2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
bad idle issue, help!
Old Oct 21, 2012 | 12:39 PM
rcarr0327's Avatar
hey guys,
whenever i come to a stop in neutral, my car rpms bounce between really low then back up to high, it also sometimes dies making it very hard to drive around the city and whenever coming to stop lights/signs.
i cleaned my throttle body as much as a can and it helped for like a day but its back to the same issue. any other suggestions for me to check/replace/clean? thanks guys
Old Oct 21, 2012 | 01:10 PM
07cobaltguy's Avatar
Let it sit and idle and unplug the MAF. See if the car changes. If it dosent, well then there may be the issue. Id do the same to the Map as well. Sounds definately like a leak or a sensor issue. use some carb spray and spray around some areas and see if the motor changes and rule out leaks.
Old Oct 21, 2012 | 01:12 PM
Twoozofjuice's Avatar
the carb spray is sprayed while motor is on? i think i have a leak and havent found the correct way to look for it but i have a good idea on where it is.
Old Oct 21, 2012 | 01:19 PM
rcarr0327's Avatar
yea if the spray finds a leak the engine will rev higher cuz its flammable
okay, is the MAF on the manifold and map on the charge pipes?
Old Oct 21, 2012 | 01:21 PM
it sounds dangerous...lol.
mines supercharged not turbo and i think my leak is where the manifold is. like on the top side that faces the injectors...not sure if you know what im talking about. is that a safe place to try it on?
Old Oct 21, 2012 | 01:22 PM
Map is on the manifold and MAF in the Charge pipe. You can use water too the motor will bog, but with break cleaner/carb spray/maf cleaner, the engine will have a bump in rpm if theres a leak.
Old Oct 21, 2012 | 01:23 PM
nhanson's Avatar
Any place is a safe place besides by the header/exhaust...lol
Old Oct 21, 2012 | 08:09 PM
rcarr0327's Avatar
i just realized that taking out the map or maf wont help because the bogging/bad idle only happens when coming to a stop. once its able to stay a constant rpm its fine. its either it bounces around until its at normal rpm or it dies and i restart it and its back to normal. ill still check for leaks, any other suggestions?
i did notice when i was cleaning my throttle that there was a bit of oil in my intake manifold, but pipes where clean and i dont have the line from my valve cover to intake, just a breather.
Old Oct 21, 2012 | 09:01 PM
nhanson's Avatar
Clean TB?
Old Oct 21, 2012 | 10:09 PM
rcarr0327's Avatar
yea i already did, i guess ill take another wack it. ill get some throttle body cleaner or whatever.
this doesnt have anything to do with spark plugs, injectors or anything right?
Old Oct 22, 2012 | 01:16 AM
You didnt move the blade did you?
Old Oct 22, 2012 | 09:59 AM
rcarr0327's Avatar
the blade in the throttle body?
i moved the plate yea, but it is still doing the same thing as before... maybe i moved it previously when working on my car and thats how it started? how much is a new TB go for... idk if i want to get a 2.4 yet cuz i dont wanna get tuned just for that
Old Oct 22, 2012 | 11:09 AM
MURDERD's Avatar
Old Oct 22, 2012 | 11:59 AM
If you move the blade of the TB by hand it screws it up. Search it. I might have an extra one id let go.
Old Oct 22, 2012 | 12:44 PM
rcarr0327's Avatar
Yea if you have an extra one laying i might pick that up if in good condition. Just don't wanna buy and it not be the problem
Oct 13, 2015 09:32 PM
tomj77
Oct 4, 2015 11:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
