Calgary - random talk thread
wow talk about **** retentive word blocker;
if you would have quoted me the word would come up;
spacers or s_p_a_c_e_r_s
sorry, but that's a BIG fail for CSS.net
LINK for pic
EDIT:
I dunno what happened there, when I first posted it, it looked ok, then I came back, saw them censored, typed it above, and it didn't get censored; so I edited the initial post, deleted and retyped a single letter from each censored word...
now they all appear ok!??!?
LINK for pic
EDIT:
maybe I missed something - I understood from your posts that a 2 gauge pillar was being added, but that's all I read.
Are you not still under warranty? Unless you beat the hell out of it, it should be covered, and even still, our dp's are all under a recall.....
I have the stock antenna, I may have misunderstood you before. Is your stock antenna base a different size than previous years? If so, and if your shorty will fit the base on my car you can have it if/when I get it shaved off
I bought a set of BFG Drag Radials (the ones Bluecobalt99 wants to borrow) that came mounted on SS/SC rims;
HERE
(or THIS related post)
I test fitted a set of SC rims about a month after buying my car under the premise of having a second set for winter duty, to find that it's so close it's not even funny;
I'd wager that 3mm would do it, but it's probably better to go with 5mm or even 2x3mm just because.
FYI: The other 17" delta platform rims that clear our calipers - I needed to do a the old piece of paper trick to verify that there was clearance between the back of the rim and the front of the caliper... it's just that close.
I since have acquired a full second set of SS/TC rims for winter duty (one of which I just got back after having it repaired/straightened/repainted a couple days ago).
these are the ones i was refering to that i will buy
Hoosier DOT Drag Radial Tires - SummitRacing.com
this would be to make the SS/SC wheels clear our huge calipers.
HERE
HERE
I was just figuring if you're getting a DR, why not at least have something in the 235 width size...
Oh okay, I thought you already had the shorty but was the one that screwed onto the 6mm, and I was saying if you wanted mine, because that's the size I think mine is, that you could have it when I get around to getting it shaved off, then you just need to swap the 6mm one I have with the 7mm one you have and install the shorty that you had. Alright then, sorry I couldn't help
The plan right now is to meet at Race City, watch some racing, and maybe go to BP's afterwards.
