2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Supercharger build Lap
Old Mar 17, 2020 | 03:48 PM
  #126
USMCFieldMP's Avatar
Rattlesnake Race Shop
Originally Posted by jdbaugh1
Ultimately it's up to you to decide what's worth it and what isn't but using Tees isn't inherently messy. You can't even see the vacuum line or Tee's under my hood.
They can be done right and they can be done wrong. Part of why I said "it might be worth getting a vacuum block". The beauty of the vacuum manifold is that when you make changes to your setup, you don't necessarily have to run all new lines, worry about removing tee's, etc. They exist because they can make things easier, cleaner, and/or more convenient. A vacuum manifold also won't degrade with years of use like a plastic tee can (sure, they could be using a metal tee, but most people seem to spring for the plastic ones. Again, "might be worth it". Just a suggestion.
Old Mar 17, 2020 | 04:18 PM
  #127
G5ALIVE's Avatar
I don't do anything to my Cobalt unless it has a performance/functionality advantage. It's not a show car, it's my toy/hobby. If I made it too nice I'd have to get pissed off every time something gets screwed up. "Good enough" has been said plenty of times lol.
Very true.
I will do the same then. If it's not needed, why bother.
I would assume you have the lower intake manifold mounting bracket though, correct?
Old Mar 17, 2020 | 04:30 PM
  #128
jdbaugh1's Avatar
Originally Posted by G5ALIVE
Very true.
No but I won't tell you it's not needed. Others have told me that it isn't and it hasn't caused me any problems so I haven't worried about it but the part would appear to add a significant amount of support to the IM assembly to help distribute the load from the supercharger. If I stumbled across one I would probably use it but if you can't find one don't sweat it.
Old Mar 17, 2020 | 04:47 PM
  #129
G5ALIVE's Avatar
Very interesting.. I think I'll try to source one still.
Did you re-drill your Cylinder head for M8 bolts/studs?
Old Mar 17, 2020 | 04:49 PM
  #130
G5ALIVE's Avatar
Not a site I have every used but.. "OEMcats.com" seems to sell them, 7OH, 33.65 USD
Old Mar 18, 2020 | 08:32 AM
  #131
jdbaugh1's Avatar
When I was still using L61 head I never did drill and tap out my head to use M8 bolts but I did purchase the appropriate length shoulder bolts that had 8mm shoulder with 6mm threads so the manifold would be aligned correctly. I now have an LSJ head.
Old Mar 23, 2020 | 10:08 AM
  #132
G5ALIVE's Avatar
You think H/E mounting brackets are essential for a stock LSJ H/E? Can't source them without spending hundreds...
Wondering if some light fabrication and some zip ties would do the job?
Old Mar 23, 2020 | 10:18 AM
  #133
jdbaugh1's Avatar
I made my own brackets for the heat exchanger with a cut-off wheel and a bench vise to bend. I think I put the flat pattern up in my build thread along the way. You can look there but I'll see if I can dig it up.
Old Mar 23, 2020 | 10:38 AM
  #134
G5ALIVE's Avatar
Awesome. I'll give it a shot without them then, I'm sure there will be a bit of room to get creative..
Old Mar 23, 2020 | 11:00 AM
  #135
jdbaugh1's Avatar
I basically mounted mine with a simple bracket off of the front crash bar.
Old Mar 23, 2020 | 11:08 AM
  #136
jdbaugh1's Avatar
Dug up pictures and flat pattern for bracket from my build thread
Old Mar 23, 2020 | 11:13 AM
  #137
G5ALIVE's Avatar
Awesome,
Got a dual pass end plate and a heat exchanger on order now. Should have something to do now when the world falls apart
Old Mar 23, 2020 | 11:53 AM
  #138
G5ALIVE's Avatar
Thankyou, this is perfect!
I will get a friend to start fabricating these brackets right away
Old Mar 23, 2020 | 02:54 PM
  #139
G5ALIVE's Avatar
do you remember what gauge metal you used?
Old Mar 23, 2020 | 03:58 PM
  #140
jdbaugh1's Avatar
1/8" Aluminum is what I used.
Old Mar 28, 2020 | 11:20 PM
  #141
G5ALIVE's Avatar
Decided to tear my car apart today.. Dual pass end-plate should be here this week.
Went ahead swapping the cores,
and decided to gives thing's a quick fresh coat,
Old Mar 28, 2020 | 11:34 PM
  #142
G5ALIVE's Avatar
Regarding bending the tubes on a stock lsj heat exchanger...
Would it not be easier to just cut them off at the base?
Old Mar 29, 2020 | 02:08 PM
  #143
G5ALIVE's Avatar
Think I may just cut them off at the base..
Old Mar 30, 2020 | 07:54 AM
  #144
jdbaugh1's Avatar
The reason I didn't just cut mine off is that I was concerned the hose might not seal well without the bead rolled into the tube like it is stock. Bending the tubes without kinking them is a challenge though.
Old Mar 30, 2020 | 11:45 AM
  #145
G5ALIVE's Avatar
Well its definitely not pretty, but I figured out how/ where to bend the tubes. Hopefully should have it mounted now by the end of the day ..
Old Apr 7, 2020 | 12:46 AM
  #146
G5ALIVE's Avatar
End-plate finally came in, Everything's back together after a long evening. Car ate a decent amount of coolant, everything seems full, spilled lots of coolant
Ready to test her out tomorrow!
Old Apr 7, 2020 | 03:37 PM
  #147
G5ALIVE's Avatar
Got the system completely bleed this morning, took a little trial an error but alas its all done!
Being an auto with AC, everything was super tight.. Broke a sweat slipping the belt back on the blower yesterday, literately took me a solid 15 minutes.
Lot of 'firsts' for myself, Had a hell of a time routing all the hoses between the endplate and my front frame.
All in all, pretty darn Happy! !
Old Apr 8, 2020 | 02:03 PM
  #148
jdbaugh1's Avatar
Congrats man. Glad it's all working for you
Old Apr 17, 2020 | 04:30 PM
  #149
G5ALIVE's Avatar
Do you recall the dimensions of the shoulder bolts you ordered JD?
Measured the M8 bolts supplied in the phenolic spacer kit, looks like they are about 79mm and 29mm in thread length.
Looking at these off McMaster;
6x 8 mm Shoulder Diameter, 20 mm Shoulder Length, M6 x 1.0 mm, thread length 11mm, overall length 31mm
2x 8 mm Shoulder Diameter, 70 mm Shoulder Length, M6 x 1.0 mm, thread length 11mm, overall length 81mm
Old Apr 19, 2020 | 05:34 PM
  #150
jdbaugh1's Avatar
I think I posted it in my build thread when I bought them. I'll see if I can find any records.
