Painting my calipers
just painted mine over the weekend, while changing rotors and pads. used vht for the brackets and duplicolor kit for the caliper.
https://www.cobaltss.net/forums/memb...10-1449-16935/
I couldve walked over there from WI with a can of spray paint and had this done already in the time it takes you to decide this.. who would've thought painting calipers was so difficult
it takes 3-5 hours depending on the system you yse and how well you prep.
i took a good amount of time with g2 paint.
jacking my whole car up
wheels iff
brake cleaner/wire brush everything
mask off everything around the caliper you can as good as possible
taking your time to do solid light coats
~4 coats and i painted my engine mount while i was at it with the leftover
let it sit about a day longer if possible
good to go
wheels iff
good to go
wheels iff
good to go
wheels iff
good to go
took about 6 hrs, only since one came out bad so had to sand and redo it. advice is make sure you have the surface clean!! otherwise it'll start spotting. Take the extra time and do a good job. The quality of a good prep job in the end will definitely be worth it.
I did the brembo swap on my car and just painted the rear calipers the same color that the brembos came in
DANRICKARD
Oct 1, 2015 12:08 AM
QuickSilver_SS
Sep 17, 2015 05:38 PM
