BuyHIDs.com BuyHIDs.com is a Supporting Vendor of CobaltSS.net
Contacts: mkulrey13
RETROFIT Install questions and support!
Old Sep 3, 2010 | 09:10 PM
  #51
kidcrash603's Avatar
Almost forgot, if you put the torx bit on a 1/4 drive socket wrench, you can get it off without removing the reflector too.
Old Sep 3, 2010 | 11:23 PM
  #52
DoMiStIc_RuSh_06's Avatar
Ok I got the screw removed.... Thanks for the help. Gotta give the lights one more coat, paint the reflectors , then clear everything and then just wait for the retrofit kit.
Old Sep 5, 2010 | 02:32 PM
  #53
hook's Avatar
How to remove deflector tab
Locate tab
Locate where tab is attached
squeaze tab till forks touch eachother
Remove
Kinda blurry but the end of tab is the forks
Tab
Tab removed from housing
Old Sep 5, 2010 | 02:40 PM
  #54
hook's Avatar
Originally Posted by skidizzle105
This is exactly what I was wondering, could you tell me which wires they are. Could you post up a picture?
Thanks for the reply!
ill get pictures up asap guys
Old Sep 5, 2010 | 02:59 PM
  #55
hook's Avatar
How to run fogs into running lights so they stay on with hi and low beams as well as only running lights.
Remove Headlight
Tabs, I have found a flat head works great
Headlight bolts (10mm)
Headlight Bracket 4 10mm blots
Locate fog light
All you need from a fog light is a ground and a power. I cut my wires out and just ran them as following
Blue is ground. (aftermarket wires factory color is different
Factory wiring color is brown for running lights. tap your power into this
fog light into running lights
tape up and reinstall and enjoy
Old Sep 5, 2010 | 03:02 PM
  #56
hook's Avatar
Factory wiring color is brown for running lights. this is also perfect to tap your halo ring into btw
the blue wire is the blinker if you would like for your halos to flash with flashers!!!
Old Sep 5, 2010 | 07:09 PM
  #57
Mines all apart and painted, just waiting for my Retrofit kit to come in
Old Sep 6, 2010 | 02:43 PM
  #58
JoshuaVnyrd1817's Avatar
Very nice pics Hook. A lot of people will find these helpful.
Old Sep 6, 2010 | 08:46 PM
  #59
hook's Avatar
i hope so. alot of people have helped me on this site.
Old Sep 7, 2010 | 07:09 AM
  #60
mkulrey13's Avatar
Directions are included with the retrofit kit guys :P
Old Sep 7, 2010 | 08:34 AM
  #61
However, I'm sure these pics will be helpful regardless! Thanks Hook!
Old Sep 10, 2010 | 08:45 AM
  #62
iboost's Avatar
Now I know this isn't for your retrofit kits per say...but they are the G3 kits from 3b specs. I got them mounted and everything, but they came with this wiring harness...
Obviously that plug to the "headlight socket" isn't gunna work. Is there a way I can either rewire it or something to make it work for me?
Old Sep 10, 2010 | 09:05 AM
  #63
The easiest thing would have been to order H4/9003 hids, since that is what your harness is for. It might be possible to cut off that connector and wire in the correct one, but that means finding the correct one.
Old Sep 10, 2010 | 09:12 AM
  #64
iboost's Avatar
i got the kit off their ebay website labeled for the cobalt...I don't know where the hell that connector was "supposed" to go...
Old Sep 10, 2010 | 11:08 AM
  #65
mkulrey13's Avatar
Guys, the installation manual will be online tonight. It will be located under the Installtion page on our website!
Old Sep 10, 2010 | 11:31 AM
  #66
iboost's Avatar
is there a way that I can buy your guys relay harness for the retros I have already?
Old Sep 10, 2010 | 01:53 PM
  #67
JHans5774's Avatar
Subd
Old Sep 10, 2010 | 08:52 PM
  #68
WickedSS2005's Avatar
Project "Black Sapphire" is under way!!!
Old Sep 10, 2010 | 09:16 PM
  #69
morelos704's Avatar
my harness looks very similar to this with the retrofit kit i ordered
Old Sep 10, 2010 | 11:29 PM
  #70
DETAILED INSTRUCTIONS WITH PICS!!!
http://buyhids.com/pdf/DIY_Retofit.pdf
Old Sep 11, 2010 | 12:16 AM
  #71
jrzdude's Avatar
sub'd...
Old Sep 11, 2010 | 12:20 AM
  #72
i've got the importance of taking the daytime running lights fuse out, but i was wondering why? (i know maybe a stupid question)
Old Sep 11, 2010 | 12:27 AM
  #73
Think about how many times per day you start your car. Getting gas, going to the store, running errands, etc.
If you leave the DRL fuse in, you are asking your HIDs to fire every time you start the car, which will seriously limit their life.
Old Sep 11, 2010 | 12:33 AM
  #74
OK, so then there is no way to wire the halos to be on all the time? (other than to a voltage source from the fuse box) I like some light on (black car rural roads, so many mother f***ers have pulled out in front of me)
Old Sep 11, 2010 | 01:48 AM
  #75
morelos704's Avatar
will silicon be good enough to seal the headlights back up or do i need something else?
