jul 19, 2009 | 07:05 PM
biniecki's Avatar
There isnt a leak to my knowledge. I checked all the lines and everything looks to be in order
Old Jul 20, 2009 | 02:00 AM
USAF1123's Avatar
Take out the battery for 10 min and put it back in. It resets the computer. If that doesn't work try unplugging the battery and filling the tank full with the highest octane you can buy and then reconnecting and running the car. If you can't get it rich enough like that, tune it.
Old Jul 20, 2009 | 02:50 PM
randizzle's Avatar
higher octane fuel doesn't make the vehicle run more rich.
Old Jul 20, 2009 | 05:03 PM
USAF1123's Avatar
Yeah but if getting too much air, upping the octane will produce a larger explosion and might counter it out. Eg.: forced induction cars need high octane fuel.
Old Jul 20, 2009 | 10:47 PM
BLKLS's Avatar
No, octane makes NO differance in lean or rich conditions.
If all you did was replace exhaust parts then you have a problem. You have a leak. Changing exhaust parts will makes NO differance inthe air coming in.
Old Jul 22, 2009 | 12:49 AM
biniecki's Avatar
Well i also have a CAI which is now more effective with a more free flowing exhaust. I think this weekend I am going to check the plugs and possibly replace if needed, clean the MAF Sensor, and replace the intake filter and see what I find out
Old Jul 23, 2009 | 03:48 PM
tjkline's Avatar
if u got rid of your cat,what is your 2nd 02 reading?
Old Jul 24, 2009 | 12:16 AM
biniecki's Avatar
Not sure what the reading is on it but it is not throwing any codes. I have a 90* extension adapter for it which works out great. There are several other catless guys that use this to prevent the o2 from throwing a code and from the sound of it, one of the only things that really works to prevent them
Old Jul 24, 2009 | 12:42 AM
weiss27md's Avatar
put your cat back in if you can, no reason to take it out
Old Jul 24, 2009 | 06:35 AM
Sentry's Avatar
I doubt that you are running lean, and if you are, it's time to check the MAF, check for intake leaks, have you recently removed your throttle body or intake manifold?
I'm betting it's just a code being thrown because of the catless downpipe, even though logically you would expect it to sense the mixture being too rich because there's no cat to filter it.
Old Jul 25, 2009 | 10:53 PM
biniecki's Avatar
Please tell me your not serious. Cats are very restrictive. Removing them increases performance and air flow. They are only there for emissions and MI has no emission laws.
I have found out what was causing the lean code on the first o2 sensor. Turns out that the place that installed the bung had a bad weld and it was leaking. Patched it up and its all good now.
turbochargedss2012
Sep 20, 2023 12:17 PM
tomj77
Oct 4, 2015 11:39 AM
DocSvensk
Sep 27, 2015 02:24 PM
ATOMbomb
Sep 11, 2015 10:48 AM
