View Poll Results: What gear failed on your F35?
First gear
18
11.92%
Second gear
64
42.38%
Third gear
50
33.11%
Fourth gear
7.28%
Fifth gear
31
20.53%
Reverse
22
14.57%
Multiple Choice Poll. Voters: 151. You may not vote on this poll
The "Broken F35 Transmission" thread
Joining the fun here. Trans and clutch said
after 73k on the clock. I'm pretty sure I cracked the case cause its leaking trans fluid bad. Further inspection will tell.
I broke mine because of wheel hop at the track only. I have MANY drag passes on the car. I will be upgrading mounts and trans now.
I'm in need of a F35 trans with G85(looking to urgrade my 1 wheel wonder). Anyone pm if they got something.
after 73k on the clock. I'm pretty sure I cracked the case cause its leaking trans fluid bad. Further inspection will tell. I broke mine because of wheel hop at the track only. I have MANY drag passes on the car. I will be upgrading mounts and trans now.
I punched a nice hole in mine from the differential case to the bellhousing. Actually, I blew parts through right there.. and my leak looked just like that.
I got lucky though and it didn't get on my hyper single. It all just kind of flowed out. haha.
Finally i get to join you guys with complaining about this damn F35. I drive down to DC from Philly perfectly fine. Then when i get off the highway and hit local streets second gear decided to grind any time i tried to put it in gear. At first i thought it was me but i tried multiple times and different ways to not grind the gears. So now i'm driving around First to Third everywhere i go. I am lucky that it has lasted 78,000 mi. Why can't Chevy make their own tranny. I'm assuming it is issues with the second gear synchro, so now im gonna get that fixed and swap the clutch and flywheel out at the same time. I would love to get LSD as well, but they are soo damn expensive. Does anyone have a used stock one from the G85 package?
Back from the dead. My F35 went out this weekend. I haven't pulled it yet but i can see a hole in the diff housing and a cracked gearbox case. The gearbox is cocked at an angle to the bellhousing. The car wont even start right now because the thing is so badly bound up. I'm worried there might be more problems. This came out of nowhere for me. The car has almost 47,000 on the clock.
3rd gear went out at 13200 miles... i have no clue what broke, but i know it is a very loud click, no 3rd gear, goes in gear without clutch but is basically in neutral. i was just downshifting to get off the highway and bam. blew it all to hell
okay so the swap went okay. transmission and mounts went into the car, pretty much everything is all the same. only one small difference. only problem is, when the car go put all back together it will crank but no fire. plugged in HPT and saw no DTC's. reflashed the ecu to the stock gm s2 tune. comunicated with ecu okay. still just cranks with no fire. scanning shows rpm, pw, duty cycle, and 6* of timing during cranking. no fuel smell or vapors out of the tail pipe even after some cranking. so I am thinking that the injectors aren't actually opening, but not sure. everything was taken back apart and rechecked, connections were rechecked. So I don't know if its possible that the plugs for the injectors and for the plugs got reversed? Or if its possible that the ECU could have gone bad. It was unplugged and set on a bench for 4-5 hours. IDK WTF is going on. Just cranks and cranks without firing.
Any ideas?
Also, found my map sensor is cracked. I only see the 3bar on CED, is it okay to run a 3bar sensor? Would I need to re-tune anything for it? I'm just running the SC with either 3 in in the winter or 2.8 in the summer. Will be on 80#s too this summer for the 2.8 so don't worry about me running that 2.8 on 42.5's.
Any ideas?
another one
hi im new to this and lookin to answers as well i have a 05 ss/sc
what about rebulding the f35 to make it lsd would there be the same problums or is that not even a option
Last edited by QwikenufCobalt; Apr 12, 2010 at 11:53 AM. Reason: sorry i f up i think thats what u were talken about f35 that are made lsd
Similar to the 'how'd you blow up' thread... I'd like to find out what part of their tranny gave out.
I listed a poll to find out what gear... but please state in a post what caused the gear to fail.
In cases where the whole tranny was buggered.... I guess, just post up "I f*cked the tranny bad!"
Can anyone send me an exploded diagram of this transmission ?
Thanks !
Grinds into 2nd and reverse with clutch all the way in at sporadic moments. And doesn't like to throw into 3rd gear all the time. 31,000 miles with intake and exhaust. clutch slippages in second at times. Been grabbing decently lately.
Sounds like either your Synchros are fkd, your shift linkage is screwed up, or most likely: You need to replace your Roll-Pins.
Search out the Roll-Pill replacement thread which is in the How-To section. That might fix your problem.
Ok I'll have to check that out. Thanks for letting me know.
