Drag Racing Kindle Racing and Dalcorp Racing
Went to the drag strip yesterday.... PERSONAL BEST!
Old Apr 12, 2011 | 11:28 PM
Hockeyman's Avatar
Originally Posted by BlueTurbo
That's awesome man. I'm hitting Thunder Raceway park this weekend. Really hoping for low 13's.
if you're from Oklahoma you should roll with us to the Lonestar Bash this weekend.
Old Apr 12, 2011 | 11:30 PM
BlueTurbo's Avatar
I'd love to but already got plans to go to Import Face-Off in Thunder Valley. You know, since those imports need a lesson lol.
Old Apr 12, 2011 | 11:37 PM
Hockeyman's Avatar
Good luck man, I've never been able to get a good run in there because the prep is so shitty. Wish you could roll with us, we are gonna have a huge cobalt cruise!
Old Apr 12, 2011 | 11:42 PM
BlueTurbo's Avatar
Yea I much prefer Tulsa, Thunder Valley really does blow. Have fun fellas. Represent OK proudly.
(sorry to thread jack)
Old Apr 13, 2011 | 08:39 AM
Gremlin85's Avatar
Originally Posted by LS6Rally
WHAT!!! NED!!! i wish i knew you were going. i've wanted to get up there since it opened a few weeks ago.
Nice times, will you be going to Chevyfest in Oct?
Thanks. We'll have to meet up there some time. Every time I go there, theres always some cobalt owner running up there. Maybe set up a day where we can get a bunch of us to meet up and hit the track.
I didn't know about CHevyfest. I'll have to look into it.
Originally Posted by kidcrash603
NED is all new surface this year, I hear it's all concrete now. That's got to help with grip.
Nice job with the times. Were you experiencing any cutout in third? If so it could have been COT, which can be tuned out.
I had no idea it was all new surface! That's awesome. They changed the Helmet rules this year, too. SNELL 2000 or better. Was 95.
Thanks again. I didn't experience any cut out in third. I do have the COT tuned out as well. I feel like the only thing I can do to improve is get my launch down for a better 60' and to nail my shifts a bit better.
This car has low 12's written all over it.
Old Apr 13, 2011 | 09:19 AM
CudaJoe's Avatar
WoW! Good time and trap! We got the same mods except I have a new IC. We even have the same tires, lmao. Im surprised you got that quick with these tires. Im impressed/
WHo tuned you? what boost you making? I got a BYT HPTune right now and my dyno was 299whp and 327trq with slipping clutch. Do you have an aftermarket clutch?
Old Apr 13, 2011 | 09:30 AM
O9cobaltSS's Avatar
great job dude!!
Old Apr 13, 2011 | 10:01 AM
Gremlin85's Avatar
Thanks, man!
What intercooler did you end up going with?? I think that and meth are my next mods.
Same tires too?! Which, the Conti's or the NITTO's? I ran the Conti's this time and my NITTO's are going back on soon.
I tuned me.
With some help from my previous tuner and his dyno that I've been using since I started modding. He's been tuning GM for years and I learned a lot from him. I also learned from Term and BYT as well. The car runs about 24-25 PSI right now. Clutch is stock, turbo is stock, tranny is original as well as the rest of the drivetrain, no suspension mods or anything. All that's done is what's listed in my sig.
I feel very fortunate that everything is holding up and working so well. The only things I've had to replace were the rear brakes last year and the MAP sensor that blew out about a month ago.
Old Apr 13, 2011 | 02:12 PM
newt's Avatar
Good job for street tires!!
Have you tried running your tires with a bit more pressure? I know alot of people seem to have better luck in the 28psi range on street tires as they tend to bow upwards in the center if you run them with low pressures.
You might of already tried this...but I figured I'd lend the advice anyways.
Keep up the good work!
Old Apr 13, 2011 | 02:16 PM
drewbroo's Avatar
28PSI got me up 12 sec pass too. Alot less wheelhop
Old Apr 13, 2011 | 02:41 PM
  #36
Gremlin85's Avatar
Thank you!
And, no, I haven't tried more pressure.... I get what you're saying about the tire bowing up in the middle with less pressure... but more air presure? That definitly reduces contact pacth, though.
