HELP, I need F35 tranny diagram...
Old 09-11-2009, 08:11 PM
rallyracer's Avatar
Arrow HELP, I need F35 tranny diagram...
Does anyone have good GM diagrams / images of the F35 transmission? Mine is leaking and before I start trying to fix things I like to have a GM diagram.
I know some of you guys can get this info off your GM computers, please help
Old 09-12-2009, 10:25 AM
rallyracer's Avatar
Old 09-12-2009, 11:43 AM
Kennyspec's Avatar
send me your email address
Old 09-12-2009, 11:44 AM
rallyracer's Avatar
PM sent, thanks
Old 09-20-2009, 11:47 AM
rallyracer's Avatar
Old 09-21-2009, 09:47 AM
rallyracer's Avatar
Old 01-24-2015, 09:45 PM
stevenwhaley89's Avatar
F35 Diagram
hey brother, did you ever get a hold of the diagram? i'm trying to find it too and it's pretty hard to come by.
Old 01-24-2015, 09:51 PM
TStone's Avatar
WEll I can get one but idk how it's going to help you....... is it leaking trans fluid or engine oil/rear main?
Old 01-25-2015, 10:01 AM
its leaking trans fluid. i just got underneath her yesterday and saw where it was coming from. so i'd like to see some parts and see what i may need for a reseal
Old 01-25-2015, 01:50 PM
Mr.Tozzi's Avatar
where is it leaking from?
Old 01-25-2015, 08:13 PM
09CobaltSS1's Avatar
I can likely get whatever diagram you need. Are you looking for anything specific? There are quite a few for the f35.
Old 01-25-2015, 08:22 PM
chris88z24's Avatar
Prob the axle seal
Old 01-26-2015, 06:20 PM
It seemed to be leaking from one of the bolts just below the transmission fluid drain plug. I'm not too savvy on this area but it seemed weird to be coming from there. I unscrewed it and there was fluid all along the bolt. And it didn't seem like it was the right bolt for the job. All the other bolts were regular hexagonal, 1/2 I believe. This one was a torque bolt or something. Seemed to be the same size and all. But at any rate, I just swapped one of the hexagonal bolts in its place. Doubt that will work but it seems to have worked so far.
I'd like a diagram showing the innards, seals, and possibly some part numbers so I can begin to diagnose the issue
Old 01-27-2015, 11:25 AM
Let me know if you need something even more detailed and/or part info.
Old 01-28-2015, 10:40 PM
that looks great brother! thanks.
is there a document to go with it that lists each part in reference to the number in the diagram? it's pretty intricate but it seems like i'm look at 46. it's a screw of some sort. close to the one that i found the leak coming from
Old 02-15-2015, 02:51 PM
mongorat427's Avatar
Old 01-22-2021, 01:26 AM
Northeastcustoms's Avatar
hey do you have the full diagram info with parts list you can hit me up with ?
Old 01-22-2021, 09:41 AM
Kolt's Avatar
Here ya go
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
The following 2 users liked this post by Kolt:
GroupA242 (01-07-2023), USMCFieldMP (01-22-2021)
Old 01-26-2021, 06:32 PM
Yet
Yet's Avatar
F35 Output shaft parts
Synchronizer 1 gear (16), and 2 gear (10). Should goes in the same way? When I assembly gearbox I was thinking it can be mistake. Do not remember how I made it. After assembly my 1 gear synchronizer doesn't work correctly. Now I bought new one and I will change it. In other cars with F35 It goes diffrent.
Old 01-26-2021, 06:47 PM
Yet
Yet's Avatar
Checked and in pdf is mistake it should goes like in picture added. Synchronizer from 3 & 4 how it should be. Quite logical.
ACESSbalt
05-02-2011 05:15 PM
07_Red_SS/SC
11-15-2009 05:17 PM
phatnackySS
09-09-2009 09:57 PM
mrbelvedere
07-09-2009 07:15 AM
booosted
04-01-2009 09:34 AM
Quick Reply: HELP, I need F35 tranny diagram...
