Running lights wired into turn signals? Or...
Old Sep 21, 2011 | 11:56 AM
Boostin''s Avatar
I finally got the right switchbacks and have had them all hooked up for about 2 weeks now. I everything seemed to be working as they should until yesterday when I looked into the reflection of a ricey civic and realized they were running orange. So I got home and checked them out. They run white as they should when the headlights are on, and even just the fog lights. But when its just the running lights, they are Orange. When they ARE white they switch to and from orange when turning as they should. Just can't get the running lights to run white, which is the reason I bought them. I have just been running my fogs so they'll be white but Id like them to work properly.
I called 3Bspecs and he said the only thing that he could think of is that the running lights run off of the turn signals, making them orange.
So I ask you cobalt masters, Wtf? (05 Cobalt SS)
Old Sep 21, 2011 | 02:07 PM
tunameltman's Avatar
The running light's during the day are the high side of the turn signal bulbs, when the turn signals blink with the driving lights on the bulb just flashes on and off. I don't really think there's a way you can change it because if you did it would make your turn signals white. Hope this helps
Old Sep 21, 2011 | 05:39 PM
Boostin''s Avatar
So the point of Switchbacks is only for night time use? I thought that the point was for them to be white during the day.. they still look sick at night by matching my headlights, but the main reason I bought them was to get a white light during the day
Old Sep 21, 2011 | 05:42 PM
LS6Rally's Avatar
theyre going to be orange due to what tuna said. they are the bright side of the bulb durring the day. if you turn your fogs on all the time, it would kick them down to the dimmer filament, and would be white instead of orange
Old Sep 21, 2011 | 05:45 PM
rekameohs_nire's Avatar
your turn signals are your running lights when your headlights or fogs are not on. i just got switchbacks too. did you use a resistor to install them?
Old Sep 21, 2011 | 05:50 PM
Boostin''s Avatar
Gotcha. Kind of sucks because I dont like the orange running lights but I can just run fogs.
Yes I used resisters, but I dont think I needed them. I installed one, and then before I did the other I put the bulb in alone to see this "hyperflash" and it worked the same speed as the one with the resister. But i still but the second one in for good measure.
Old Sep 21, 2011 | 05:53 PM
maybe ill put them in without a resistor first and see if i need them
Old Sep 21, 2011 | 05:54 PM
Boostin''s Avatar
I would suggest it.. but if you need them, not a big deal. I was a bit worried because I dont do any kind of electrical work with wires.. but it was the easiest thing i have done to the car yet. Just make sure you get the right wires together and use the blue splice connectors if they came with them!
Old Sep 21, 2011 | 06:35 PM
just tried them and i have hyper flash. where did you get your resistors and what did you get
Old Sep 21, 2011 | 07:04 PM
sick_tight's Avatar
id just turn my running lights off when i get in the car
look up how many amps or voltage your regular lights should be pulling and then go to radio shack to find a resistor that will draw that much voltage.
or just check the bulbs resistance with a multimeter and match that
Old Sep 21, 2011 | 08:04 PM
padlock's Avatar
try pulling your DRL fuse and see what that does
Old Sep 21, 2011 | 09:29 PM
NCC-2000's Avatar
^^He can't, the DRL fuse wasn't added until 07.
Old Sep 21, 2011 | 10:28 PM
If I had fogs I'd run those things all the time, lol
Old Sep 22, 2011 | 07:57 PM
Boostin''s Avatar
Got these and they work great.
6 OHM 50W 2 BULB LED LOAD EQUALIZER RESISTORS TURN SIGNAL BLINKER FIX
chefhhr
Oct 26, 2015 10:36 PM
Barkleyj605
Oct 24, 2015 12:07 AM
How to Guide
57
Oct 15, 2015 11:56 AM
ATOMbomb
Sep 11, 2015 10:48 AM
bustaSS
Sep 3, 2015 09:33 PM
