Autocross and Road Racing Road racing is not “street racing”
Help
Old Jan 21, 2018 | 01:21 PM
frankkonetzka's Avatar
Help
i am new to this forum and i need help i have a 2005 cobolt ss and i pulled everything out of it to make a chump endurance racer all the interior including air bags and i have lost my ground to the crank relay i can jump it but it only stays running for 10 seconds then dies any help would be appreciated
Old Jan 21, 2018 | 02:41 PM
Henry3959's Avatar
Where are you jumping to start it? At the crank relay, 30 to 87?
Old Jan 21, 2018 | 02:56 PM
Henry3959's Avatar
Your PCM commands the ground to the relay. To command that you need the following.
Good 10 amp IP Ignition fuse if you have a manual
Good 10 amp back-up fuse if you have an auto
Working Clutch / PN switch
That will send ign. voltage into pin 54 of the PCM and feed ign. voltage to the crank relay winding
The PCM will make a ground on the crank relay when it sees the command from the BCM to the PCM that you are in the crank position.
shooK on3
Jan 9, 2009 06:51 PM
brett5
Jul 12, 2007 12:02 PM
Tung
Apr 7, 2007 07:33 PM
