Spray Paint Rims
Here ya go!
I plasti dipped my wheels yesterday took them to a car wash and they are still good. I live in Tallmadge Ohio near Akron right down the street from Summit Racing. Here are a couple of photos taken of my car with the plasti dip wheels. I like it and I can always peel it off later if I want a change.
http://i330.photobucket.com/albums/l...ackwheels3.jpg
another
http://i330.photobucket.com/albums/l...lackwheels.jpg
another
I only cleaned my wheels with a cleaner and then sprayed away. If I had all 4 wheels off together it would have taken me about an hour. Then Give it about another hour to dry or if its hot out you could probably just take off after you put them back on. Let me know if you have any more questions. It does not chip off and you can wash your car with a sprayer. I did on the same night after I painted them.
If you want to possibly undo it, the plastidip works, but other than that the **** sucks. Doesn't bond nearly as well and discolors easily with use, hated the person whom I bought my Ion rims from for using it.
Also, I like the playing cards, but save yourself some time and use notecards, 50/50 overlap. Works like a charm.
i just sanded mine with fine sandpaper and did like 3 coats each. **** looks amazing, i had semi gloss black first. then bronze. now full gloss black and i love it now.
straight murdered bruhh..
I think my wheels turned out fairly well for spray can. Although it took me about 2-3hrs per rim to sand and paint.
http://www.flickr.com/photos/dandaman15/5066529332/http://www.flickr.com/photos/dandaman15/5103682100/http://www.flickr.com/photos/dandaman15/5103088473/
^^^ lmao that sig is rediculous...
An im thinkin bout jus spraypaintin mine to save some mulah or if all else fails, ima jus take a piant brush to it....
jus like the video games
In order for the plastidip to be able to peel off legit, you have to put multiple thick coats of it on. If you don't, then when you try to take it off, it'll just tear into small pieces and it'll take forever to get off your wheel. Believe me, you have to mess up to learn the correct way.
