Remove VHT "Night Shades" Paint?
Old Mar 8, 2011 | 09:10 PM
gone_in_10_sec's Avatar
Arrow Remove VHT "Night Shades" Paint?
Like the title says.. does anyone know how to remove the VHT "Night Shades" paint from the tail lights and the front lights? Is there a chemical or cream that does this?
Old Mar 8, 2011 | 09:13 PM
Render2009's Avatar
paint thinner?
Old Mar 8, 2011 | 09:14 PM
HyperMuffin's Avatar
Try some mineral spirits or paint stripper? Mineral spirits will be safest on the plastic lenses. If you use a stronger paint stripper just don't leave it sit on the plastic for very long. I used mineral spirits to get mine off. Sanded it down a bit as well since I had many layers. Then I fine sanded the lenses and clear coated it and it looked factory again.
BPacak's Avatar
Vtec Rep
laquer thinner
Old Mar 8, 2011 | 09:17 PM
ssblackstealth's Avatar
corn gas ftw....
laquer thinner or gas, but the thinner will prolly be cheaper lol
Old Mar 8, 2011 | 09:39 PM
i tested paint thinner in a very small area, it ate the plastic like acid.. Mineral spirits - which one and which sand paper grit? My lights have 9 lite coats of VHT and 3 heavy coats of Clear..
Old Mar 8, 2011 | 10:31 PM
SlobatLT's Avatar
yeah thinner eats plastic, i cant believe they told you to do that.lol
Old Mar 8, 2011 | 10:33 PM
bratboy0007's Avatar
Use acetone. i have used it on my cars several times, works wonders.
Old Mar 9, 2011 | 06:31 AM
this doesnt eat plastic, but damn never everything else.
Old Mar 9, 2011 | 06:49 AM
C_A_D88's Avatar
use some m.e.k
thatll get it off in a hurry
Old Mar 9, 2011 | 07:01 AM
aweadSS's Avatar
Laquer thinner but it's gonna dull it down use a buffer when ur done and will look brand new
Old Mar 9, 2011 | 07:58 AM
Rambotk3's Avatar
x2 thats what I did and you can't tell I ever had them done!
Old Mar 9, 2011 | 12:51 PM
Brizzal's Avatar
good old wet sanding and polishing compound
Old Mar 9, 2011 | 01:02 PM
corn gas ftw....
dont leave the thinner on the plastic lol if any gets on the plastic wipe it off soon
Old Mar 9, 2011 | 01:09 PM
gray ss/tc's Avatar
any of those will work.. just ploish them when ur done
Old Mar 9, 2011 | 01:15 PM
MastaShaKe_88's Avatar
Use a hammer an then 2 coats of clear afterwards
Old Mar 9, 2011 | 01:25 PM
WA9260SS's Avatar
Start with something like a 600 grit and see how it's going. Once it's all off and you didn't go below 400 grit you might be able to clear. I would get it up to 600 then clear. Will look brand new if you use automotive clear. Not sure about rattle can.
If you don't have access to auto paint, I'd say get it up to 1000, then a light dynabrade, then you can wheel it out.
Old Mar 9, 2011 | 01:33 PM
revolution607@yahoo.'s Avatar
DO NOT USE PAINT STRIPPER! lol
Old Mar 9, 2011 | 01:35 PM
Red08Sport's Avatar
CARB CLEANER works great. i used it. just wipe it off as your spraying it.
Old Mar 9, 2011 | 03:10 PM
mikko's Avatar
Goof off! Came out perfectly just have to b patient and dont let it touch the paint of the car.
Old Mar 10, 2011 | 08:55 AM
lilredg588's Avatar
X2.used it an works perfect.takes it off easy as hell an safe on the lights
Old Mar 10, 2011 | 09:20 AM
StevoElSupremo's Avatar
man I cant believe how many people dont know this...
Somehow..Nightshades is its own remover, just spray that **** on there nice and thick, let it sit for a sec then scrub it good, the stuff comes right off.
Old Mar 10, 2011 | 10:55 AM
Spanky's Monkey's Avatar
this is true. test it out if you don't believe him.
Old Mar 10, 2011 | 11:04 AM
C_A_D88's Avatar
Found thAt to be true with most rattle can paints
Old Mar 12, 2011 | 01:37 PM
gray ss/tc's Avatar
yup
brickloaf
Show & Shine
56
Jun 18, 2019 12:51 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
riceburner
Sep 26, 2015 12:57 AM
