Lets see your engine bay!
The piping is a little harder to do than it looks. The only part that wasnt modified is the part that says Dejon. The 90 that goes into the turbo had to have a section added onto it and then repowdercoated.
incase you guys are wondering.. you can fit;
two wheels
four tires
transmission
intermediate shaft
fuel rail
injectors
stock header
sway bar endlinks
h/e
wakeboard
wakeskate
all inside a cobalt without taking out any seats.
two wheels
four tires
transmission
intermediate shaft
fuel rail
injectors
stock header
sway bar endlinks
h/e
wakeboard
wakeskate
You should lose the breathers and get 2 -10an fittings. One to weld in place of the rear breather... and then other to replace the Oil Filler Cap.
Oil Filler Cap: Valve Cover Adapter, AN Valve Cover Adapters: Metco Motorsports
Weld-in Replacement for the Rear Breather: EXTREME PSI : Your #1 Source for In Stock Performance Parts - Weld Bung : -10 AN Male
Trust me. I've ran a breather on the rear... and am currently running a breather on the Oil Filler Cap. Just do it the right way like I just mentioned. I'm in the process of switching mine around now.
thanks dude.ill keep that in mind. ive ran those breathers for quite some time actually. even before i blew it up last haha. havent noticed much blow by but i always keep things really clean under there anyway. but thanks again for the tips
That's because you're still on the M62.
You should upgrade to a nicely sized turbo. I've got a Turbo Mani, Downpipe, and Wastegate w/ dump that I'm looking to sell. Would put that built motor to use.
But yeah, when I first turbo swapped, I just ran the rear breather... and I ended up with oil all down the back of my block. Now, with a larger turbo... I have to run the big breather on my Oil Filler... and now my Valve Cover/Spark Plug Cover is covered in oil. I've got either some leaky rings or some leaky valve seals. Bitch moves out though...