Someone at the track when I went for my very first time told me about how to see your contact patch and that would tell you how much pressure you can run. Basically, you just let air out a little at a time, roll your car through a small puddle on flat ground (just to get the tire a little wet) and look at the tread path on dry ground. You can see how much of your tire is actually touching and you can deflate/inflate accordingly... That's how I found that about 24 PSI gives me the widest contact patch in these tires. This is all on the drive tires only.
BUT, I am all for trying new things and I'll give the 28psi a shot next time I go. I'll do whatever works!
I don't experience any wheel hop, really. Only when it kinda bogs. I slip the clutch a lot to balance wheel spin with grip.
Old Apr 13, 2011 | 02:51 PM
  #37
Supercharged Guy's Avatar
Nice run OP
I wish I could pull off a 113 trap lol
Old Apr 13, 2011 | 02:55 PM
  #38
newt's Avatar
Thats a good trick! Never thought of that.
Give 28psi a try...worst case it doesn't work as well and then air them down to 24 again.
The idea is that when the pressure gets low the center part of the tread bows inward towards the center of the wheel...I'm not sure why that happens but thats the threory...lol
The best way really is to start at 30psi and go down 2psi every 2-3 passes....write down your 60' for each pass....and see if on average you are getting better 60's, once you notice them getting worse go back up 1 psi to they get better again....that should be your best tire pressure.
Alot of the time that doesn't work tho since its hard to get that many passes in in a day.
Let us know how it goes!
Old Apr 13, 2011 | 04:25 PM
  #39
Gremlin85's Avatar
Will do! I'll give some of this a try. I'm all for new methods, ideas and suggestions. I just do what I do because it's worked for me so far.
Thanks again everyone.
Old Apr 13, 2011 | 04:39 PM
  #40
BlueTurbo's Avatar
That's where the sweet spots are. It's a tad hard on the clutch, but if you want the best run possible, it must be done!
Old Apr 13, 2011 | 08:12 PM
  #41
LS6Rally's Avatar
Dont forget to air the **** out of the back tires, i run 45-50 psi back there.
Old Apr 13, 2011 | 10:06 PM
  #42
IonNinja's Avatar
sedans FTW!
Old Apr 19, 2011 | 10:24 PM
  #43
MyOtherSS's Avatar
nice time man.
Old Apr 19, 2011 | 11:04 PM
  #44
redcobalt07's Avatar
I was gonna say no way but that proves it. That is one absolutely hell of an epic run.
Old Apr 21, 2011 | 11:40 AM
  #45
Gremlin85's Avatar
THANKS!
Meth Kit should be coming in, so I hope that helps a bit. Gonna air up the rear tires next time. I didn't do it for this run... didn't even occur to me oops.
Old Apr 21, 2011 | 02:50 PM
  #46
tityrous's Avatar
Nice times!
Old Feb 21, 2012 | 08:06 PM
  #47
AARON-SS-TC's Avatar
this is still the best run with your mods at the time...what was the weather like?
Old Feb 22, 2012 | 02:44 PM
  #48
^This
Just takes practice.... and a lot of slipping the clutch.
I hold rpm's at about 2800-3000 and then slip the clutch. I feel for traction and then just GO. I DO NOT NLS into 2nd and then I NLS into 3rd. Before, I use to ride out third all the way to 7000 rpm and across the line but I noticed the car drops off in a lot of power up there. SO, this time I NLS into 4th at 6000 rpm. Took me across at the 113.9, my highest trap ever.
Recap...
Slip clutch at launch at 3000 rpm.
shift regular into 2nd at 6800-7000 rpm
NLS into 3rd at 6000 rpm
That's consistent high 12.'s for street tires for me. Might be different for you. Everyone does things different.
good techniques..my redline is set at stock level though(6200), so i have to shift much quicker...lol
Old Feb 22, 2012 | 02:48 PM
  #49
Gremlin85's Avatar
Weather was ideal for racing. I think it was just about 60 degrees, track was well prepped, some wind gusts but nothing bad, very low humidity and I had about 1/4 tank of gas.
I put mine back to stock for a while and then raised it to 6500RPM like the GMS1.
Old Feb 25, 2012 | 07:51 PM
  #50
skip_jones's Avatar
nice run gremlin!
jcalvin1126
Oct 26, 2015 12:31 AM
Oct 21, 2015 11:57 PM
Hugger1975
Oct 15, 2015 03:28 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
brickloaf
Sep 21, 2015 02:17 PM
