The Motor is IN!!!!!!
Old Nov 22, 2006 | 11:23 AM
  #326
bdwarr6's Avatar
Originally Posted by DJMKAFKA
Arggggggggggggggggggh
no **** LOL
Old Nov 22, 2006 | 11:33 AM
  #327
JRANGER's Avatar
O ******* A!
  #328
wdsoccer's Avatar
Hey Bdwarr6 just lettin you know that i got the gauge pod....thanks
Old Nov 22, 2006 | 11:37 AM
  #329
M88ArRamadi's Avatar
Dude...I can't wait until it starts up!! Did you use a pulley puller to get the crank pully off? Also did you get a mint with your pistons...I did.
My Situation: I'm waiting for my friends cherry picker, leveler, and stand. My motor is prepped already....Holy screaming eagle **** that wire harness is huge!! Also waiting for CPP.com to send my stuff. I ended up getting the stage 3+ but I thiink that is overkill. what do you think? Should I change it to the stage 2+? Please PM me the answer...I don't want to side-burst.
Old Nov 22, 2006 | 11:59 AM
  #330
SS_SC_Cobalt's Avatar
fo you guys doing this stuff here is a thanksgiving present..
Ch1 and 2
CH 3 and 4
CH 5 and 6
Enjoy!
Old Nov 22, 2006 | 12:12 PM
  #331
Imlikedrpepper's Avatar
Damnit, all this waiting...I want to see that post "ITS RUNNING" and then I want to see the dyno, hehehe
Old Nov 22, 2006 | 12:41 PM
  #332
bdwarr6's Avatar
no have someone hold the belt onto the pulley and keep it tight then just take off the bolt the pulley will slide right off,
becareful with your oil squirters i fucked mine up
Old Nov 22, 2006 | 12:42 PM
  #333
bdwarr6's Avatar
also the leveler is a must, you will have to finagle it to get it out,
This is a must pull the block and complete transmission otherwise youll just waste time and end up doing it anyway
hook the leveler upto the head and then remove 3 tranny mounts and the engine mount and all wires, then just pull it out
Old Nov 22, 2006 | 02:41 PM
  #334
cMw's Avatar
cMw
having fun at work?
Old Nov 22, 2006 | 02:45 PM
  #335
2K5SS/SC?'s Avatar
BD, this project has got to be driving you crazy by now. I'm going nuts just waiting on its completion and I've never even seen the car!
Oh, and you did reinstall the oil squirters right? I sure hope so.
Old Nov 22, 2006 | 07:27 PM
  #336
bump. Any new info?
Old Nov 22, 2006 | 09:10 PM
  #337
bdwarr6's Avatar
I got 3 of them in fine the 4th was completely stripped out, a very knowlegable person told me just to plug it, and it would raise oil pressue 1-2lbs
so i plugged it
nothing else i could do, you cant get a helicoil for the size it was
  #338
bdwarr6's Avatar
also i have the cam just relaxing some before i go finish it up, and prepare myself for what is going to break next
Old Nov 22, 2006 | 09:15 PM
  #339
Brian MP5T's Avatar
so i plugged it
You plugged an oil squirter? Do you think that was a good idea??
Old Nov 22, 2006 | 10:38 PM
  #340
sunfirejoe's Avatar
yah arent the oil squirters a major part of cooling
Old Nov 22, 2006 | 11:02 PM
  #341
bdwarr6's Avatar
nothing i could do about it, the place i took my block said it shouldnt be a problem, and they are the best place in the midwest for engines
Schmits
they build 1/2 mil drag motors, he said just get an oil pressure gauge and oil temp you should be fine
  #342
bdwarr6's Avatar
also PRAY
they timing is done just have to put valve cover back on and super
please dear god
  #343
06black's Avatar
thats what i thought....i cant see that being a good thing
Old Nov 23, 2006 | 12:10 AM
  #344
bdwarr6's Avatar
oh well, there is honestly nothing i could do about it, i had several opinions on it and thats what i chose to do,
I am almost ready to attempt to fire it up
replace supercharger and motormount then try!
Old Nov 23, 2006 | 12:17 AM
  #345
06black's Avatar
ohhh snap!
let us know!
Old Nov 23, 2006 | 12:26 AM
  #346
BooSSted's Avatar
The moment of truth awaits.................
Old Nov 23, 2006 | 12:35 AM
  #347
HickOverLOrd's Avatar
after reading all 18 freakin pages and all the sh*t you have gone through after you thought it was done, I hope everything goes good. Good luck!
Old Nov 23, 2006 | 01:05 AM
  #348
bdwarr6's Avatar
THEY BITCH IS ALIVE
it sounds nasty
I will get a sound clip and movie tomorrow when i get the wheels back on it
Old Nov 23, 2006 | 01:06 AM
  #349
bdwarr6's Avatar
I am so ******* happy!!!!
one last thing is to bleed clutch, and I cant drive it till friday, snce it broke down on dealer plates... i have no plates!!!! neerrrrrrr
omg im seriously so happy
Old Nov 23, 2006 | 01:08 AM
  #350
Congrat the ****** ulations!! Get the sound clips up asap!!!
