OFFICIAL Blown 4-banger build updates!
Old May 16, 2008 | 05:07 PM
  #1001
Blown 4-banger's Avatar
Originally Posted by Witt
Cannot rush perfection imo.
Also budget as well.
So true its not even funny
Old May 17, 2008 | 10:59 PM
  #1002
INFE's Avatar
When do you think your going to have your car running again??
Old May 18, 2008 | 12:13 PM
  #1003
SwizzDSMSS's Avatar
Originally Posted by Blown 4-banger
Last time the engine ran was March 17th, 2007
That was a still a good night! hahaha
Old May 18, 2008 | 04:04 PM
  #1004
Hopefully by mid June.
Hellz yeah it was! If I had a change to do it again, you bet I'd would!!!
Old May 20, 2008 | 04:27 AM
  #1005
I pick up the dismantled clutch on thursday
Drop the stuff off at the cryo place, hopefully friday
Pick it up on monday
Drop the head off at the machine shop on tuesday
pick it up ~2 weeks later
Reassemble motor and install in car
Break motor in
proceed to destroy all other cars on the highway
Old May 20, 2008 | 11:51 AM
  #1006
Area47's Avatar
Rent me! per hour
::looks at arm and then realizes his watch doesn't measure infinity:::
Old May 20, 2008 | 01:00 PM
  #1007
RedGoat's Avatar
Its nice having a car thats over 2 years old, and has 11,123 miles
My 05 GTO has 14K miles.
And it runs.
What kind of power are you hoping for when you are done with this build?
Old May 20, 2008 | 01:03 PM
  #1008
  #1009
Area47's Avatar
Rent me! per hour
i'll be here all week
  #1010
And it runs.
400 hp at the crank (332 whp) on pump gas with a 2.9" pulley.
Then like 375-380 whp with a 2.6" on race gas.
Then ~480 whp on race gas, 2.6" pulley + 100 shot
Old May 20, 2008 | 01:38 PM
  #1011
USMCFieldMP's Avatar
Rattlesnake Race Shop
Break motor in
proceed to destroy IT ONCE AGAIN
Fixed it for you.
I'm just playing man. Good luck though. That first start up always makes me nervous... you start doubting stuff... "Oh ****... did I torque ALL of the rod bolts? What if I forgot one? **** Me!"
Old May 20, 2008 | 03:14 PM
  #1012
Fixed it for you.
My worry will be, **** did I make sure the internal shift linkage was lined up right!?!?! If we get it wrong, the car would run fine, but it would only have either 1st, 3rd, and 5th, or 2nd, 4th, and reverse
Old May 20, 2008 | 03:17 PM
  #1013
Indeed. You shall find out shortly.
You can check the Internal Shift Linkage before you put it in the car though.
Old May 20, 2008 | 04:08 PM
  #1014
WunSick's Avatar
Glad to see there is more progress man. Sorry i havent been able to yack on AIM, been blasted with code updated the last few months. Sucks.
Old May 20, 2008 | 04:38 PM
  #1015
Oh.... I haven't been on aim in a while
Old May 20, 2008 | 08:51 PM
  #1016
sunfirejoe's Avatar
does anyone know the alignment for the gears lol, i had that problem
Old May 20, 2008 | 09:01 PM
  #1017
What do you mean? Alignment for the gears? Do you mean the spiral gears (1st, 2nd, 3rd ect) or the little partial gears for the linkage?
Old May 22, 2008 | 12:58 AM
  #1018
sunfirejoe's Avatar
sorry was drunk when i posted lol, i meant for the shifter linkages and so on, i was missing 2nd 4th and reverse, also 5th, lol, motor is out of car again lol, blah stupid turbo installs
Old May 22, 2008 | 11:11 AM
  #1019
RedGoat's Avatar
Your still gonna run the Heaton?? **** with a turbo race gas and 100 shot you would be looking at 600+
Old May 22, 2008 | 11:15 AM
  #1020
lsjwannabe's Avatar
ehhh, i don't see it happening
Old May 22, 2008 | 11:52 AM
  #1021
Yeah, and no usable power below 3500 rpm. This is gonna be my daily driver (not very practical I know, but I'm crazy ), I want power for daily driving, and turbo certainly doesn't provide that. Plus, I like the thought of being able to title myself "Fastest stock blower LSJ in the country"
Naysaying has no place in my thread, so STFU!!! Jk, but seriously, there is no reason what so ever that I can't EASILY make my power goals with the rediculous cams, head work, and valvetrain I'm using. It will probably make peak power right at the rev limiter, and would want to make peak power more like 8300-8400 with a 2.9", and peak power around 7400-7500 with the 2.6". I think you don't want me to hit my goal because my car would have more power than your TVS, and mine will be running like 12-13 psi out of the stock blower jk
Old May 22, 2008 | 12:34 PM
  #1022
RedGoat's Avatar
330 WHP on pump should make for some mid to high 12's should not be bad. What kind of cams are you going with? Lift/Duration/LSA.
Old May 22, 2008 | 12:35 PM
  #1023
lsjwannabe's Avatar
your not making 80 whp on internals this is not a ls1. I will wait and see prove me wrong though.
Old May 22, 2008 | 10:07 PM
  #1024
Ok little guy, calm down
You shall see, and I will accept your apology when the time comes
.475" lift/224 @ .050"/110 LSA (will play with it a little with the cam gears). Thats with +1 mm valves, and ridiculous head work.
Last edited by Blown 4-banger; May 22, 2008 at 10:07 PM. Reason: Automerged Doublepost
Old May 22, 2008 | 11:19 PM
  #1025
Asphalt Assault's Avatar
Hmm. no usable power under 3500RPM and turbo is old school thought my friend. 2871 Garrett turbo on an LSJ SS with bad tune, 12 PSI, and GMS2 tune with injectors out pulled my LSJ GMS2 3" pulley by 2.5 car lengths. plus he had to shift prior to 6200 RPM cause the injectors were maxed. car is just sick and boost is there in an instant.
when trying to crank up the boost a little he hit 20 PSI by accident. it was instant as well. I would not have believed it with out seeing it myself.
TVS is a good idea. but you can benefit from a good turbo and still have instant boost. I am still a fan of SC scream.
I know your not about TUrbo's but I didnt want you to just run your mouth about turbo lag when there is not any.
