2.4ss/sc build commenced!!!
Old Mar 15, 2009 | 07:21 PM
  #176
Jn2's Avatar
Jn2
Originally Posted by Dragonsfire12345
the plug and play 60s are for the 2.4 only
also how do check the oil in the supercharger
2.4 and 2.2 use the same injectors and harness BTW, there is a allen bolt on the neck neck portion of the blower, its on that part, ull see it, its black, i took mine off, drained the oil out, put it back one, taped over it, so it wouldnt get coverd in paint when i painted the blower, easy to spot check the how to section
Old Mar 16, 2009 | 03:22 AM
  #177
elecblue06's Avatar
not true.. because you can plug and play 32's and 42s 2.4s cant
Old Mar 16, 2009 | 03:25 AM
  #178
Jn2's Avatar
Jn2
Hmmm so stg2 plugs would plug right in than huh
Old Mar 16, 2009 | 04:10 PM
  #179
rockstar014's Avatar
damnit i need a 2.5 pigtail
Old Mar 16, 2009 | 04:24 PM
  #180
elecblue06's Avatar
they should.. 32's plug right into the 2.2 harness.. and 42s plug right into the lsj harness
Old Mar 16, 2009 | 05:39 PM
  #181
Jn2's Avatar
Jn2
hmmmmm...
Old Mar 24, 2009 | 12:15 AM
  #182
Dragonsfire12345's Avatar
update
well I've had lots of bumps and hic ups through out the build /cry lol oh well.... car is done and ready to go but........
theft lock system activated and now my car won't turn on.... so I'm towing it to st. phillips college tomorrow so we can remove it and get the car running. While we are there, I'm gonna have one of the teachers look over the tune with hp tuners.
Old Mar 24, 2009 | 01:10 AM
  #183
Jn2's Avatar
Jn2
good luck man, I dont know y u have so many problems
Old Mar 24, 2009 | 02:33 AM
  #184
agreed
Old Mar 24, 2009 | 02:52 AM
  #185
well I really haven't had many problems... just a late arrival of the injectors, broken byass valve, and theft lock kicking in...
Old Mar 24, 2009 | 12:13 PM
  #186
ok got a big Q do we need this...?
Old Mar 24, 2009 | 01:27 PM
  #187
HunterKiller89's Avatar
^^ what is it? Clearly a MAP sensor, but is it the stock 1 bar, the LSJ 1 bar, or the ZZP 1.8 bar?
regardless, you need a 1 bar MAP sensor from the LSJ for plug and play, or you can use the LSJ 2.5bar/zzp1.8bar and tune the MAP tables to rescale for the larger range.
Old Mar 24, 2009 | 01:44 PM
  #188
Jn2's Avatar
Jn2
depends who your tuner is vince has said its useless and he doesnt need the lsj MAP and he can use the stock one, some tuners would preffer rescaling everything for the 2.5 map
Old Mar 24, 2009 | 02:05 PM
  #189
ic ic soo i wouldnt need it????
Old Mar 24, 2009 | 02:24 PM
  #190
again, how many bars is it, and who's doing your tuning?
Old Mar 24, 2009 | 02:48 PM
  #191
elecblue06's Avatar
umm wut .lol .. you said lsj 1 bar map to many times.. now i'm confused... lol
the issue is faking a 2.5 bar map doesn't actually change anything really tuning wise.. you cant use it for what it's intended for
Last edited by elecblue06; Mar 24, 2009 at 02:48 PM. Reason: Automerged Doublepost
Old Mar 24, 2009 | 03:24 PM
  #192
Guardian314's Avatar
this looks awesome, i hope it turns out good and you have no more problems, good luck man
Old Mar 25, 2009 | 04:50 PM
  #193
the LSJ has a 1 bar that mounts in the blower, and a 2.5bar/IAT2 sensor that mounts in the intake manifold
Old Mar 25, 2009 | 08:06 PM
  #194
elecblue06's Avatar
you talking about a supercharger inlet pressure sensor?
because thats not relaly the MAP sensor lol
Old Mar 25, 2009 | 08:30 PM
  #195
so here is whats going on right now... as yall know the theft lock system is on... I towed it to the automotive school where my friend goes/works at. One teacher said that the ECM is fried, and another teacher says that he doesn't think it is cuz if it was nothing would be working at all(radio, instrument panel, and other electrical stuff)
What do yall think?
Old Mar 25, 2009 | 08:38 PM
  #196
it is a 1 bar MAP sensor regardless of what the ECU uses the readings for. It's the sensor thats controlling my ECU at the moment as well.
What do yall think?
im sure the ECM is fine. i think the same thing happened to me when i was flashing my ECU. I accidentally unplugged something i shouldnt have when the battery was still connected (the engine was off tho), and i saw a tiny spark. I scared myself half to death, so i tried to start the car, and the theft lock thing came on. I dont remember how i got around it tho, but my car drives just fine
Last edited by HunterKiller89; Mar 25, 2009 at 08:38 PM. Reason: Automerged Doublepost
Old Mar 25, 2009 | 08:50 PM
  #197
pjk91's Avatar
What do yall think?
Leave your key in the on position for a half hour and the bcm will rel-learn the code.
Old Mar 25, 2009 | 10:14 PM
  #198
elecblue06's Avatar
your ecu doesn't see the extra sensors as it should.. you're FAKING it but it's still necessary.. and a 1 bar map sensor .. wont read extra pressure..
the does he need a 2.5 bar map.. NO
but does he need the SCIP sensor yes..
Old Mar 25, 2009 | 10:48 PM
  #199
you're losing me a bit. on a 2.4/2.2, the SCIP is NOT needed to run, as the stock ECU has no parameters to be reading. Because of this, the SCIP 1 bar sensor can be removed and used as a replacement for your stock 1bar MAP sensor since the stock sensor is too small to fill the IM hole. Vince's tune will then have PE mode engaged based on the readings by the 1bar MAP, and fueling above 1bar will be handled by the MAF.
Old Mar 25, 2009 | 11:52 PM
  #200
elecblue06's Avatar
ohh ok .. sorry .. lol .. yea the scip is only needed to fill the hole
