Calgary - random talk thread
Old May 20, 2011 | 10:45 AM
  #17476
Projekt's Avatar
hello fellow calgarians. figured i would see if there is interest for this here
i know most of you probably do not like katy perry, but maybe a girlfriend or sister wants to go to the concert.
I bought 2 tickets when they went on sale because my girlfriend wanted to go. now she has a new job and can not book time off for it. they tickets in the area i bought them for are going for 200 ish on kijiji. However i am into them for like 140 (IIRC). Since i respect this community i would sell them for what i paid.
If anyone is interested or knows someone who would be interested or can spread the word for me that would be great. Id rather deal on here then strangers on kijiji.
Thanks all!
Old May 20, 2011 | 10:48 AM
  #17477
Sylver01's Avatar
When's the show?
Old May 20, 2011 | 11:03 AM
  #17478
Projekt's Avatar
july 16th saddledome. tickets for the show are sold out.
Old May 20, 2011 | 11:05 AM
  #17479
Sylver01's Avatar
I might know some people interested. I'll get back to you
Old May 20, 2011 | 12:20 PM
  #17480
soundjunky's Avatar
Four pages!?
I have to scroll/read through four pages of your posts since last evening @ 4:30!
Originally Posted by thedude411
How can u tell when u need to replace rotors. Mind have a helluva lip on them but that might mean dick all
generally, there should be cast into the backside of the rotors "hub", a "min" width measurement;
you would need to use a caliper to verify how thick the rotors are;
this assumes even rotor wear btw.
Originally Posted by Baltbitch
@Mark I'm having a small dinner for Ella on Tuesday. Cake food etc... you are more then welcome to come as I have Khloe, and I'm sure Ella would like to see her. I also don't live far. You are more then welcome to come to her birthday on June 4th, and Jonathan you are too even tho you have not really met Ella. Khloe will be there. So will STEVE! and JON if they know whas good for them
hey thanks for the invite!
Originally Posted by CanadianCobalt
FYI a shorty raises power up top (and beyond what we rev to to make it really effective), a long tube is on the bottom end (and sounds awesome) and a turbo doesn't use a header. Just a manifold to it and downpipe off the turbo.
Joel
Joel, you have that slightly backwards;
Both will actually hurt your off idle power, but generally speaking,the shorty will give you more lower rev power, while the long tube would seem to make the lower end seem a bit soft, but give you more up top;
Think of it this way;
The shorty keeps the theoretical restriction point closer to the engine, while the long tube moves it further (this is a generalization becasue normally a header will grossly outflow the exhaust system it's attached to);
You need a degree of restriction, otherwise the air will stall out;
The restriction creates backpressure, and in turn necesitates airflow;
Since the shorty header is shorter, it has less CFM capacity, and will "fill up" quicker, where as the long tube header has a much greater CFM capacity, and will take longer to "fill"...
Hopefully that makes sense.
In regards to which is better with turbo, this is entirely dependent on the configuration, and turbo's intended location;
Generally turbos are kept closer to the exhaust port top aid in quicker spooling - the further it sits from the exhaust port, generally means the longer it takes to spool up...
As pointed out, generally a remote mount turbo negates the need for any cooling, as the air has a chance to cool on route back to the engine.
That one should make sense.
happy long-weekend-friday!!
Old May 20, 2011 | 12:25 PM
  #17481
DiabeticKripple's Avatar
Hmmm everyone seems to have it backwards. I thought it was short down low, long tube up high and then I found a thread on it and the guy asked if short is down low, and 3/4 of the people said it was up high
Old May 20, 2011 | 12:38 PM
  #17482
soundjunky's Avatar
There are several subjects in which peole in the "tuner"/Cobalt crowd seem to have it backwards, and try to say that conventional logic isn't so.
When you have a larger diameter exhaust (and a header of one type or another essentially equates to a larger exhaust right off the port), this makes it so that your exhaust will theoretically outflow your engine up to a specified RPM;
Once your engine makes more exhaust for a given period of time than your exhaust can flow, you've reached the point of restriction;
Once you've reached this point, your engine will not be able to make much more power - generally this is where the power band starts diving off....
Keep in mind I'm leaving out many other factors that tie in - but I'm trying to tell this in a simple fashion that should make it understandable...
Jordan, you can trust me, I have no reason to give you bad advice.
But hey, it's your call... just don't say I told you so if you end up with an exhaust that kills the bottom end power that your car's engine was designed for
If you want, I could actually show you some stuff so you can see for yourself what works...
Old May 20, 2011 | 12:41 PM
  #17483
jrmotosports 88's Avatar
on tues? bish? i think we are in.... i bring the truck too.... pm me the adress....
Old May 20, 2011 | 12:42 PM
  #17484
Kris had one on his car and said it was awesome. And no I won't blame anyone, I'll just put the stocker back on, and sell it. But I'm confident it will help
Old May 20, 2011 | 12:54 PM
  #17485
thedude411's Avatar
Ah ha. I thought the long tubes were better for the upper power band. All the racing headers are like ultra long for corvettes and stuff. Soundjunky is definitely correct.
Old May 20, 2011 | 01:26 PM
  #17486
whats everyone doing today? i gotta cut a tree down
Old May 20, 2011 | 01:35 PM
  #17487
soundjunky's Avatar
probably family stuff over here...
Old May 20, 2011 | 01:43 PM
  #17488
Baltbitch's Avatar
Residental Bish.
Laundry. Attempting to get my house nice and clean.
Old May 20, 2011 | 01:48 PM
  #17489
im stuck at home without my car at least its at the sop right now getting my summers on. i might do a tranny flush when i get it back. i dont think the fluid has ever been changed. also i need an oil change lol
Old May 20, 2011 | 02:11 PM
  #17490
Projekt's Avatar
Shorty. Low end. Long tube. High end.
Like John said.
Old May 20, 2011 | 02:14 PM
  #17491
i want low end cause my car wont go until 4k and it takes forever to get there
Old May 20, 2011 | 02:27 PM
  #17492
CanadianCobalt's Avatar
I'm working as per usual,
and what you guys are saying is owning what I've learned about headers
I was under the impression that the lengths of the primaries were chosen for the RPM band of the engine, and you could "rock" the torque band higher and lower with longer and shorter primaries. Lower RPM was long and higher RPM was short. This of course coupled with the diameter of the primaries dictates a lot too.
Also, long tubes have the advantage of being able to scavenge while the shorty's cant. Which is more of a big deal for N/A engines rather than SC/TC.
Joel
Old May 20, 2011 | 03:11 PM
  #17493
Baltbitch's Avatar
Residental Bish.
Calgary
baltbitch spam! Anyone not doing anything click, and vote for my child. Thank you
Old May 20, 2011 | 03:48 PM
  #17494
i voted twice lol
Old May 20, 2011 | 03:50 PM
  #17495
Baltbitch's Avatar
Residental Bish.
Thanks Jordan
Old May 20, 2011 | 03:57 PM
  #17496
Banzai2.4's Avatar
voted
  #17497
Baltbitch's Avatar
Residental Bish.
Thanks Travisssss <3
Old May 20, 2011 | 03:59 PM
  #17498
Banzai2.4's Avatar
no problem, went to txt you just now actually and the zee phone froze.. bah!
Old May 20, 2011 | 04:00 PM
  #17499
Baltbitch's Avatar
Residental Bish.
BAM! Travis your vote put her on the first page. Thats where we would like her to stay.
Oh lame! Well text away when you fix it lol
Old May 20, 2011 | 04:50 PM
  #17500
voted....
