Alcohol Injection Systems Alcohol Injection Systems is a Supporting Vendor
Questions About Water Methanol Alcohol Injection - Post Them Here
Old Feb 17, 2009 | 01:23 AM
  #226
kwest's Avatar
Hey rodney, Im gunna need a new o-ring for my nozzle. and also, whats the pros/cons of going with a differnt sizze nozzle...
Old Feb 18, 2009 | 01:56 PM
  #227
AIS's Avatar
AIS
Non Authorized / Non-Supporting
Give me a call directly at 801.447.2559 ext 2 so we can go over this.
Originally Posted by ColeJJones
Rodney thanks again for the super fast shipping and superior Meth kit you sell. the trunk kit conversion kit is sexy. cant wait to install it on my back seat delete!
back seat for the trunk kit...
trunk conversion kit
brackets and nozzle
Yeah sure thing. By the way. Who took those pics? I thought you were over in the sand box playing still.
Old Feb 18, 2009 | 02:38 PM
  #228
ColeJJones's Avatar
Bannned
my wife took the pics
Old Feb 18, 2009 | 07:06 PM
  #229
AIS's Avatar
AIS
Ahhhh, I figured so. So what the hell. Does everyone get internet out there now?
Old Feb 18, 2009 | 11:35 PM
  #230
ColeJJones's Avatar
Bannned
yea its the MWR...
Old Feb 18, 2009 | 11:40 PM
  #231
ssmokin's Avatar
slow down cole. you're starting to sound like someone else i know....
Old Feb 18, 2009 | 11:46 PM
  #232
ColeJJones's Avatar
Bannned
lol... where is Angelo?
Old Feb 22, 2009 | 11:01 AM
  #233
mexi_loco's Avatar
for anyone with an Injen intake on a 2.0 LSJ, how bad would it be to tap the rubber coupler that connects the intake to the throttle body?
Old Feb 22, 2009 | 12:37 PM
  #234
AIS's Avatar
AIS
It can be done but will require the use of another fitting to do it. Why not just drill and tap your cold air pipe and be done with it?
Old Mar 2, 2009 | 06:47 PM
  #235
AIS's Avatar
AIS
Let me know if you have any other questions.
Old Mar 2, 2009 | 07:16 PM
  #236
mexi_loco's Avatar
well, to be honest, there's more space around the rubber coupler in my car than around the area of the intake that will be tapped. I figure if I tap the line into the coupler, I could do a better job of hiding the line. But I might as well drill the intake. Thanks! And thanks, btw, for walking me through the wiring.
Old Mar 9, 2009 | 07:42 PM
  #237
AIS's Avatar
AIS
Let me know if you have any other questions or how i can help.
Rodney
Old Mar 22, 2009 | 10:12 AM
  #238
Maxim_X's Avatar
Are nozle sizes adjustable with your kits. I couldn't find different rate nozzles on the sight.
Old Mar 25, 2009 | 12:44 PM
  #239
AIS's Avatar
AIS
Yes. With each order received on the site you must fill out our questions related to your application. We then determine your nozzle(s) size based on this info.
Rodney
Old Mar 30, 2009 | 07:47 PM
  #240
mexi_loco's Avatar
hey rodney, is there anyway you can send me a pdf file of the instructions booklet?
Old Mar 31, 2009 | 12:58 PM
  #241
SCcobaltSS's Avatar
I bought my devils own universal kit about 1.5-2 months ago and it has failed twice already, I am having trouble with the pressure switch mounted to the pump.
First time devils own was really responsive and sent me a replacement part for it and I was happy.
Now it has happened again and I have not been able to use my methanol for about 2 weeks. I emailed them and got a response right away, I kept asking questions trying to figure out how I can fix this. Well I sent an email to them showing where I installed it and I didnt get a response back for about 3-4 business days. (Even though I sent the same email everyday so they would respond)
To sum up the emails sent, they say its because of the heat under the engine, even thought they say the part can work up to 200 degree's and people have put it under their hood before, and they suggest that I move the pump to the inner fender or on the bumper.
So if I move it I may have to get more fluid line becasue I cut the line to exactly where I needed it and I loomed the wires to the relay and psi pressure switch so now I have to extend all the wire.. This is crap.
Now that I vented a little, my question is, does anyone else have this kit or install a kit in the engine bay and have this problem with the pump? Does it really get over 200 degrees under the hood? If it is mounted on the bumper or in the inner fender will possible water splash hurt the pump?
Old Mar 31, 2009 | 02:13 PM
  #242
Area47's Avatar
Rent me! per hour
same pump. get a pump that does not have the pressure switch built into the pump. it will be fine
Old Mar 31, 2009 | 04:19 PM
  #243
SCcobaltSS's Avatar
Ok I will look around I guess, that means my pump I got with the kit is crap and cant be used... Who makes one?
Old Mar 31, 2009 | 09:10 PM
  #244
Area47's Avatar
Rent me! per hour
they are all made by the same company. more or less
Old Apr 1, 2009 | 02:25 PM
  #245
SCcobaltSS's Avatar
I only see the 250psi pumps that only have the wire going to the rear (power to the pump) and not from the top to the rear. Can I assume that is the one needed?
Old Apr 4, 2009 | 03:52 PM
  #246
FF_ace's Avatar
^^^^ hey what part of phx are you from?
Old Apr 6, 2009 | 02:47 PM
  #247
CobaltSC06's Avatar
hey AIS, I have tried contacting you a few times via emails and PM. I placed an order march 25th and it's still "Pending". I need this asap
Old Apr 6, 2009 | 04:06 PM
  #248
SCcobaltSS's Avatar
I am Actually in south Scottsdale. I few miles north of Scottsdale and the 202. You?
Old Apr 6, 2009 | 07:21 PM
  #249
mexi_loco's Avatar
don't mean to play the devil's advocate or anything, but I do believe they get busy during racing season. Try leaving a voicemail with Rodney. He's usually very good about returning your call.
Old Apr 7, 2009 | 04:29 AM
  #250
CobaltSC06's Avatar
thanks for the heads up, that was the next step. I was just wondering if I had caught them on a busy time of year.
