The Motor is IN!!!!!!
LSX RWD S/C conversion
Originally Posted by bdwarr6
THEY BITCH IS ALIVE
it sounds nasty
I will get a sound clip and movie tomorrow when i get the wheels back on it
it sounds nasty
woot and i was honestly starting to think it would never run again!!!
down with negatism
cobalt FTW!!!!!
seriosly there is no way in hell i can sleep but cant do **** till i get my tuners cable back, and get some help to bleed the clutch
down with negatism
cobalt FTW!!!!!
oh well, there is honestly nothing i could do about it, i had several opinions on it and thats what i chose to do,
I am almost ready to attempt to fire it up
replace supercharger and motormount then try!
The option is to fix it.
1. The heatloading across the 4 will not ballance, this will cause the one piston to expand at a diferent rate and swell in the cylinder.
2. It will increase the heat of that piston, because it is hotter in that one cylinder, you will encounter problems with detonation in only that one cylinder. The others will be fine but when you come on to it, that one cylinder will limit your HP across the entire bowerband.
The OPTION is to replace it. Buy a new block if you have to, I replaced my Mazda engine from Valve cover to oilpan for $800.00... Sold half the **** for a total of $600.00 and used that block and head..
well for one I"m happy for ya man,,, I know this has been one hell of a project and I followed it from day one... I just hope that oil squirter doesn't cause ya major problems.. it is actually a very important part of the motor.. especially runnnin high boost and compression... If I were you I would limit the amount of time you spend at WOT and hope for the best...
Good luck man now lets see some damn vids.. I gotta see/hear this thing go
Congrats on getting it running. However I think your a fool for running it without the oil squirter. I know your anxious to get the project done, but you have to do it right. If you need a new block then that's what you need. You don't want to break more parts and be back in the same boat again with a broken car.
I got 3 of them in fine the 4th was completely stripped out, a very knowlegable person told me just to plug it, and it would raise oil pressue 1-2lbs
so i plugged it
nothing else i could do, you cant get a helicoil for the size it was
so i plugged it
Originally Posted by cawpin
If the place you took it was such a good shop they could have MADE a plug and threaded it for you. I think you're asking for trouble with that. It is cool that you got it running but I hope you don't fry it.
Still, you should have waited til you had enough to get that squirter fixed. Now your motors worthless because 1 piston is running 2 or 3 times hotter than the others, knock is gonna be crazy IN THAT 1 piston, and the piston will prolly melt as soon as it sees long continous WOT use
You doomed yourself to blow the motor again...
You doomed yourself to blow the motor again...I have done several runs to 150mph and ran it there for 2-3 miles rest assured its not that
Im selling my car not that I cant afford it, my income just more than doubled.... it doesnt fit my lifestyle anymore. This is honestly a pointless argument
