first htv 1320 received
yea.....well, I swapped the Bypass valve from the stock blower on to the HTV since the HTV didn't have a vaccum port for the bypass solenoid. Got some vaccum hose and ran the new lines.
you keep like the COT active, then tune the PE table to get your desired AFR?
damn it......I was doing
air flow vs rpm vs fuel map vs cabbage...
apparently cabbage always make things run "rich"
Last edited by Sunburst_SS; Mar 26, 2008 at 06:38 PM. Reason: Automerged Doublepost
cot has to be shut off.
the moon is larger and has a larger affect on the earth than cabbage. if the moon blew up. we would die. if cabbage blew up. we would need a shower
P.S. regardless of what the forums say a cam /= instant 11s...u need 2 cams for that OOOO BURN!!!
BTW bryan...phone died at work today...no juice ftl
considering the headers prob pulled be back to the dyno numbers of a 6 speed... i think 107 is decent
You shall find out at quaker city.
and it's only good for 5-15 psi.
