OFFICIAL Blown 4-banger build updates!
Old Apr 23, 2008 | 03:46 PM
  #926
Tomtwtwtw's Avatar
Yeah, I think we need updated pics of both builds.
Old Apr 24, 2008 | 12:39 PM
  #927
Blown 4-banger's Avatar
Tore apart the tranny yesterday. Took several hours, and two transmission experts scratching their heads, but we got it.
5th gear was a bitch and end up getting destoryed in the process
We finally split the housing and pulled the guts out
Neither one of the guys working on it, had EVER seen shift linkage like this
We also took apart the diff (LSD)
We decided the differential was built by super advanced aliens, while the transmission was built by Satan.
So now the transmission sits like this
Old Apr 24, 2008 | 12:59 PM
  #928
Area47's Avatar
Rent me! per hour
helical diff
did you have the right tools to pull apart said tranny?
Old Apr 24, 2008 | 01:01 PM
  #929
Originally Posted by Area47
helical diff
For the most part. We had all tools, EXCEPT the tool to pull off 5th gear. In the end we ended up breaking like 3 or 4 teeth off the gear. So yeah, like I said 5th gear is fuct.
Old Apr 24, 2008 | 01:03 PM
  #930
blackjack hotrods's Avatar
Too bad. If you had asked, I may have been able to borrow the special tool from work here.
Old Apr 24, 2008 | 01:05 PM
  #931
I didn't know you worked at a dealer.
Old Apr 24, 2008 | 01:13 PM
  #932
Area47's Avatar
Rent me! per hour
learn something new everyday don't ya
Old Apr 24, 2008 | 01:44 PM
  #933
I work at Thorobred Chevrolet. I live around Chandler and Dobson. You're right in between the two right?
Old Apr 24, 2008 | 03:14 PM
  #934
USMCFieldMP's Avatar
Rattlesnake Race Shop
I can send you my extra 5th gear off of my car, free of charge... all I ask is that I can borrow your tools to tear apart the trans. I just need to be able to get the case apart, and get the second gear Synchro off. And then, if you want my 5th gear... I'm gonna need the tool, if you can borrow it.
Old Apr 25, 2008 | 12:06 AM
  #935
Do you drive the black ss/sc?
Old Apr 25, 2008 | 01:32 AM
  #936
You'll answer his question and not mine? Haha, that burns me on the inside.
Old Apr 25, 2008 | 02:37 AM
  #937
Nope. That's Steven. He works the retail counter. I drive a lowly sport red tintcoat 2.2L LT sedan. I work the shop counter and I used to be a technician.
Old Apr 25, 2008 | 02:45 AM
  #938
RedGoat's Avatar
Guess he doesn't like driving his car!!
Old Apr 26, 2008 | 05:39 AM
  #939
If you want me to send you two pry bars and a torch, then go ahead and send me your gear, but it will be broken too.
Old Apr 29, 2008 | 05:51 AM
  #940
I'll sell you the 5th gear off of my current tranny. Save you the money of having to buy a new one.
Interested? Or do you already have one lined up?
Old May 1, 2008 | 01:24 AM
  #941
WSFrazier's Avatar
Question for you Cam...
Did you happen to test fit OEM wrist pins in the small end of your Crower rods yet? I know your probably going to be using the pins CP gave you, but just curious if you did or if you can.
I figured the Diamond wrist pins would be too big to fit, because they were too big for OEM rods, but even the OEM pins won't fit into the Crower rod. So much is going to be needed to be honed away, it is probably going to remove all the bearing surface.
These rods were also listed as 2.2/2.0, which technically shouldn't be the case.
Old May 1, 2008 | 03:42 AM
  #942
Yeah, that kinda sucks for you man if you bought a set of rods. My rods were custom made, off the dimensions of the stock rod I sent them. The oem wrist pin fits perfectly into my rods, as well as the CP pistons wrist pins. My crower rods are EXACTLY the same dimensions as my stock rods.
Old May 1, 2008 | 05:55 AM
  #943
shaunmcdee's Avatar
Hes talking about my rods.
And the only different aspect of our rods looks to be the pin bushing....
about how much bushing material do you have left on your rod? approx...caliper reading if at all possible. Thank you.
Old May 7, 2008 | 11:46 AM
  #944
Got my main bolts, and replacement 5th gear today. That means that I can get everything cryo frozen, then get the tranny reassembled, then while the head work is getting done, I can begin to reassemble the motor!!!
Old May 7, 2008 | 02:03 PM
  #945
WunSick's Avatar
Hell ya, lot-o-pics
Old May 14, 2008 | 02:41 PM
  #946
Not really an update, but I thought I'd share this sexy picture of my engine. Now that is a built ass motor
Old May 14, 2008 | 02:47 PM
  #947
SSdan's Avatar
Not quite because it isn't back together yet!
Old May 14, 2008 | 06:30 PM
  #948
jimbos'ss's Avatar
did you have the block sleeved?
Old May 14, 2008 | 06:41 PM
  #949
BlackSS/SC's Avatar
Yummy!
Old May 14, 2008 | 06:42 PM
  #950
hatrickstu's Avatar
cam that looks like a bunch of pieces, not a motor
