first htv 1320 received
Old Mar 26, 2008 | 05:32 PM
  #1276
SK360's Avatar
If 110 traps are all I have to compete with from the turbo saturn..... It's gonna be a good year
Old Mar 26, 2008 | 05:39 PM
  #1277
Area47's Avatar
Rent me! per hour
Originally Posted by Smarty Art
When your car would launch and wasn't towed off the strip.
oooooohhhhhhhhhhhhhh tag!
Old Mar 26, 2008 | 05:44 PM
  #1278
Sunburst_SS's Avatar
shouldn't it be
"ohhhhhhhhh SNAP"??
Old Mar 26, 2008 | 05:48 PM
  #1279
Witt's Avatar
x2
Old Mar 26, 2008 | 05:50 PM
  #1280
anyways...how you coming along on the htv Witt?
Old Mar 26, 2008 | 05:51 PM
  #1281
Area47's Avatar
Rent me! per hour
Originally Posted by Sunburst_SS
shouldn't it be
"ohhhhhhhhh SNAP"??
touche salesman
Old Mar 26, 2008 | 05:57 PM
  #1282
yea.....well, I swapped the Bypass valve from the stock blower on to the HTV since the HTV didn't have a vaccum port for the bypass solenoid. Got some vaccum hose and ran the new lines.
Old Mar 26, 2008 | 05:58 PM
  #1283
turboeco's Avatar
How are the 60s treatin ya? ^^^
Old Mar 26, 2008 | 06:00 PM
  #1284
they are doing alright......they're in, and the car is running pretty good. Just trying to flatten out the afr a bit is being a pain in the ass haha.
Old Mar 26, 2008 | 06:09 PM
  #1285
Area47's Avatar
Rent me! per hour
welcome to the world on a none linear pe curve to maintain a flat afr
have fun with that
Old Mar 26, 2008 | 06:12 PM
  #1286
care to elaborate on that a bit???
Old Mar 26, 2008 | 06:36 PM
  #1287
Area47's Avatar
Rent me! per hour
maybe
air flow vs rpm vs fuel map vs the moon.
Old Mar 26, 2008 | 06:38 PM
  #1288
you keep like the COT active, then tune the PE table to get your desired AFR?
Originally Posted by Area47
maybe
damn it......I was doing
air flow vs rpm vs fuel map vs cabbage...
apparently cabbage always make things run "rich"
Last edited by Sunburst_SS; Mar 26, 2008 at 06:38 PM. Reason: Automerged Doublepost
Old Mar 26, 2008 | 06:40 PM
  #1289
Area47's Avatar
Rent me! per hour
cot has to be shut off.
the moon is larger and has a larger affect on the earth than cabbage. if the moon blew up. we would die. if cabbage blew up. we would need a shower
Old Mar 26, 2008 | 06:45 PM
  #1290
hahaha, I never thought of it like that!!!!!
so, if you have COT still disabled.....how do you not have a constant PE value?? Is there another adder somewhere??
Old Mar 26, 2008 | 06:47 PM
  #1291
Area47's Avatar
Rent me! per hour
negative meat popsicle. it's more in the higher rpm range, and higher airflow area's
Old Mar 26, 2008 | 06:51 PM
  #1292
ever have a meat popsicle melt in your hand?
well, I guess there's something I missing
Old Mar 26, 2008 | 06:54 PM
  #1293
Area47's Avatar
Rent me! per hour
just keep and eye on the afr.
Old Mar 26, 2008 | 07:03 PM
  #1294
hah, well hopefully I figure that out then
i need to get it smoothed so I can actually put some timing back into it
Old Mar 26, 2008 | 08:57 PM
  #1295
djt81185's Avatar
LOL at the modded LS2 that goes 13.2@107
P.S. regardless of what the forums say a cam /= instant 11s...u need 2 cams for that OOOO BURN!!!
BTW bryan...phone died at work today...no juice ftl
Old Mar 26, 2008 | 09:18 PM
  #1296
Blown 4-banger's Avatar
This thread is hilarious!!! At first it was about the new supercharger released for the LSJ... LAME!!! I'd rather hear how Al's car was faster than Dan's turbo'd car... or vic versa
Old Mar 26, 2008 | 10:33 PM
  #1297
SK360's Avatar
107.68 dick...
considering the headers prob pulled be back to the dyno numbers of a 6 speed... i think 107 is decent
You shall find out at quaker city.
Old Mar 26, 2008 | 10:36 PM
  #1298
WSFrazier's Avatar
Lol, you have a better chance of seeing me at Quaker City in a new car.
Old Mar 26, 2008 | 10:38 PM
  #1299
SK360's Avatar
Old Mar 26, 2008 | 10:52 PM
  #1300
jimbos'ss's Avatar
Originally Posted by Witt
Yep I'm in the same boat. Actually commanding slightly richer and overrunning pulse width to 113% duty cycle but it ends up being 11.4. I just need to smooth MAF and add timing, I have it severely cut back for the time being.
BTW, I want this:
hey where did you find that one because when i go to aeromotives websight all i find is this one: http://www.aeromotiveinc.com/product...tsub=0&prod=32
and it's only good for 5-15 psi.
