Lsj + mp90 dynoed!
not to mention.. changing a bunch of things at a time is really not a great way to figure out what works.. you could switch the header/ dp and tb and maf.. and not see any gains because one part doesn't work well..
and whats with your obsession with crush bent exhaust stuff
sorry, I didn't interpret it that way
- g/cyl is pegging @ 5000 rpm in the high octane table (larger maf housing will solve that)
- Most of the high hp lsjs have blow through mafs
- 5hp is 5hp I didn't have before; only problem I see it creating is a touchy throttle and pegging the maf (both of which are covered)
- It's a spare 3" downpipe I have laying around. Not going to spend $200 on a 3" straight pipe for insignificant gains
people who have made more then 400hp were turbo not sc and you make more then just 5hp with a ls4 one guy on here showed 21hp under the curve more with an ls4 the car isent that hard to drive with it either the bottom and mid you pick is also worth it
throttle size is not as important on the charged air side. This is why the LNF uses a smaller TB than the LSJ as well, despite flowing greater CFMs
Alright let me waste my time and money on a dyno an hour away that reads 25-30whp higher.
So when I lean out to 12.0-12.5 afr I hit 320-330 whp.... that way you won't be dissappointed
get real
get real
you are worrying about too many details to even get it right.
leave the stock tb on it.
change the header. your beloved "g/cyl" will drop like a rock. this will fix for need for a larger maf housing. which will **** part throttle and idle.
eh, I like the LS4 throttle body personally. But there are so many people in this thread now and I think for the most part, everyone is split down the middle.
If you just swap that header and dp, then go redyno, I think that will clear up a lot of issues with everyone on here.
couldn't get a hold of a o2 bung today...
so header install will have to wait until sometime this week.
Going to try and get a dyno in after the new year asap
for all you haters (thank Euthanasia for the temporary donation!)
I'm gonna spend 2 hours taking this damn noodle off my car; there better be a substantial gain
