2.4L Supercharged Videos
Old Nov 11, 2007 | 09:15 PM
  #126
2.4SlowassBalt's Avatar
Originally Posted by Beck
well technically there is no 'plug and play' harness. The harness reguardless of which vehicle it is for will need to be spliced (to set up the map sensor). the main thing is you have the adapters taht allow the 42.5" injectors to fit. I've heard that the stock harness for a 2.4 will also work for the 42's but i cannot confirm this.
i thought that the injector harness from an ecotec cavalier allowed ss/sc injectors to be plug and play with the 2.4, which would make me figure that all injectors that fit the lsj (42's and 60's) would work with that harness. if that is incorrect please let me know.
Old Nov 11, 2007 | 09:18 PM
  #127
Beck's Avatar
the harness from the cavi will allow you to use the LSJ injectors (which are obsolete for this setup) and the GM version of the 42's. Basically it will work with GM injectors.
If you go with aftermarket 42's or 60's you'll need a bosch style injector clips. You'll have to cut and splice them.
Old Nov 11, 2007 | 09:27 PM
  #128
i see, thanks for clearing that up. now when you buy aftermarket injectors they come with the clips correct, or do they have to be purchased separately and if so where are they available?
Old Nov 11, 2007 | 09:31 PM
  #129
Beck's Avatar
well they are seperate, but most websites that sell the aftermarket ones will also sell the clips/harnesses.
Old Nov 11, 2007 | 09:32 PM
  #130
aight man, thanks for the help.
Old Nov 11, 2007 | 10:36 PM
  #131
senior_brown's Avatar
i gotta fix my p300, gonna try a different gap
Old Jan 23, 2008 | 12:35 AM
  #132
xx07cobaltss24xx's Avatar
iam soooo jelious
Old Jan 23, 2008 | 02:30 AM
  #133
Onyxd04Redline's Avatar
Very nice
Old Jan 23, 2008 | 02:43 AM
  #134
Slowbalt SS05's Avatar
nice 2.4 man congrats
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
z28addiction
Sep 28, 2015 12:03 AM
