OFFICIAL Blown 4-banger build updates!
Old May 14, 2008 | 10:49 PM
  #951
Blown 4-banger's Avatar
Ok well it may not be back together just yet, but one thing is for sure. Theses gauges I just got in the mail today are effing sexy
Old May 14, 2008 | 10:52 PM
  #952
WSFrazier's Avatar
Did you end up re-sleeving the block?
  #953
Na, stock sleeves don't fail until 750 hp. I'm not worried about ever making that much.
Old May 14, 2008 | 10:55 PM
  #954
WSFrazier's Avatar
Looks good.
We just finished Dan's the other night. Took a few hours.
After building 4 while in the car, I can say doing Dan's out of the car was FTMFW. Shouldn't take ya too long at this point.
Old May 15, 2008 | 12:19 AM
  #955
jimbos'ss's Avatar
is that what the build book says? i keep hearing 450hp, figuring yours are cryoed like mine i figure it will be a bit higher than stock.
Old May 15, 2008 | 04:39 AM
  #956
Back in like 2002 GM tested the limits of the stock ecotec block. The sleeves didn't fail until just over 750 hp.
Old May 15, 2008 | 06:12 AM
  #957
USMCFieldMP's Avatar
Rattlesnake Race Shop
That's what I thought as well... but GM just released the Ecotec Build Book 3rd Edition with this in the back:
Old May 15, 2008 | 08:36 AM
  #958
06black's Avatar
your looking at the liners for the L61........
Old May 15, 2008 | 08:52 AM
  #959
It doesn't say L61... it just says liners, when they are engine specific, they specify. I assume they mean Sleeves by that.
I'm just point out what everyone has been quoting.
Old May 15, 2008 | 12:05 PM
  #960
Well they are stupid. Look at Pauls car. 411 whp on stock internals (that includes sleeves), 411 whp = 495 hp at the crank.
Old May 15, 2008 | 12:21 PM
  #961
Area47's Avatar
Rent me! per hour
the drag cars don't run the lsj block. they start with the l61. hence that info.
Old May 15, 2008 | 06:24 PM
  #962
Witt's Avatar
I haven't dug into it too much but the LSJ and L61 blocks and liners should be the same afaik aren't they? Both 86mm bore and gen1 L850 lost foam blocks. Am I missing something?
BTW, if you do a little digging the Darton sleeves are actually manufactured under the MID line for even more win.
Old May 15, 2008 | 06:34 PM
  #963
Area47's Avatar
Rent me! per hour
l61 has thinner sleeves.
someone should step in to confirm this
Old May 15, 2008 | 06:47 PM
  #964
Witt's Avatar
Should be easy to confirm with part numbers. When I get home I'll check.
Old May 15, 2008 | 06:51 PM
  #965
Area47's Avatar
Rent me! per hour
tiz true
Old May 15, 2008 | 07:21 PM
  #966
06black's Avatar
material thickness wont change. however the material will.
91mm cast bore, 5mil sleeve = 86mm bore.
the big-bad GM race engines run L61 blocks from builds start, thus the reason they are replaced so early in.
its a long life material, not a big power sleeve.
the lsj on the other had had to pass warranty and durability cycles at the max GM backed power levels (stg3 on the bottle) this the difference in cylinder heads, sleeves, ect, ect.
cam's correct here, the lsj sleeves are good to far more then people think.
Old May 15, 2008 | 07:35 PM
  #967
jimbos'ss's Avatar
thats comforting to know
Old May 15, 2008 | 07:39 PM
  #968
Psykostevo's Avatar
Cameron let's race!
Old May 16, 2008 | 04:02 AM
  #969
I like how just about every person on this site knows my name
Originally Posted by Psykostevo
Cameron let's race!
I'd win.
My car with no engine/trans and gutted = ~2500 lbs
Your car full weight = ~3400 lbs
Unless you are many times stronger than me, I could easily push my car faster than you could push yours
You do however need to give my a ride in your Stang!!!
Old May 16, 2008 | 04:11 AM
  #970
Witt's Avatar
Why does your title thing say dead in the water?
Old May 16, 2008 | 11:06 AM
  #971
Area47's Avatar
Rent me! per hour
he went fishing and fell out of the fail boat
Old May 16, 2008 | 11:40 AM
  #972
Is that better?
Old May 16, 2008 | 11:43 AM
  #973
Witt's Avatar
Is that better?
I love you.
no homo
Old May 16, 2008 | 11:55 AM
  #974
Area47's Avatar
Rent me! per hour
wow....... that ranks right up there with a full on man orgy
Old May 16, 2008 | 11:57 AM
  #975
Witt's Avatar
I has ninja text in my post.
Don't be hatin.
