The Painted Brembo's Thread...
Old Jul 9, 2015 | 04:29 PM
  #226
NeedHelp's Avatar
I painted my Brembo red yesterday.. Let it dry all night and all day long. Today I put the sticker on and applied a clear coat. When I applied the clear coat the paint started to flake and crack.. I'll probably need to wash them off and do it all over again.
Anyone know why this happened ?
Old Jul 9, 2015 | 04:37 PM
  #227
yellowsupercharged06's Avatar
uhhh your clear coat is paint stripper ??
Old Jul 9, 2015 | 04:55 PM
  #228
NeedHelp's Avatar
Haha no it's a clear paint for engine..
I'm not sure flaking is the right word, there's just cracks everywhere
Old Jul 9, 2015 | 05:43 PM
  #229
crispino's Avatar
Sounds like you used different based solvants.. make sure they were the same.. ie: both lacquer based etc
Old Jul 9, 2015 | 05:51 PM
  #230
NeedHelp's Avatar
They were both engine paint of the same brand.. Think they cant be different based solvant ? I'll look for it later, thank you !!
Old Jul 10, 2015 | 06:48 PM
  #231
ATOMbomb's Avatar
How did you prep before you painted. How did you spray paint them? Did you leave enough time before coats. Maybe sprayed too much for each layer?
Old Jul 11, 2015 | 06:43 AM
  #232
NeedHelp's Avatar
Waited 15-20 mins between the three layers of red.. And then waited almost 24h before the clear coat.
They were brand new calipers so the only thing I did to prepare was sanding them.
Maybe it's just bad quality paint.
Old Oct 24, 2015 | 02:40 PM
  #233
Pitbull2o08's Avatar
Hey guys, can anyone recommend me a good person to rebuild my brembos? THanks
Old Oct 24, 2015 | 02:42 PM
  #234
I saw a how to on here not long ago it looked pretty simple to do
Old Oct 24, 2015 | 08:35 PM
  #235
Thanks man. I found it. Just need to find the dust covers on rock auto. Anybody see them? lol
Old Jan 29, 2016 | 07:38 PM
  #236
Manicmechanic's Avatar
Just wanted to add my .02, I rebuild Brembo's for Charger SRT8's and wanted to share a few things. First the Brembo stickers, the one's found on Ebay are generic or don't always fit the application size wise, I had to mic a set and then have them made to spec. At the same time I used that to an advantage and ordered reflective ones from reflective concepts. I have had great success using Ceramic based paint for longevity and also recommend a synthetic brake fluid to prevent paint damage from any fluid getting on your freshly painted caliper! I hope to add a pic soon but PB is down for maintenance at the moment.
Old Jan 29, 2016 | 08:27 PM
  #237
Powell Race Parts's Avatar
clear is not compatible with base coat.
rebuilding Brembos is easy once you have done it a few times. The piston and seal kits and dust seals are so expensive its cheaper to buy new calipers on amazon
The cross over pipe is not sold, if its damaged you have to make it. GM bubble flares are very difficult.
corrosion screws the bridges, the pin sockets and the banjo bolt surface.
buy new.
Old Feb 5, 2016 | 10:02 AM
  #238
freakta's Avatar
My paint faded very badly. Still looking for a good pink. Any suggestions
jmdubose202
Dec 29, 2015 05:06 PM
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
camaromanss1992
Oct 1, 2015 10:51 PM
riceburner
Sep 26, 2015 12:57 AM
