BuyHIDs.com BuyHIDs.com is a Supporting Vendor of CobaltSS.net
Contacts: mkulrey13
RETROFIT Install questions and support!
Old Sep 18, 2010 | 02:49 PM
  #151
CudaJoe's Avatar
Lightbulb Issue with retro's solved.
I had no issues getting mine put in and lit up fine. I bought the pre-maid retro's so it was easy for me
I did not hook up the halo's yet, im not sure if I will. I wanna see some of the ideas the peanut gallery comes up with before I try something.
At night I adjusted the lighting using my garage, everything looked good except for the cutoff line was alittle funky, makes an obtuse 25 degree angle to the right of the cut off line for both projectors. (at least that doesnt point at the oncoming traffic.) started to drive and then after 2 minutes I noticed my right projector started slumping down. then it was basically pointed at the ground.
Today I took the head light off and found that the adjuster screw popped out of the reflector housing cap. I went ahead and took some vice grip plyers and held the cap in place while I used a screw driver on the adjuster screw to force it back into socket. Worked! Now as to why the screw popped out in the first place, I dont know... hopefully not a defect in the headlight assembly. We will see tonight after I give the car a ride to a friends house.
Here are some pics.
problem found.
Tools to deal with problem.
Problem delt with.
Old Sep 18, 2010 | 03:30 PM
  #152
mkulrey13's Avatar
^ could of had a nice jolt from shipping. which loosen it.
Old Sep 18, 2010 | 03:36 PM
  #153
mkulrey13's Avatar
Originally Posted by WickedSS2005
My lights have been fine for a week until last night. One of the halo's went out. Wiring is secure, and nothing is loose... Email sent
Funny thing, my friend asked "did you wire up my new lights to wink at me?" haha... nope, but it was only one halo.
Email replied
Old Sep 18, 2010 | 03:47 PM
  #154
CudaJoe's Avatar
The results.
up close.
fogs and projectors on.
4500K light out put.
All and all they were a good purchase. Looks like alot of messy glue work in the back and I found a finger print or two on the reflector housing, but if I were making these im sure there'd be alot more, lol.
Pulled the DRL fuse as well (honestly the greatest mod any one could ever do!) lol.
My fogs stay on now whenever I turn the car on, strange huh? and I don't have to worry about the headlights being on all the time....
Old Sep 18, 2010 | 03:57 PM
  #155
zerosk8ter83's Avatar
haha i have the same promblem but it was solved with the help of alittle glue =)
Old Sep 18, 2010 | 08:10 PM
  #156
G Speed's Avatar
Very Odd Problem...
Timeline
Cutting Grass started to Rain
Decided to install the fogs
Rain Stopped
Continued with Fog Installation
Got the fogs working with relay harness
Grass was dry, went to cut
Had Dinner
Dark out now
Went to check out the fogs
Driver one works... Passenger doesn't...
Switched Hid Bulbs Same thing
Switched Ballast Same Thing
Plugged the passenger ballast directly to car, passenger side works...
Not Cabling
Not Ballast
Not Bulb...
What the hell could of broke? How could the relay break?
Old Sep 18, 2010 | 08:18 PM
  #157
TommyP's Avatar
AWD > FWD
How do your fogs always come on? I wish mine did
Originally Posted by G Speed
Very Odd Problem...
Timeline
Rain Stopped
Had Dinner
Dark out now
Not Cabling
Not Ballast
Not Bulb...
did your relays get wet? That would easily cause this.
Old Sep 18, 2010 | 08:21 PM
  #158
G Speed's Avatar
Not Possible, I was in the garage working on it when it was raining lol
The relay still get's the driver side fired up, just not the passenger...
Old Sep 18, 2010 | 08:37 PM
  #159
TommyP's Avatar
AWD > FWD
well that was the only thing I could think of.
Old Sep 18, 2010 | 09:16 PM
  #160
G Speed's Avatar
I also noticed when all plugged in with relay.. I noticed that the driver side is flickering a little bit?
Is't possible my battery could be weak?
Old Sep 18, 2010 | 10:17 PM
  #161
LS6Rally's Avatar
check your ground
Old Sep 18, 2010 | 11:24 PM
  #162
G Speed's Avatar
Originally Posted by LS6Rally
check your ground
The Driver, side I used the common ground...
The Passenger, I found a hole right beside the intake tube...
I actually tightened it, still nothing
Edit: If kidcrash or mkulrey don't respond before I get up in the morning, then I will post some pics of the setup
Old Sep 19, 2010 | 12:45 AM
  #163
its prom your power source where you hook it up to the battery.try messing with those
Old Sep 19, 2010 | 02:13 AM
  #164
morelos704's Avatar
i was just noticing this myself on my way home from work tonight
Old Sep 19, 2010 | 02:22 AM
  #165
davebetterthanu's Avatar
Got my projectors and housings painted today hopefully the install goes smoothly tomorrow
Old Sep 19, 2010 | 02:25 AM
  #166
Maupin SS/SC's Avatar
wiring mine up tomorrow afternoon aswell we will see how it goes we can ask eachother questions :P. gotta reseal them after i make sure cutoff is level...
Old Sep 19, 2010 | 08:26 AM
  #167
G Speed's Avatar
Sorry for **** quailty pics
Passenger Side - First Pic you can see ground
Driver Side - First pic you can see ground
Relay & Other Stuff..
End Result
Old Sep 19, 2010 | 10:21 AM
  #168
G Speed's Avatar
Update...
Bad Ground Location ^^ Do not Use lol
Old Sep 19, 2010 | 10:30 AM
  #169
CudaJoe's Avatar
Actually I dont know now. They stayed on the first night, they dont do it anymore now. wierd!
Old Sep 19, 2010 | 11:23 AM
  #170
boosted20's Avatar
The fog light kit that I bought with my retrofit kit has a male plug coming off of the h11 HID bulb so how am I supposed to plug that into the stock harness?? The plug that I have coming off of the bulb looks like the same yellow male plug that plugs into the ballast..
Old Sep 19, 2010 | 01:58 PM
  #171
G Speed's Avatar
Update...
Update Part 2:
So everything is mounted and everything works, both grounds are on fender bolts etc.. etc..
But my Driver side fog is still flickering, and the ballast is making a ticking sound
Old Sep 19, 2010 | 02:14 PM
  #172
Woo got the halos hooked up to a switch
YouTube - Green Halos
Old Sep 19, 2010 | 03:36 PM
  #173
nice mine are to the fogs theyre working just gotta get the projos on...i need to switch wiring idk what im doing at the moment im bored. got a concussion yesterday i think so im so out of it
Old Sep 19, 2010 | 03:52 PM
  #174
dayhoff35's Avatar
aiming
i think my retros aiming is messed up i messed with them a little and passenger side one seems fine but the drivers side one looks weird
does it just need to be moved up more?
Old Sep 19, 2010 | 04:01 PM
  #175
TommyP's Avatar
AWD > FWD
Looks to me like the passenger side is crooked and the drivers side is good.
