2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
2.2 header and lsj header
Old 05-10-2010, 08:47 AM
BlaqkBalt's Avatar
says its 3''
Old 05-10-2010, 09:12 AM
Chuck's Avatar
Isnt the 2.4 auto stock DP 2.5 inch... Is it made alittle different than the LSJ?
Old 05-10-2010, 09:19 AM
Administrator
Administrator
Staged07SS's Avatar
subd
Old 05-22-2010, 07:24 AM
cobalt523's Avatar
dc sports makes one 2.5in part# chc3002 :
Old 06-09-2010, 01:31 PM
souchak2112's Avatar
XTC sells 2.5''
Old 06-09-2010, 01:45 PM
coopercharge's Avatar
Originally Posted by Gene Culley
Sorry, but the information here is incorrect. I know because I have the LSJ header and LSJ DP on my car. The stock 2.2 header is much smaller, and does not allow as much flow. The 2.2 header is longer and the 2.2 DP is shorter. The LSJ header is shorter, but the DP is longer. So, if you want to use LSJ DP or header, you must use both or it will not fit. But trust me when I tell you, the header is certainly smaller on the stock 2.2.
Part numbers are the exact same for the exhaust manifold unless you get the extrude honed manifold. Downpipe may be larger diameter than the 2.2 but same length and bends.
Old 06-09-2010, 01:47 PM
ikeryder13's Avatar
if anyone is interested i have a stock ss/sc manifold for sale 40+shipping
Old 07-11-2010, 03:43 PM
superchilired's Avatar
If you put the LSJ manifold and downpipe on your 2.2 will it cause a CEL/SES??
Old 07-11-2010, 04:07 PM
05Slowline's Avatar
Originally Posted by RooTBeeR
now line those up in the other order, lsj closer to the cam and the 2.2 farther away from the cam, they are the same length, its like an optical illusion...how much longer do u think the lsj dp is than the 2.2? have you taken a measuring tape to them?
are you retarded look at where the flanges are placed. even with the 2.2 dp's flange a bit farther right on the ground it's STILL shorter let alone if the flanges were lined up correctly. so much fail in here.
so you've said twice
Old 07-14-2010, 11:02 AM
Originally Posted by BlaqkBalt
fml right.. where can i get a 2.5in dp. every place ive seen is 3in !!
Vibrant
Supercharged06SS
12-11-2022 04:47 PM
06MetallicBalt
08-17-2021 03:40 PM
goaliemo
09-28-2015 01:37 PM
09-28-2015 12:51 PM
09-26-2015 06:44 PM
Quick Reply: 2.2 header and lsj header
