SS twincharged
hey i was thinking about doing this to my cobalt but i didnt know if it would blow the motor or cause any problems having both a supercharger and a turbo so my question is did you have any problems having both on your car? pm me
What size of turbo would you guys recommend for this? I've got a custom K27/K29 (pretty large) sitting around, and if the turbo parts are a decent price I wouldn't mind twin charging my LSJ.
Being that it's custom I don't have precise trim sizes, but it seems relatively the same size as a T66. It came from a Skyline single turbo kit.... I figure it's too big to use by itself, so why not help spool it with the M62?
Hey, I might be wrong. That cast elbow is 3". I was told by some UK fellows that this was comparable, if not favoured to the T66. Made the same power, and spooled faster..... on an inline-6 anyways
Here's the answer
Thats fucken funny! A racist turbo.... If thats a T66 be very carefull I have a Greddy T66 on my 240 and it makes 600whp at 22PSI and the optimal PSI range on that turbo is 28-35PSI. ACS racing purposely left the boost low as hell do to the ease of tunning. **** all the gibber jabber it's a very powerfull turbo for a 2.0. With the M62 adding another litter theoreticly it's a three liter.
this is the most optimal twincharge setup a TO4B!!!
INLET
3"
INTAKE
2"
BEARING TYPE
WET FLOAT BEARINGS
OIL INLET
1/8 NPT
MAX PSI CAPACITY
30 PSI
COMPRESSOR
.60 AR
TURBINE
1.12 AR
COMPRESSOR WHEEL
53.90 /69.31
TURBINE WHEEL
63.98 /73.89
FLANGE TYPE
T4 FLANGE
DOWN PIPE FLANGE TYPE
3" V BAND
MAX HP
400+ HP
COOLING TYPE
oil cool only
INLET
3"
INTAKE
2"
BEARING TYPE
WET FLOAT BEARINGS
OIL INLET
1/8 NPT
MAX PSI CAPACITY
30 PSI
COMPRESSOR
.60 AR
TURBINE
1.12 AR
COMPRESSOR WHEEL
53.90 /69.31
TURBINE WHEEL
63.98 /73.89
FLANGE TYPE
T4 FLANGE
3" V BAND
MAX HP
400+ HP
COOLING TYPE
oil cool only
Sorry for the long time...
In last summer, I pushed my setup to the limit.....hahaha
28 psi of boost on stock clutch and internal, After two month clutch began to slip in 3rd and blow my piston 4
But feeling the tires losing traction in third gear is awesome....
sorry for my english.... i'm tight, i'm go working lol
hell yeah no kidding, do u mind if i ask how much this has cost you? i've looked and looked and only website i have wentback to is the ZZ performance website cause they almost have everything!! but thats really sick man, and i hope i get to do mine this way, and i bet the filling oflosing control in 3rd is amazing lol
