2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
2.2 header and lsj header
Old May 10, 2010 | 08:47 AM
BlaqkBalt's Avatar
says its 3''
Old May 10, 2010 | 09:12 AM
Chuck's Avatar
Isnt the 2.4 auto stock DP 2.5 inch... Is it made alittle different than the LSJ?
Old May 10, 2010 | 09:19 AM
Staged07SS's Avatar
Administrator
Administrator
subd
Old May 22, 2010 | 07:24 AM
cobalt523's Avatar
dc sports makes one 2.5in part# chc3002 :
Old Jun 9, 2010 | 01:31 PM
souchak2112's Avatar
XTC sells 2.5''
Old Jun 9, 2010 | 01:45 PM
coopercharge's Avatar
Originally Posted by Gene Culley
Sorry, but the information here is incorrect. I know because I have the LSJ header and LSJ DP on my car. The stock 2.2 header is much smaller, and does not allow as much flow. The 2.2 header is longer and the 2.2 DP is shorter. The LSJ header is shorter, but the DP is longer. So, if you want to use LSJ DP or header, you must use both or it will not fit. But trust me when I tell you, the header is certainly smaller on the stock 2.2.
Part numbers are the exact same for the exhaust manifold unless you get the extrude honed manifold. Downpipe may be larger diameter than the 2.2 but same length and bends.
Old Jun 9, 2010 | 01:47 PM
ikeryder13's Avatar
if anyone is interested i have a stock ss/sc manifold for sale 40+shipping
Old Jul 11, 2010 | 03:43 PM
superchilired's Avatar
If you put the LSJ manifold and downpipe on your 2.2 will it cause a CEL/SES??
Old Jul 11, 2010 | 04:07 PM
05Slowline's Avatar
Originally Posted by RooTBeeR
now line those up in the other order, lsj closer to the cam and the 2.2 farther away from the cam, they are the same length, its like an optical illusion...how much longer do u think the lsj dp is than the 2.2? have you taken a measuring tape to them?
are you retarded look at where the flanges are placed. even with the 2.2 dp's flange a bit farther right on the ground it's STILL shorter let alone if the flanges were lined up correctly. so much fail in here.
so you've said twice
Last edited by 05Slowline; Jul 11, 2010 at 04:07 PM. Reason: Automerged Doublepost
Old Jul 14, 2010 | 11:02 AM
Originally Posted by BlaqkBalt
fml right.. where can i get a 2.5in dp. every place ive seen is 3in !!
Vibrant
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 28, 2015 12:51 PM
